Like Tree52Likes
Old 11-03-2013, 08:33 PM   #3271
Arigato's Avatar
Originally Posted by T3tsaya View Post
Thanks I will put it on 15 on the can as that's the lowest I can go but if I'm at 16/81 i don't understand gearing then because you guys are running 19 pinions and I'm at 16/81 should I put on a bigger main gear like the 84?
Yes.
Dog House Racing
XRay XB8E
XRay XB4
XRay XB2
XRay T4'17
Arigato is offline   Reply With Quote
Old 11-04-2013, 12:37 AM   #3272
Trader Rating: 9 (91%+)
Trust me...its that 20 degrees timing that is heating everything up.
Remove it.
leongkc is offline   Reply With Quote
Old 11-04-2013, 06:20 AM   #3273
So if i put the esc on blinky and the motor on 15 because that's as low as it goes I should be fine as long as I put my spur at 84 and gear the pinion accordingly
T3tsaya is offline   Reply With Quote
Old 11-04-2013, 06:45 AM   #3274
asc6000's Avatar
Trader Rating: 15 (100%+)
Gearing is a critical thing. Get a full range of gears in your box.
Here's a good article on proper gearing.
http://www.teamassociated.com/pdf/ca...ear_ratios.pdf
And if the math is too complicated, heres a gearing calculator.
http://gearing.rcgearhead.com/Gearing/Browse
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 11-04-2013, 07:20 AM   #3275
That was helpful but the xb4 doesn't have some of the stuff mentioned there like for a 4wd car it mentioned pulleys and this car uses diffs so I can figure the ratio between my spur and pinion but how do I get the rest sorry for being such a pain just never really had to do much with heat. I would always just pinion down if it was too hot thanks for the help I really appreciate it
Old 11-04-2013, 08:20 AM   #3276
Okay I think I figured it out and with the 16/81 I wa running it says that's I'm running a fdr of 12.66 and for a 6.5 in this car it recommends a fdr of 10 or 11 which would mean I need a 19 or 20 tooth pinion but I'm almost positive that my car would melt with gearing that high so I put the 84 tooth pinion on and with 16/84 I'm at a fdr of 13.13 so what should I do for my 100x50 tight track. Like I said I took the timing to 15 on the motor can which is as low as I can go and I'm in blinky on my esc
Old 11-04-2013, 08:26 AM   #3277
BentKa's Avatar
19 to 20 pinion with a standard spur with a 6.5T no added timing on the motor is what we have been running all season (except 7.5T on very loose tracks).
I would try a 19T and standard spur for a track of that size.
And set the motor to the standard timing it came with to avoid unnecessary heat build up and add a bit of boost instead if needed down the straight
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 11-05-2013, 02:08 PM   #3278
Originally Posted by niemand View Post
Is the new aluminium chassis flat lying on its own on a glass board? Because my new one isn't...
On the other hand the aluminium chassis is so soft on its own that it'll probably get straightened out when attached to the plastic chassis.
Originally Posted by joeymdz View Post
the old aluminium chassis was bent and tweaked from side to side. the new aluminium chassis didn't lay down perfectly flat but wasn't tweaked.
The chassis is quite soft, my v1.0 was bending at the rear after ten packs, just the tiniest bit but still disconcerting. The chassis wears badly at the rear as well. A harder/stiffer chassis would be nice not only for tuning options but to increase the durability.
Originally Posted by BentKa View Post
Nope not arguing.
But I had to go down and look at the chassis we have been using since it came out and the wear is minimal and all 3 XB4's are as straight as new.
My alu chassis was slightly bent right out of the box... Didn't lay flat on a perfectly flat surface. I contacted Xray support and they never heard of any other with the same "problem". Anyway, when attached to the composite chassis part it straighten itself out and seemed flat so I didn't bother.
But... Now after 4-5 race days I can see the rear being slightly bent upwards. I absolutely love this car and I haven't broke a part on it. I have used it solely on carpet and can't see any sign of wear except for the slight bend. I have seen the same tendency on other XB4s as well. Use a caliper or a metal ruler on its side and hold it against the rear of the alu chassis and you will probably see a gap at the very rear end.
Sponsored by Maclan Racing
1:10 Xray XB4 - Viper VTX10R BE & VST 7.5 | 1:10 Yokomo YZ2 - Viper VTX10 & VST 8.5 | 1:8 HB Ve8 HHH - Viper VTX8
macke is offline   Reply With Quote
Old 11-05-2013, 02:19 PM   #3279
Please help guys my xb4 is runnin hot. After two heats we tightened up my slipper and was running about 160 at 5 minutes and after the main 8 minutesI was at 185-190 on the can and 160 on the esc. I'm running the pro trak esc with protrak 6.5 motor with it set one about 20 degrees timing and blinky on the esc. My current gears I'm using is 16 pinion and 81 main and I'm still getting hott. Here is a picture of my track and I have a 84 main gear I can use but don't know what to do. I haven't rechecked my slipper to see if its fried already but I don't think its that the track is about 100x50 with a long straight
Seems like you are under geared instead of over geared. Try a 18T or 19T. Changing to a 84T spur will probably make it even worse...
Remove it.
The timing on the can differs between manufacturers. 20 degrees is not necessarily that much. It depends on the motor. My Viper VST motors comes with 30 degrees of timing on the motor (default) and are adjustable +-15 degrees from that (i.e. they can have 15-45 degrees of timing on the motor).
Old 11-05-2013, 04:13 PM   #3280
asc6000's Avatar
Exactly the issue I have. It may only be the slightest bit and maybe not enough to have a noticeable effect the rear geometry but it is the kind of thing that for me when I know it's not right I lose confidence in the car. Between that and wanting the ability to stiffen the chassis even more I would love to see a stiffer/stronger chassis.
Ayrton Senna
Old 11-05-2013, 06:31 PM   #3281
advpball's Avatar
Trader Rating: 28 (100%+)
Just noticed my front tires barcode golds are worn a lot more than the rears?
Think that the problem is center diff to tight or oil in front to low running 5k front and 3 in rear? Stock foams in front ,running 8.5 motor so not over geared ,but car is a little squarely in rear? to much steering? running mostly stock setup.
xray xb2 de
Johnny 5 designs xsc2
Tekno eb410
all powered by smc battery's and Motiv motors
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 11-05-2013, 06:42 PM   #3282
hobdog's Avatar
Trader Rating: 19 (100%+)
That's normal. Every four wheeler I have had no matter what the diff weights, my front tires always wear faster then the rears
Lunsford racing
Kyosho RB6
DEX408V2
Hoby
hobdog is offline   Reply With Quote
Old 11-05-2013, 08:26 PM   #3283
What made me go down to a 16 was that I was getting 165 to 170's with a 19t pinion im not really sure what to do not I mean im on a 100x75 track
Old 11-06-2013, 02:12 AM   #3284
BentKa's Avatar
You've gotten all the correct advice in the last posts in this thread and on PM's with videos to show you track size etc.
Now go out and try the suggested changes as those are what works for all the rest of us
Bent
Old 11-06-2013, 07:21 AM   #3285
Bortzilla's Avatar
Trader Rating: 24 (100%+)
What kind of brake strength are people with a Tekin RS Pro/Tekin motor running? I'm @ 65 on a med traction/smooth indoor clay track. Am I at risk of messing up the gears with that much or is 65 a good #? Thanks!
Mugen MBX7r / MBX7r Eco
LCRC / Trains and Lanes
"Get the Led out"
Bortzilla is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
