Like Tree36Likes
Old 09-23-2013, 04:38 PM   #2836
ImageX's Avatar
Originally Posted by joeymdz View Post
^^^You'll hate it!!!! but I'll buy it from you for $150.00 shipped? lol
enjoy the new ride
Thanks! I'll have to pass on the sweet offer though. I'm getting ready to assemble the diffs here in a few minutes.
I noticed you guys were talking about wings. I was wanting a molded heavier grade wing but there doesn't seem to be any out there. I was told because they would be too heavy. I wonder why they don't make them anyway. Too hard on the car/towers in a crash?
ImageX is offline   Reply With Quote
Old 09-23-2013, 06:17 PM   #2837
Odin544's Avatar
Trader Rating: 93 (100%+)
There is nothing wrong with the wing that comes with them unless you spend a lot of time upside down.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 09-23-2013, 06:28 PM   #2838
Odin544's Avatar
Originally Posted by leongkc View Post
I suspect so. Use smaller hole pistons?
It's doing one of two things. Its bottoming out hard and bouncing off the track, in which case you need thicker oil or smaller holes. Or it is over dampened and isn't soft enough to absorb the landing. I would guess it is under dampened and needs smaller holes.
I run on a hard packed clay outdoor and am running pretty close to the clay setup. I'm running 3 hole 1.3's al around with 40f/35r.
TriCitiesRC.com
Old 09-23-2013, 06:33 PM   #2839
protc3's Avatar
Hey guys, what diff oils are you running front and rear. I am thinking of tryin 7k front and 3k rear to mellow my car out a bit. Have any of you tried that combo?
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 09-23-2013, 06:42 PM   #2840
Arigato's Avatar
I'm running that combo right now and it seems pretty good.
Dog House Racing
XRay XB8E
XRay XB4
XRay XB2
XRay T4'17
Arigato is offline   Reply With Quote
Old 09-23-2013, 07:00 PM   #2841
protc3's Avatar
Good to know. I am running 10k front and 5k rear and it is pretty good but seems to be a little irratic. I was thinking of trying the forward holes on the steering rack but im not sure if that will mellow it out too much. The steering rack is a quicker change but i dont want be changing diff oils at the track. Thanks for your input. I am leaning towards the oil change
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-23-2013, 11:19 PM   #2842
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Jason....
Seth from Superior was recommending running 7/3 and also running the avid piston with the Avid shock setup which is.
Use 1.5+1.1 piston in XB4 Front. Start with 35 wt Associated oil (425 cSt). For XRAY oils, use 450 cSt.
Use 1.6+1.1 piston in XB4 Rear. Start with 30 wt Associated oil (350 cSt). For XRAY oils, use 350 cSt.
From Avid:
XRAY racers can now run the signature AVID setup on the XB4 buggy. The AV1033 pistons are custom machined from XRAY shocks to tune high speed and low speed damping separately with 2 large 1.5mm (or 1.6mm) holes and 2 small 1.1mm holes (we call it the 2+2 piston). AVID's test drivers found that these pistons help provide the traction and bump handling of running lighter shock oil or larger piston holes, while still maintaining the control of running heavier oil or smaller hole piston when taking on jumps.
http://www.avidrc.com/company/news/1...Available.html
I changed out my pistons trackside on Saturday and ran the 35/30 AE oil and I could tell a big difference.
I'm still running 10/5 but I will be changing that out when Superior hobbies restocks on diff fluid sometime this week.
I also purchased the JC 6.5 high down force wing and wanted to try that out.
But changing the pistons and diff fluid should help a lot bro...
A battery pack a day keeps the stress away
RED-LINE M03 is offline   Reply With Quote
Old 09-24-2013, 04:07 PM   #2843
ImageX's Avatar
Build complete! Just need paint, tires, and electronics install.
Old 09-24-2013, 04:17 PM   #2844
Nitronut3's Avatar
Send a message via AIM to Nitronut3
Originally Posted by mjk1210 View Post
i noticed the same thing and went back to the 1.3 - 3hole to compare. a definite lack of pack with the 1.7. So either be sure to downside the jumps very well or try a smaller hole. the 1.7 should be very helpful on a bumpy track with smooth landings though.
I found that 1.3-3 hole with 32.5 and 22.5 rear seams to be a good mix. I'm experimenting with different combos right now
Nate Jaskot
XRAY, RC America, KO Propo, Hudy, FX Engines, Nitropro, Rc addiction products , TeamSR, SmacTrac
Nitronut3 is offline   Reply With Quote
Old 09-24-2013, 04:17 PM   #2845
asc6000's Avatar
Trader Rating: 15 (100%+)
if your track is med/low in traction or bumpy drop it all the way to 5/3, really mellow
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 09-24-2013, 04:17 PM   #2846
aloksatoor's Avatar
Trader Rating: 42 (100%+)
The protector needs to face you in the front tower. Looks ugly but works. Else you will have wear and potential delamination on the front tower.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 09-24-2013, 04:24 PM   #2847
ImageX's Avatar
Yeah, I have my M2C bra on my Mugen reversed as well. I just don't like the ugliness in front. If the towers get beaten up... I'll just replace em.
Old 09-24-2013, 05:40 PM   #2848
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 09-24-2013, 05:44 PM   #2849
I sanded and then painted my braces flat black - hides them well!
New buggy, old school paint scheme.
[IMG][/IMG]
Daragh Slowey
Old 09-24-2013, 05:46 PM   #2850
ImageX's Avatar
Originally Posted by HeavyD99 View Post
Or paint'em flat black like I did...hides them well.
New buggy, old school paint.
Yeah, man. I was actually thinking about doing that myself. Still keeping them on the backside though. Have a shot from the front?
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
