Like Tree52Likes
Old 10-14-2013, 05:00 AM   #3151
mjk1210's Avatar
Originally Posted by big chris View Post
Anyone know a US store that has 365114 (bevel gear) in stock? First weekend on the XB4 and slipper was too loose at first then apparently too tight. Was super awesome even after it lost a few teeth!
Also does someone have a pic of both (V1 and V2) 35T Bevel gears side by side?
the difference is that the v2 gears have a small 35 molded into the side of them. v1 gears don't
I'd rather be fishing!
"Watch the quad. Watch the quad! ...SHA-BAM!"
mjk1210 is offline   Reply With Quote
Old 10-14-2013, 05:07 AM   #3152
Originally Posted by BentKa View Post
It doesn't matter which way you orientate the spring.
The spring will compress just the same either way
I usually have them mounted with the markings on the spring facing up to be able to identify them quicker
Bent
If you got more coils on one side they will compress in different way.
Did you check the coils on your progressive spring?
OMP / ModelFlight.com.au / Losi 8 4.0 1/8 nitro off-road
marco cianfrone is offline   Reply With Quote
Old 10-14-2013, 05:30 AM   #3153
BentKa's Avatar
NO.....that is incorrect !
A spring will always compress the same regardless of which way you mount it.
There's no way of applying pressure to just one side of the spring.
Put 2 dampers (without oil) with springs in a shock tool (like Losi's) with the springs the same way, compress and observe, now flip one of the springs the opposite way and compress again.......then get back to me
You're not alone in thinking this though.........it's a VERY wide spread misconception
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 10-14-2013, 09:13 AM   #3154
joeymdz's Avatar
Send a message via MSN to joeymdz
google:XRA365114
I found 2 stores that have them in stock (but they are not the normal online ones)
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 10-14-2013, 10:32 AM   #3155
Bortzilla's Avatar
Trader Rating: 24 (100%+)
Guys - What size/length screws are used for tuning the chassis flex? I don't see any mention of this in the manual and the used kit I bought didn't include any extra screws. Thanks for your help.
Mugen MBX7r / MBX7r Eco
LCRC / Trains and Lanes
"Get the Led out"
Bortzilla is offline   Reply With Quote
Old 10-14-2013, 10:47 AM   #3156
joeymdz's Avatar
(90 3310) HEX SCREW SFH M3x10/ 2mm
http://www.petitrc.com/setup/xray/se...XB4_Manual.pdf
very helpful site:
http://www.petitrc.com/setup/xray/Se...tsXrayXB4.html
Old 10-14-2013, 11:02 AM   #3157
Bortzilla's Avatar
Originally Posted by joeymdz View Post
Thank you!
"Get the Led out"
Old 10-14-2013, 03:25 PM   #3158
advpball's Avatar
Trader Rating: 28 (100%+)
the only thing i need more of is practice time.Otherwise love it.
xray xb2 de
Johnny 5 designs xsc2
Tekno eb410
all powered by smc battery's and Motiv motors
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 10-14-2013, 03:47 PM   #3159
BentKa's Avatar
Bent
Old 10-14-2013, 03:51 PM   #3160
ImageX's Avatar
Exactly. A spring does not know which side is up or down... nor does it care.
ImageX is offline   Reply With Quote
Old 10-14-2013, 05:04 PM   #3161
Pulse_'s Avatar
coming back from a local indoor onroad carpet track were the buggies are allowed and the xb4 is already faster than the touring cars even if it was our first time there
we ran used mini spike in yellow and the car was awesome! I had my SV2 with me too and it has a better steering on this tight track but this is normal being a 2wd, laptimes were a tad slower though because of the lack of traction compared to 4wd
https://www.youtube.com/channel/UC1CAwFfuz1K3chBSVpIlSew
Pulse_ is offline   Reply With Quote
Old 10-14-2013, 09:09 PM   #3162
Trader Rating: 26 (88%+)
Default Major Slipper Issues
My XB4 has some major slipper issues...tried everything scraped the glaze, etc even tried a new set of Associated pads...to no avail. Got the car to work decent after I razor scraped the stock pads and tightened the slipper almost all the way locked down probably about a 1/4 turn out from locked. Anyone have these issues. Running the composite gears in the difs...rebuilt the difs with 7000 front and 5000 rear...anyone...someone???
jgonz is offline   Reply With Quote
Old 10-14-2013, 09:35 PM   #3163
joeymdz's Avatar
Has the slipper never worked or I this a new issue? What is your gap space using calipers
Old 10-14-2013, 10:14 PM   #3164
Just under 5mm the manual says 5.5-5.7 again its locked down and backed a 1/4 at the most to get it to work somewhat decent. I bought this used but in really close to new condition. When I first ran it a couple weeks ago it was whipping around the corners....came to find out last week that the slipper was locked (I hadn't even thought of checking it) so when I ran it again I followed the recommended setting and could not get it to work properly. I did go through the diffs and the gears were missing a tooth here and there im guessing from running it locked down. Again I replace the gears when I redid the difs....still no clue???
Old 10-14-2013, 11:17 PM   #3165
Odin544's Avatar
Trader Rating: 93 (100%+)
Sounds like you need to replace the slipper spring. If it was locked all the way down for some time it probably over compressed the spring. That is where I would start anyhow.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
