Like Tree52Likes
Old 11-06-2013, 08:19 AM   #3286
Originally Posted by asc6000 View Post
Exactly the issue I have. It may only be the slightest bit and maybe not enough to have a noticeable effect the rear geometry but it is the kind of thing that for me when I know it's not right I lose confidence in the car. Between that and wanting the ability to stiffen the chassis even more I would love to see a stiffer/stronger chassis.
Do you have this issue with the new XB4 2014?
racer_hh is offline   Reply With Quote
Old 11-06-2013, 08:28 AM   #3287
asc6000's Avatar
Trader Rating: 15 (100%+)
no, but I believe the chassis is unchanged, there is no mention of any change by Xray. It is minor but it is there. I doubt it has any real effect but that kind of stuff bothers me.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 11-06-2013, 09:05 AM   #3288
Trader Rating: 28 (100%+)
Just got a xb4 off of a trade. It is a v2 so is there anything that I should look for before running this weekend.
Thanks to my sponsors
Proline racing Sidewinder Fuel 4C Hobby Supply Upgrade-Rc Psm-Rc Rcdepot.ca RcAmerica Hudy Xray
kyok2 is offline   Reply With Quote
Old 11-06-2013, 09:09 AM   #3289
big chris's Avatar
Trader Rating: 50 (100%+)
Check the slipper and set it by the book and go from there.
B6 Carpet
B6 Clay
B6D dirt
SC5M
big chris is offline   Reply With Quote
Old 11-06-2013, 09:22 AM   #3290
joeymdz's Avatar
Send a message via MSN to joeymdz
redo the shocks, check the slipper (do not follow the book.. it is wrong! http://www.petitrc.com/setup/xray/setupxb4/XB4_Tips/), re-grease the outdrives, check the bearings, and I would personally redo the diffs (making sure its running the right fluid, the correct amount, and no damaged teeth on the bevel gears)
**On the slipper the adjustment will vary from how used your car is to what level of grip surface you are racing on. its always better to start on the loose side then tight
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 11-06-2013, 10:48 AM   #3291
Wink
I like things simple, so here's my understanding of the new 2014 spec parts, the most notable items:
The new +2mm rear hangers were designed to provide more forward traction on low traction tracks. Use them directly on the chassis - no chassis plate.
For high-medium traction tracks, stick with the original spec rear hangers and use the chassis plate (no need to cut up your original plastic moulded 2013 chassis). These new rear hangers are not 2mm wider, they are 2mm higher, basically playing with the roll centres and anti squat/height of the rear end. I run med-high traction clay and occasionally astro, so I will not be dropping $60 and hacking up my chassis to get the new hangers just yet.
Question:Martin Bayer ran the new hangers AND the chassis plate and won the 2013 Euro's with it that way. His set up sheet does not show this but if you look at photos of his buggy it is obvious, the rear shot shows RR+2 and the spacer is clearly there. What would combing the two give him?
Front and rear A-arms - redesigned, but maintain the same geometry. You can now move them forward or aft 2mm with spacers. They are also now able to accept carbon fiber stiffeners for high traction - likely carpet/astro type tracks. You can also mount the rear shocks to the backside of the rear arms, apparently for high traction (I'm not sure how this really works to be honest - the same shock with the same oil/spring mounted in the same spot, in front or behind the arm should not yield different handling). (I'll get the new arms once I break mine)
New slipper pads & spring - cool (These I'll get)
New front wheels - they are +1mm wider. If I ran my -.75mm hexes in the rear, would not give me similar results?
Still no machined pistons!
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 11-06-2013, 11:30 AM   #3292
Depends on how old the kit is. Newer 13' kits have the manual updated with the correct slipper settings. Download the latest manual from the Xray site. It should have all the latest info.
Also, as already suggested, redo the diffs, especially the rear one. My rear diff seems to "consume" more oil than the front one.
Sponsored by Maclan Racing
1:10 Xray XB4 - Viper VTX10R BE & VST 7.5 | 1:10 Yokomo YZ2 - Viper VTX10 & VST 8.5 | 1:8 HB Ve8 HHH - Viper VTX8
macke is offline   Reply With Quote
Old 11-06-2013, 05:19 PM   #3293
Trader Rating: 89 (100%+)
When will the new 2014 xb4 be out?
..x-ray xb4 2014....rt6....sct410...eb48.2....et48....tc4 vta....rc10 gold pan re-release ....TF2 and D90 scale trucks..scx10 .mcculloughs in sarver pa.
Revo Dan is offline   Reply With Quote
Old 11-06-2013, 06:06 PM   #3294
hyperfuxx's Avatar
Trader Rating: 20 (95%+)
I was wondering the same thing. I'm debating between this or the 2wd. Just planing on what electrics I go with. I've seen em both the cheapest on stormer.
Mugen MBX7R REDS R7 TE MBX7TR REDS R5 TE MBX7R ECO TEKIN 1900
hyperfuxx is offline   Reply With Quote
Old 11-06-2013, 06:25 PM   #3295
Mid nov is what RCA told me yesterday
ronallen is offline   Reply With Quote
Old 11-06-2013, 06:52 PM   #3296
Ya I'm getting the xb4 first then when the rear motor comes out then I'll get that one. Thx for the eta Ron
Old 11-07-2013, 07:57 AM   #3297
Hi XRay Community,
I am interested in an XRAY XB4 2014, but just realized the gear diff pinion are plastic. Carbon gear diff pinion or metal are optional parts. Sounds like in top of the higher price as other vendors XRAY wants to sell optional parts.
Or is the plastic diff as durable as the others like TLR AE Durnago etc?
Old 11-07-2013, 11:27 AM   #3298
mjk1210's Avatar
Hi XRay Community,
haha. did you really say "as durable as TLR, AE, Durango?" yes, they are as durable as those. But those others aren't as durable as the ones from X-Ray. Not even close.
I'd rather be fishing!
"Watch the quad. Watch the quad! ...SHA-BAM!"
mjk1210 is offline   Reply With Quote
Old 11-07-2013, 11:32 AM   #3299
mjk1210's Avatar
Although this is good advice, I find that no two cars are really exactly the same and if someone tightened down on the spring a little more than someone else, then a measured setting will not be the same. I have found that by starting with a loose slipper and holding the rear wheels while blipping the throttle is the surest way to get it where I want it. Start loose. I mean real loose so it will most definitely slip. A quick blip to hear it slip. then tighten a little at a time until either the pitch of the sound of the slipper changes and/or the front wheels just barely start to lift from the table. I've set mine like this for months now and it has run great with plenty of acceleration and jumping capability with very little wear on any gears or drivetrain parts.
Old 11-07-2013, 01:31 PM   #3300
BillyT.'s Avatar
If you think of the front axle line as the pivot point, the closer the shock is to that line, the softer it will become. The further away, the more stiff it will be.
Moving the shock to the back will have less affect on bump handling than just running a stiffer combo to achieve similar results.
Really, it's just like laying down or standing up your shocks, but on a different axis.
It would be real easy for me to speak the explanation, but for some reason I can't seem to find the right words on here.. derp.
Nemo Racing USA
Agama : Bullitt : Beta
[email protected]
BillyT. is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
ThelanderJ
