Like Tree52Likes
Old 08-26-2013, 07:41 AM   #2626
Trader Rating: 54 (100%+)
Originally Posted by kosmickid View Post
I'd be interested to know, those who have had the Durango DEx410 before your XB4's, how does the Xray compare in terms of strength, space and ease of maintenance?
I'm thinking of switching over.
I now have 2 race days on the XB4 compared to the DEX410v3. I did not have durability issues with either, so no help there. Durango is very aggressive to the point of being twitchy and loose on my local track. Was never able to calm it down enough that it was easy to drive. The XB4 is very easy to drive out of the box. Still has plenty of steering, but is much more planted and more forgiving.
Mugen Seiki | AMain | Radiopost | PT RC Racing
jsmax is offline   Reply With Quote
Old 08-26-2013, 08:45 AM   #2627
Thank you for the feedback guys, your comments align with how I've felt about the DEX410 as in being very aggressive/twitchy and constant failures or issues after every Heat. More likely now I'm going to go for the XB4 as I'm by no means an expert so I need a tamer buggy and something which is going to give me track time and not constantly spend time fixing. I race on a High grip Astro track which does take its toll on the cars.
kosmickid is offline   Reply With Quote
Old 08-26-2013, 10:14 AM   #2628
Odin544's Avatar
Trader Rating: 93 (100%+)
I've never owned the durango and have no plans to. But I race with guys who do run them. If they finish a race it's a pretty big deal. We have a few triples that are pretty difficult to land and if you don't land them right you chance breaking your car. The durango guys never even try to do them. I have no issues or reservations about tossing my car over them. I'm perfectly confident that my car wont break even if I case the jump, which I have done several times.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 08-26-2013, 10:56 AM   #2629
onekiwi's Avatar
I really don't know where you guys are getting your info from but the 410 is one of the most robust cars there is... That was my car as a noob and man I crashed. I did break a few things , most of that to do with how I was driving NOT the quality of the car AT ALL!! (maybe and exception with the ball cups)
Any car will break if you don't land jumps properly or hit curbs etc.
I did find the 410 quite aggresive and not really to MY liking so I did swap over to the XB4
The XB4 I find is robust but am seeing a tendence to break a few rear hubs also ball cups ripped out or broken and do a bearing or two.
This is considering that I have become a bit of a better driver as well.
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 08-26-2013, 12:35 PM   #2630
coretex's Avatar
My car suddenly started clicking when accelerating when I ran it today. When I hold the spur gear and the left back wheel, I can enforce the clicks by forcing the right back wheel around (not using excessive force). This do not happen at the front diff.
When I opened the back diff, I found no error. Maybe the plastic cover holding the diff in place has expanded a little as the metal gears seem fine? Should I try shimming the back diff?
coretex is offline   Reply With Quote
Old 08-26-2013, 01:39 PM   #2631
Do you have the metal diff gears in the rear housing or the stock plastic ones? I see you said "metal gears seem fine". When my stock plastic gears finally gave up it did exactly as you described and it wasn't obvious when looking at them.
Tijuana_Taxi is offline   Reply With Quote
Old 08-26-2013, 02:52 PM   #2632
Check the ring and pinon gear.
On mine the pinion gear inside the diff part number 365114 was chipped after I replaced it and part number 364935 the clicking sound was gone
Gorden
Gorden
light is offline   Reply With Quote
Old 08-26-2013, 03:13 PM   #2633
asc6000's Avatar
Trader Rating: 15 (100%+)
Similar to my experience. I did find evidence of the gears skipping (little pieces of plastic in the diff fluid and the gears were not like new). In my case I replaced that gear set with metal gears and on the other diff I simply shimmed it up, still running that original plastic v1 gears in that diff.
Yea, try shimming, shouldn't take much.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 08-27-2013, 01:38 AM   #2634
coretex's Avatar
for the record, I do not have plastic gears.
Old 08-27-2013, 09:17 AM   #2635
Argh...I just wrote a huge reply based on the clicking occurring without power/force. Then I just retread your post and see that you DID use a forced spin by holding the SPUR and wheel. If this produces a clicking then, YES, it is the diff slipping. With gear diff, that means you've got eithe worn gears and/or need to shim.
HTH
Associated: B4.2 FT, T4.2 FT
XRAY: XB4
MUGEN: MBX6R
Old School Memories: RC12E, RC1O GoldPan
CaptainGizmo is offline   Reply With Quote
Old 08-27-2013, 10:32 AM   #2636
Default K1 vs. XB4
These XB4's must be pretty darn good because no one is selling one in the for sale section!
I have a dilema, get a K1 or an XB4. (Searching this thread for "K1" is too short a word, LOL). I just sold my 511 and need something that is tough and handles clay - there will be some carpet racing, but mostly clay. I don't mind ball diffs or belts, but saw an XB4 on the clay last week and it was silent and ran really well - but I hate leaking diffs. I race at a Schumacher supported track, so there is a ton of set up help and parts - but this XB4 looks so good.
What to do, what to do....
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 08-27-2013, 10:53 AM   #2637
locked's Avatar
If you build xray gear diffs correctly, they will hardly ever leak. I have never had any of mine leak (4 xrays, over 2 years, all with nearly identical gear diffs). I have one diff in my T3'12 that I built over 2 years ago with 1000 cst and I have never rebuilt it. Still buttery smooth and it has never leaked.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 08-27-2013, 11:08 AM   #2638
coretex's Avatar
How do I shim the diff exactly? Could somebody please tell me where/which gear to shim?
Sorry for all the work gizmo, but I think it might help others
Old 08-27-2013, 11:12 AM   #2639
dandrc's Avatar
Default xray xb4
Hey guys just looking for a little help. I just recently purchased and built my xb4 and did some practice runs to find a good setup. It seems the shocks are always leaking I've taken them apart a few times to find the problem and have had no luck. The oil leaks around the upper cap .don't know if I am doing something wrong or what. wry
i live with fear every day of my life ,sometimes she lets me race.
.dirtdevilsrc, station2raceway
Dan's RC parts, rc life
dandrc is offline   Reply With Quote
Old 08-27-2013, 11:25 AM   #2640
Xray released these to address the problem
http://www.teamxray.com/teamxray/pro...p?prod_id=4546
When I built mine before they came out with their fix I used some o-rings from my TRF201 shocks of the same size, mine haven't leaked a drop.. Should be easy enough to come up with some at your local hobby shop.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
