Like Tree36Likes
Old 10-23-2013, 09:21 AM   #3211
subaru_tech's Avatar
Trader Rating: 106 (100%+)
Originally Posted by ps71 View Post
Standard servo works fine, but a low profile will give a little more space.
I use a standard in mine with the hobbywing 120a v2 esc and it fits
thanx.
can a straight alloy arm be used or does the xb4 use a offset servo arm
subaru_tech is offline   Reply With Quote
Old 10-23-2013, 09:48 AM   #3212
ps71's Avatar
I use the arm that comes with the kit, never had a problem with it.
It is a straigth arm...
http://www.amainhobbies.com/advanced...356200&x=0&y=0
Losi 22 2.0 xerun 120a v3.1 6.5t
Xray xb9e w/tekin rx8 gen2 1900kv t8
Spectrum dx3s
ps71 is offline   Reply With Quote
Old 10-23-2013, 03:32 PM   #3213
joeymdz's Avatar
Send a message via MSN to joeymdz
rumor I got was Nov 1st is when the 2014's will be in stock....
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 10-23-2013, 03:34 PM   #3214
BentKa's Avatar
Kits are shipping from Xray now and already in stock with dealers in Europe
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 10-23-2013, 03:58 PM   #3215
joeymdz's Avatar
Bent
I should of explained more in detail.... For the US (Europe can go choke on their new kits!)
Hey Bent,
You mentioned earlier that you prefer a metal diff when the traction is high? (or did I get that backwards>?)
my car came with a rear metal diff so I never got a chance to play/experiment between the two
Old 10-24-2013, 06:53 AM   #3216
Bortzilla's Avatar
Trader Rating: 21 (100%+)
Default Gearing
Looking for a good starting point in regards to pinion size.
I'm running a Tekin Gen2 6.5 w/81t spur.
Here is a pic and video of my local track:
(sorry, pic is a little small)
+ YouTube Video
http://www.youtube.com/watch?v=-FZX0...LsPPg&index=10
Mugen MBX7r / MBX7r Eco
LCRC / Trains and Lanes
"Get the Led out"
Bortzilla is offline   Reply With Quote
Old 10-24-2013, 08:04 AM   #3217
onekiwi's Avatar
Thats a huge track compaired to ours.
Try 18/19
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 10-24-2013, 10:33 AM   #3218
Bortzilla's Avatar
Try 18/19
Thank you.
"Get the Led out"
Old 10-26-2013, 10:50 AM   #3219
FunkyDunky's Avatar
Hi can anyone tell me the advantage of running a RR+2 rear hanger and do you have to run it with the FR+2 hanger?
Cheers
FunkyDunky is offline   Reply With Quote
Old 10-26-2013, 05:31 PM   #3220
BentKa's Avatar
Cheers
The +2 hinge pin holders are used to alter the roll center when removing the rear part of the split chassis.
And yes the RR and FR holders are used together.
More info and illustrations are found in the 2014 supplementary sheet here:
http://www.teamxray.com/xb4/download...tary_sheet.pdf
Bent
Old 10-26-2013, 07:50 PM   #3221
nexxus's Avatar
Trader Rating: 301 (100%+)
Had an absolute shocker with this car last race meet, had a suspension arm break in the last qualifier, then in the first final, a slower car misjudged the triple jump and landed on top of my buggy snapping the front bulkhead where the shock tower is connected and the front Uni failed (the pin punched through the plastic retaining collar)
Have a spare XB4 and while I have ordered replacement parts (and Exotek Collars) am wondering if it is worth keeping the 2nd unit as spares if breakages are common, or call it a fluke and just keep a couple of spares and sell the spare?
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 10-26-2013, 08:50 PM   #3222
MrLosi88's Avatar
Nexxus you can fix that pin from happening by going to a pin with a flat spot and a grub screw, screwed into the cv shaft.
Because I was told its a common problem with the xb4.
Other then that is a monster of a car. Love it to bits I also snapped the front bulkhead after hitting a tree with it coming over a triple.
Adelaide Rc Team Driver - Troy McGuire
XRAY XB4 '14 Spec / Nosram
XRAY XB4 2WD / Nosram
WWW.ADELAIDERC.COM.AU
Now a ARCR member
MrLosi88 is offline   Reply With Quote
Old 10-27-2013, 12:41 AM   #3223
nexxus's Avatar
Yeah got the exotek cups on order from NBHC along with a new bulkhead not sure if it will get to me in time for Friday (postage just said flat rate) so am using the spare car to rebuild my racer, which is just as well as I found I'd bent a hingepin and the two front eccentric bushes had disintegrated too. Also found I was way overgeared for 17.5 (FDR was 5.8) which would explain a lack of punch up to the jumps. Just going to go back to kit set up for Clay but with the track width at it's widest so I can get some more stability for now.
Old 10-27-2013, 01:33 AM   #3224
silvalis's Avatar
Trader Rating: 29 (100%+)
What was a tree doing on your triple
I went to the orange exotek cva covers from nbhc too. The $10 flat rate is express, however they may take a day or two to post. I was told a few pages back that the pin punching through is a symptom of dry cvas - took me 4 months + going back to mod to get one to punch through.
I was at 69/30 with my reedy m2 17.5 @ 35-40 deg. Dunno what that fdr equates to (forgotten the idr). I had reasonable punch over the jumps (but my track requires cornering speed rather than punch out of the corners).
What setup are you running? I was running Boz's setup with a few shock tweaks...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 10-27-2013, 07:42 AM   #3225
Chris Rakus's Avatar
Trader Rating: 17 (100%+)
Has anyone tried the avid pistons for this car, and if so could you tell a difference and what size did you get.
Thanks to my sponsors
Team Associated, Reedy, JConcepts, Nitro Pro Fuel, RC Addiction Products, Sanwa, Murnan Modified Motors
Chris Rakus is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
