Like Tree52Likes
Old 09-08-2013, 09:02 AM   #2716
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by protc3 View Post
I am running the trackpower 6.5 and am eating up 1/8 e buggies on a large outdoor track. I am now going back to work on my e buggy setup to try to get it running more like the xb4. I need a softer setup in my e buggy i see.
Physics is not on your side, can't make a nascar handle like an F1.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 09-08-2013, 09:42 AM   #2717
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
What kind of low profile servos are you guys running?
Any problems with the low pro in the 4wd?
I was looking @ the Savox 1251mg or the Spetrum 6070.
Or is everyone running a full size servo?
A battery pack a day keeps the stress away
RED-LINE M03 is offline   Reply With Quote
Old 09-08-2013, 10:12 AM   #2718
Red - I plan to run a full size servo, a BLS451, SP GT2.0 Pro, spektrum 3500 micro receiver & my MRT transponder all on the same side. The capacitor will be mounted on top of my servo - the only thing on the other side will be the motor, fan & on/off switch.
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 09-08-2013, 10:47 AM   #2719
locked's Avatar
Shorty servo works fine. I've been using a savox 1251 since day 1. Gives a bit more room for the ESC and makes it easier to route wiring through the little channel under the front drive shaft.
Spektrum S6070 is a Savox 1251MG, just with a different case and higher price tag.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 09-08-2013, 11:12 AM   #2720
BentKa's Avatar
Originally Posted by light View Post
has any one tried the Yaiba Racing XRAY XB4 Carbon Fiber Full Length Upper Chassis Deck?
We use it on Malin's astro setup
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 09-08-2013, 03:36 PM   #2721
Bent
Do you happen to have a setup sheet for that somewhere?
"If you have complete control over the damned thing, you're not going fast enough."
kaan is offline   Reply With Quote
Old 09-08-2013, 04:48 PM   #2722
silvalis's Avatar
Trader Rating: 29 (100%+)
I used a 1251 for 12 mths in my kyosho fs2sp with no issues. Moved it to my xb4 then eventually switched to a futaba s9551. Been running this for the last 6 mths.
I run low profile servos (also using a bls551 and a ko one10) in all of my 4wds and haven't had any issues yet.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 09-08-2013, 05:52 PM   #2723
joeymdz's Avatar
Send a message via MSN to joeymdz
Its funny that were talking about servos. I'm not sure if its my bls551 no centering or if its my servo saver. I bought the car used (roller) and had zero issues until recently. The servo saver was at 2.5mm and I went back to 1mm as per the manual. It seems to be corrected but that shouldn't of made a difference correct? Has anyone else had problems from their cars not centering?
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 09-08-2013, 06:12 PM   #2724
aloksatoor's Avatar
Trader Rating: 42 (100%+)
I run the same servo in my 2wd buggy run its big bro the 451 futaba in the xb4. No issues centering. Maybe the servo horn is slipping? I would check that first.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 09-08-2013, 07:29 PM   #2725
hobdog's Avatar
Trader Rating: 19 (100%+)
I've had the same problem. I actually just pulled my servo saver apart after I left the track today to see if that was it. Mine seemed to be cranked down quite a bit also (bought mine used), but the servo saver plastic looked to be in perfect shape so I'm still not sure, but I am thinking it must be my older hitec 7955 from the nitro days getting a bit of slop in it.
Lunsford racing
Kyosho RB6
DEX408V2
Hoby
hobdog is offline   Reply With Quote
Old 09-08-2013, 08:09 PM   #2726
Arigato's Avatar
+1 If you're running the plastic servo horn that could be the issue. It was for me.
Dog House Racing
XRay XB8E
XRay XB4
XRay XB2
XRay T4'17
Arigato is offline   Reply With Quote
Old 09-08-2013, 09:12 PM   #2727
joeymdz's Avatar
Opened up the servo and didn't see any messed up gears but te horn was kinda worn. Is there an aluminum one available from xray?
Old 09-08-2013, 09:22 PM   #2728
Arigato's Avatar
Not yet. I use this one:
http://www.amainhobbies.com/product_...rvo-Horn-Black
Dog House Racing
XRay XB8E
XRay XB4
XRay XB2
XRay T4'17
Old 09-08-2013, 11:15 PM   #2729
joeymdz's Avatar
Originally Posted by Arigato View Post
Cool thank you
Old 09-08-2013, 11:44 PM   #2730
joeymdz's Avatar
New question about the set up sheets: when talking about the servo saver being tight, medium, and soft.. would soft be 1mm, medium 2mm, and tight 3mm? Is there an exact measurement?
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Caradha
