Like Tree36Likes
Old 10-09-2013, 04:55 AM   #3061
BentKa's Avatar
Default New 2014 Spec Xray XB4
Posted on Facebook by Xray Racing Cars:
The new 2014 specs of the European Championship winning XRAY XB4 coming very soon. Watch out!
https://www.facebook.com/TeamXray
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 10-09-2013, 05:51 AM   #3062
Pulse_'s Avatar
how soon is very soon...hummm
I'm wondering what did Xray do to improve an already very good car, let's hope the price won't change!
https://www.youtube.com/channel/UC1CAwFfuz1K3chBSVpIlSew
Pulse_ is offline   Reply With Quote
Old 10-09-2013, 06:43 AM   #3063
Suspended
Trader Rating: 6 (88%+)
This passed weekend was regionals and it was my first race with the car. once i figured a good setup on it the car was really good. i was able to qualify 7th out of about 39 buggies and i finished 6th after the triple a mains. Seth also got his into the a and so did a fellow racer which was his first weekend with the car as well. i dont remember where they finished overall though.
for the ones looking for a 12mm hex fix. i ran all weekend with the conversion i found but i did find a flaw. if you over tighten the wheel you will bind the bearings. after each run i would actually loosen the hex and reposition them so that when i would tighten the wheel again they wouldnt bind the bearing. the problem is that the pin sits too deep in the losi hex. good news is that Jason from JConcepts was there and i told him what was going on and gave him the product idea. He ended up taking my buggy with him and a set of the stock hexes to try to get a conversion for it. hopefully hell be able to get one.
Jader Lopez
JaderL is offline   Reply With Quote
Old 10-09-2013, 08:36 AM   #3064
DanielC.'s Avatar
Trader Rating: 56 (100%+)
I finished 7th and Seth 8th . Not bad for our first race with the car.
I was doing the same thing you stated with the TLR hexes, and using thread lock as extra security. Hopefully Jason will be able to bring a proper conversion to market. Would be sweet if we could use b44 fronts as well.
|HVR Batteries|JConcepts|Serpent America|Desoto Racing|EZ Customs|FactoryOne|Shiverville Raceway|
DanielC. is offline   Reply With Quote
Old 10-09-2013, 09:16 AM   #3065
joeymdz's Avatar
Send a message via MSN to joeymdz
I bought my car used and it came with 1 off machined hexes front and rear. I was running b44 fronts and b4/losi rears. I didn't care for the front hex's. The rims were very loose on the axle and serrated nuts was a must! Plus since they were one off's I couldn't change my hub offsets.
I really like the Xray rims. Very solid and tough (pipe clipping and no scratches).
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 10-09-2013, 10:50 AM   #3066
Suspended
Oh my gosh! So many new 4wds I'm like a kid at a candy store. I'll be getting xb4 14 and d413.
latentspeed is offline   Reply With Quote
Old 10-09-2013, 05:46 PM   #3067
Woulvesbaine's Avatar
Any chance you need a 410v3 with fresh clay tires as well?
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 10-09-2013, 06:21 PM   #3068
DanielC.'s Avatar
I'll take those adapters off your hands if you don't want them
Old 10-09-2013, 07:31 PM   #3069
Suspended
No thanks. I'll pass. Had a 410 v2. Great car but was too mannered for my style. Loved the responsive steering. I was supposed to have gotten xb4 when it came out, but it had issues and I really wanted to try xray so I ended up with t4. I've been waiting for this update! In fact I might not be getting d413 anymore. Nothing steers like an xray and not boring easy like kyosho or yokomo.
Old 10-09-2013, 08:01 PM   #3070
Trader Rating: 48 (100%+)
If they adapt the 3 diff setup nd shorty packs like the d413 I will make this my 4wd
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 10-10-2013, 01:10 AM   #3071
Bcholka's Avatar
Just 1 request-go away from the "composite" diff ring/pinion gears--bad bad idea-lots of failures from people-everyone "out of stock" with the pinion gear--yikes!!!!
I know I know-shim properly, loosen slipper, lower boost settings etc etc etc--bottom line they just weren't a good idea IMO
2-Tekno EB48.2's, 1-Tekno ET48, 1-Tekno NB48, 1-Tekno NT48, 1-Tekno SCT-410, 1-AE B5, 1-AE B5M, 1-Kyosho RT6, 1-Kyosho MP9e TKi, 1-TLR Losi Mini 8ight
Our Awesome Sponsors: Tekno RC, AKA Tires, Dialed Designs Airbrushing
Special Thanks to: Trackside Raceway, Clark R/C Park & RC Scoring Pro
Bcholka is offline   Reply With Quote
Old 10-10-2013, 01:21 AM   #3072
BentKa's Avatar
All you need to do is learn to set the slipper according to grip level and surface
We've been running 5.5T and 6.5T boosted on high grip astro with Schumacher Mini Spike and Mini Pin this summer with no problems at all
The XB4 has a very easy to adjust slipper as well as high quality slipper pads that don't fade......shouldn't be hard to adjust correctly at all
Takes 1-2 min max when you get to a new track or the grip level has changed.
Bent
Old 10-10-2013, 04:40 AM   #3073
Nitronut3's Avatar
Send a message via AIM to Nitronut3
I love the composite gears. When you switch to metal gears you also increase heat inside the diff. When I ran Durango I hated the metal gears for that very reason. You had to run thicker oil and hope it thin out enough. Set everything right and you'll have no problems.
Nate Jaskot
XRAY, RC America, KO Propo, Hudy, FX Engines, Nitropro, Rc addiction products , TeamSR, SmacTrac
Nitronut3 is offline   Reply With Quote
Old 10-10-2013, 07:25 AM   #3074
asc6000's Avatar
Trader Rating: 15 (100%+)
Defending a product without question that clearly is not perfect and never admitting that POSSIBLY it could use a little help. In psychology thats called denial.
Different people will have different experiences. Expecting everyone in the world to have exactly the same experience as you is totally unrealistic. Thats why WE have a conversation to share and learn.
I've never said you HAD to shim. Merely that it is an option if you feel it is neccessary.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 10-10-2013, 07:56 AM   #3075
BentKa's Avatar
Originally Posted by asc6000 View Post
I'm old enough to disregard the mfgs' recommendations. For better or worse I grew up in my dads machine shop so I learned about tolerances at a young age. I allow for heat expansion but if I think there is too much slop... I'll shim. Yes the new bevel is thicker, the NT1 metal gears are thicker as well. So if you used the new bevel and metal gears it will be MUCH tighter than the old bevel and composite gears.
Seems like there is room for questions about shimming and it's need based upon each persons situation.
You're the one stating the NT1 gears are thicker.....and if I used them it would be much tighter......which is incorrect.
You're the one disregarding Xray's recommendations and give the impression to know more about the tolerances and "heat expansion" of the gears then said manufacturer.
Yet.....you're the one stating the gears (or product) are not "perfect" when I'm the one (who follows the directions) NOT having any problems or shimming issues after building 3 of these and racing them every other week since January........see my point ?
That's the beauty of the Xray's......they're not a product made cheaply in the far east......thus the tolerances are very tight
Same discussion in the XB9E thread........the ones following instructions have no problems......while the ones with years and years of "hands on forum experience" and "the knowledge the R/C manufacturers would pay big bucks to get a hold of" are the ones having issues.......hmmmmm
And yes I would expect everyone to have the same experience with the exact same product following the exact same manual and manufacturer recommendations
Bent
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
