Like Tree36Likes
Old 12-12-2012, 11:25 PM   #301
Bigkev's Avatar
Originally Posted by Boz View Post
Made by Xray, these may fit as the composite gear where made to replace the metal ones
Active Diff Steel Bevel & Satellite Gears (2+4)
Hey Boz I think those diff gears are for 1/8th size active diffs, too big (XB9). With the info from the guys above I’m assuming the diff gears from the nitro 1/10th on-road car Xray NT1 would most likely be a direct fit. Part #XY335030.
http://www.nbhc.com.au/products.php?...b4)-(Xy335030))
But all speculation at the moment to start changing diff gears, will have to wait for all the guys who have their buggies to get some laps down and see how the stock ones go..
AKD Prototypes (Koln)
Bigkev is offline   Reply With Quote
Old 12-12-2012, 11:54 PM   #302
Boz
Trader Rating: 23 (100%+)
Ops
Wrong link. All fixed. Thanks for pointing that out BigKev.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 12-13-2012, 12:04 AM   #303
onekiwi's Avatar
Heres mine
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 12-13-2012, 12:38 AM   #304
OleC's Avatar
READ THIS, IMPORTANT INFO!
I started building mine last night, and found something:
The manual says nothing about using shims to get proper mesh from the crown and pinion gears in the diff casing. There are no shims supplied either.
BUT, I had to add 0,2mm of shims in the rear diff, and 0,3mm of shims in the front diff to get perfect mesh.
That is quite a lot IMO, but not all kits will be the same so check yours while building. And check your car if you already have built it!
I had to use shims to get a tighter mesh. With the loose mesh I had in my diffs with no shims, I would not be surprised if the gears would strip quite easily.
ALL crown gears and pinions need to be shimmed in order to have perfect mesh, which is crucial for durability. I am a bit surprised that Xray chose not to include this...
Tamiya makes some very nice shim kits in 0,1 and 0,2 and 0,3mm thicknes (TAMIYA part number 53588 for the 10mm set). I bought a bunch of shim sets in various sizes some years a go, since there is always something that need to be shimmed properly
JQ The Car Black Edition - O.S. - BUKU - AKA - Byron - Sanwa - Sav÷x
No sponsors. I drive what I like, and so should you
OleC is offline   Reply With Quote
Old 12-13-2012, 12:44 AM   #305
Boz
Sorry onekiwi,, but I don't like.
Why.....
....cause it's sitting on your work bench and not mine.
All the best at your first test day.
Chris Bozich
Xray XB8 XB4 XB2
Old 12-13-2012, 01:24 AM   #306
Onekiwi, do you fancy showing us a few close up pics of your wiring/ what space you've got in there? I notice you've mounted your receiver on the rhs of the car...
Mugen Seiki | Beta | KO Propo | OS Engines | Byron Fuel
OliOC is offline   Reply With Quote
Old 12-13-2012, 02:11 AM   #307
speedy2's Avatar
http://www.teamxray.com/xb4/
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 12-13-2012, 02:25 AM   #308
Bigkev's Avatar
Hey the guys/girls who have already received their buggy kits, has the instruction manual been updated or did you receive a setup guide showing which screws to use for the different flex of the chassis settings?
Just keen to know.
Old 12-13-2012, 02:42 AM   #309
OleC's Avatar
My manual is not updated, so its a bit confusing to know which screws to remove for the different settings.
I havent checked my XB9 manual, but i guess you could adopt the settings there?
Edit: If you go to the above linked XB4 presentation and scroll down to the presentation of the multiflex chassis, there are three images showing the three different settings (animation).
No screws = soft
Screws along the centerline = medium
Screws along the centerline + outside in both ends = hard
Old 12-13-2012, 02:47 AM   #310
onekiwi's Avatar
There is a guide in the manual and on the setup sheet that follows
Wiring, yeah I think there is tons of room as I came and still have a durango 410.
I have a hobbywing V2.1 which is one of the biggest escs and there is no probs with room, only thing is I might file off the screw hole/cable holder thats on the outside of the sidepod, that way I can rotate the esc 90░ and solder the wires downwards
With the short distance to the motor from the esc I think you could use 14AWG for more flexibility and 12AWG to the batteries as either the + or - will be quite long
My motor wires went over the upper brace but Ill sort out a little better install at a later point.
Pics Ill look at getting a little later on today
heres one:
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 12-13-2012, 04:52 AM   #311
Z00M's Avatar
Trader Rating: 15 (100%+)
Are we there yet, are we there yet........
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 12-13-2012, 05:07 AM   #312
hanulec's Avatar
Trader Rating: 27 (100%+)
i see that a lot of these build-ups are missing motor fans like xray shows on their web site. is there are reason to not run a fan in a 4wd buggy?
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-13-2012, 05:18 AM   #313
speedy2's Avatar
are the diffs all composite? satelittes, crowngear and axles
Old 12-13-2012, 05:29 AM   #314
BentKa's Avatar
Outdrives are metal.....rest is composite.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 12-13-2012, 05:43 AM   #315
onekiwi's Avatar
The esc's look better withour the fans and it makes it look like there is more room.
Always run a fan with 4wd
XB2 CE
XB4 16
Sanwa
Hobbywing
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
