Like Tree39Likes
Old 09-10-2013, 01:36 PM   #2746
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by joeymdz View Post
my buddy has some avids and they are a bit too tight. My other buddy is using kyosho big bores. Im almost tempted to get the RB Products "A.D.S."
I drilled mine out to 1.6F and 1.7R
http://www.hudy.net/xhudy/news/newsd...&kategoria=194
I run the avids had to go a bit lower on weights compared to the drilled ones. The avids are very very consistent though and fit just right. The stockers are rounded edges while avids are flat so you might feel they are bit too tight I guess. If ghea were to come out with xb4 I would get those in a second. Best pistons ever for my rb6.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 09-10-2013, 03:24 PM   #2747
joeymdz's Avatar
Send a message via MSN to joeymdz
which avids are you running and what weights are you running? I should take off my RB6 shocks with the Ghea pistons in them (that would be the ultimate shock )
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 09-10-2013, 03:29 PM   #2748
aloksatoor's Avatar
haha yeah sadly ghea pistons for rb6 wont work, too thick for the xray eclip notches in the shafts. From my last race in the xb4
Front 3 dot springs with 1.5x2 1.1x2 35 losi
Rear 1 dot springs 1.6x2 1.1x2 30 losi
Old 09-10-2013, 03:43 PM   #2749
joeymdz's Avatar
I was thinking about using the whole shock on my Xray (Im not feeling the RB6 anymore) Im using AE drilled and shaved pistons but there's so much slop as everyone knows.
wow thats alot thinner in weight but you are racing in a hotter climate. I'm using 40F/ 32.5R losi, Oregon weather (would you sell the other 1.5/ 1.6??)
Old 09-10-2013, 03:44 PM   #2750
silvalis's Avatar
Trader Rating: 29 (100%+)
I recall trying this. Gotta watch your shock length/droop as from memory the RB6 front shock is a fair bit shorter?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 09-10-2013, 03:53 PM   #2751
LoudOne's Avatar
Trader Rating: 31 (100%+)
Hi, is a 13.5 motor fast enough for the XB4? I have two builds going right now that happen to be 4WD buggies. I've only ever driven 2WD. The esc is an LRP FLOW Works Team. Thanks!
Kyosho RB6.6, ZX6.6
Serpent SRX2 MM
X-RAY XB4 (2013), XB2 Carpet (2017)
Schumacher KF2
LoudOne is offline   Reply With Quote
Old 09-10-2013, 04:17 PM   #2752
aloksatoor's Avatar
Yessir I had posted pics a while back. The front droops too much and the rears as well. The xray towers are a lot shorter than the lazer and b44. The xray shocks are not bad with the aluminum tops though. I would not put kyosho shocks on mine ride heights tough to get down to 18mm if needed with the kyosho springs and all. The xray springs wont fit the kyosho bodies.
Also I just bought the smaller 1.5x2 1.1x2 pistons and drilled a pair out to 1.6 mm. No big deal just be careful and slow and use lots of compressed air/light to clean out the hole and see what you are doing. Used this http://www.amainhobbies.com/product_...ston-Drill-Set
Oils might be a bit light. I have not run the car for last 3 months or so been running on road in summer. The off road marshalling takes a toll in the hot california desert air . On roads more relaxing. Will be back playing in the dirt for the winter series of course. Nothing beats big air!!
Old 09-10-2013, 04:25 PM   #2753
locked's Avatar
That really depends on the size and layout of the track, the traction levels and also your driving abilities.
Around me, most people use a 6.5 in 4wd. Some as low as 5.0. Others as high as 10.5. I use a 6.5 with a little bit of boost and turbo. Feels just right to me for the tracks I go to. Could be major overkill on a small dusty track with narrow lanes though.
In 2wd it usually ranges from 13.5 down to 7.5, maybe 6.5 if you're crazy. I use a 9.5. Most of the guys I race with use an 8.5 for 2wd.
Ask around at your local track(s) what motors everyone is running. It will give you a better idea of the range you want to be in than you'll get from random people in other parts of the world
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 09-13-2013, 07:14 AM   #2754
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
What's your guys take on the XB-4?
How does the XB4 rotate say compared to a 4wd running a double ball diff?
Is there another good forum for the XB-4 because this thread seems kind of dead compared to the others.
Just installed all my electronics last night can't wait to get out to the track.
A battery pack a day keeps the stress away
RED-LINE M03 is offline   Reply With Quote
Old 09-13-2013, 07:25 AM   #2755
caguilar4's Avatar
Hi guys,
Need to buy a 2nd XB4, but sit seems to be on backorder everywhere Ive looked. Im ina bit of a time crunch, and need it delivered in two wekeks tops.
Anybody got a lead as to where I can find one, other than ebay?
RB6 | XB4 | SC10.2 | MBX6 | RC8.2e
caguilar4 is offline   Reply With Quote
Old 09-13-2013, 07:30 AM   #2756
Arigato's Avatar
1. Great kit! From build quality to durability.
2. It rotates very well compared to ball diff, just need to learn to tune with diff oil.
3. I haven't found another forum as busy as this one. However, the more people that get the car, the more likely to forum will get busier.
4. You're going to love it!
Dog House Racing
XRay XB8E
XRay XB4
XRay XB2
XRay T4'17
Arigato is offline   Reply With Quote
Old 09-13-2013, 07:49 AM   #2757
onekiwi's Avatar
I think that everyone is just really happy with how the car runs just on stock setups so ther isn't really much to talk about. Its the same on other fourms, a little dead till people run into problems.
I can fix a XB4 roller if anyone want to buy one
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 09-13-2013, 08:19 AM   #2758
joeymdz's Avatar
I was the Lawn Dart King last night and even with my cringing shoulders from the impact(s) on hard clay... nothing BROKE!!! I'm running the Bayer set still and the only thing I changed was the the diff fluid 10F/5R from what I was previously running (5F/3R for an outdoor loose dirt track). Huge difference! The rotation wasn't there and the rear end was unpredictable. I should of just changed the front diff to 7-8K (next time)
Other than the shock pistons not being up to par and not having spare diffs... the car is aswesome
Old 09-13-2013, 07:41 PM   #2759
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by caguilar4 View Post
Hi guys,
yea man, get some spare kits. I haven't even opened one for parts yet. Long Live the XB4.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 09-13-2013, 08:46 PM   #2760
You've got some deep pockets or your really good at photo shop
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
