Like Tree36Likes
Old 08-13-2013, 02:28 PM   #2596
locked's Avatar
If you reinforce the wing by shoegooing an extra piece of lexan in the bottom indent area, it makes it far less likely to break a mount. Also seems to make the wing last a bit longer.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 08-13-2013, 06:33 PM   #2597
Arigato's Avatar
Please post a picture of that if you can. Thank you.
Dog House Racing
XRay XB8E
XRay XB4
XRay XB2
XRay T4'17
Arigato is offline   Reply With Quote
Old 08-14-2013, 11:10 AM   #2598
glock man's Avatar
Another question for you Xray B4 guys. Do any of you guys run the TLR scte 2.0? I know you really can't compare a short course and buggy but are there any similarities in handling? I am still waiting on my B4 just trying to do some research. I don't know much about 4x4 other than you steer with gas. Or so I have been told lol. I still learning on my 4x4 short course.
glock man is offline   Reply With Quote
Old 08-14-2013, 05:22 PM   #2599
RMKinWI's Avatar
Trader Rating: 15 (100%+)
Originally Posted by joeymdz View Post
Question: when filling the diffs do you guys go by weight or by filling just above the satellite gears? When filling by weight it sure does look like its too much in there! Anyone else noticed this?
+ YouTube Video
+ YouTube Video
Matthew Lust
www.WisconsinSurplus.com
RMKinWI is offline   Reply With Quote
Old 08-15-2013, 06:19 PM   #2600
neallewis's Avatar
Originally Posted by mental_raycer View Post
I apologise...the problem being that we can't run stock motors in the XB4 without modifying another spur gear. the holder idea works great, if you have a lathe
just machine up an aluminium bar with about a 3mm deep pocket thats a push fit on your AE spur, then fit 3 bolts around the outside to clamp it down. then use a 5.95mm drill bit to take out the centre hole and while youre there remove the internal shoulder. assemble onto xray slipper clutch assembly and youre good to go
You need the RW Racing XB4 spur gears available from MB Models here in the UK:
http://www.rccarshop.co.uk/index.php...html?limit=all
78-85 tooth available. More sizes if you request them: http://www.rwracing.co.uk/contact.html
YZ-2 | B-MAX4III | 2x B-MAX2 MR | Cougar KF | RC10 | RC10WC | Supastox GT
neallewis is offline   Reply With Quote
Old 08-15-2013, 06:47 PM   #2601
silvalis's Avatar
Trader Rating: 29 (100%+)
I used to run an SCTE2.0. In the broadest sense driving style is the same, but buggies have far more air control and grip - especially lateral grip.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 08-15-2013, 07:25 PM   #2602
asc6000's Avatar
has anyone noticed that weighing the diff oil and eyeballing it is not the same? (should I just rely on eyeballing it?)
this was my first gear diff race care (don't count the Avanti) and I didn't have a 1/100th gram or whatever scale.. I eyeballed it, after the breakin and fluid weight adjustments the eyeballing seems to be working.
you don't really wanna see a piece of junk superglue uglied up wing... It's embarassing just getting caught with it on the car.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 08-19-2013, 05:32 PM   #2603
Default Motor mount
I've just picked up a used XB4 and am very much looking forward to racing it this weekend.
I've read through most of this thread and noticed a few people referring to motor mount issues, where some were experiencing movement and a stripped spur. Can anyone expand on this for me, or am I worrying about nothing?
On another note I'm using a Tekin RS with their gen1 8.5 - What kind of gearing would you recommend? I'm a little concerned the RS is going to get hot, as I don't think 4wd mod was it's target market!
RichD is offline   Reply With Quote
Old 08-19-2013, 07:35 PM   #2604
mjk1210's Avatar
I don't think you need to worry much about the motor mount. Put a bit of Loctite on the screws going into the mount and you shouldn't have any issues. I haven't anyway. Maybe check the screws between runs if you are really concerned.
8.5 can probably run between a 20 and 23 tooth pinion depending on track size. Might want to add a fan for any 4wd vehicle.
Speed Passion USA - speedpassion.net
Leisure Hours Hobbies & Raceway - leisurehoursraceway.com
"Watch the quad. Watch the quad! ...SHA-BAM!"
mjk1210 is offline   Reply With Quote
Old 08-19-2013, 08:13 PM   #2605
Bcholka's Avatar
I'd be concerned about that too. I'm running the RS Pro with zero issues. If you do decide to run that setup please keep us posted!!!
2-Tekno EB48.2's, 1-Tekno ET48, 1-Tekno NB48, 1-Tekno NT48, 1-Tekno SCT-410, 1-AE B5, 1-AE B5M, 1-Kyosho RT6, 1-Kyosho MP9e TKi, 1-TLR Losi Mini 8ight
Our Awesome Sponsors: Tekno RC, AKA Tires, Dialed Designs Airbrushing
Special Thanks to: Trackside Raceway, Clark R/C Park & RC Scoring Pro
Bcholka is offline   Reply With Quote
Old 08-19-2013, 08:35 PM   #2606
Thanks for your feedback.
Do you mean the screws going into the motor through the plate that sits in the clamp, or the clamp screws themselves?
I'll probably go with a 20t pinion until I get a higher amp speedie.
Cheers
Old 08-19-2013, 09:15 PM   #2607
When I was using the 8.5 with my RS I ran a 22t piņon and had no problems with heat.
If that helps
Gorden
Gorden
light is offline   Reply With Quote
Old 08-19-2013, 10:53 PM   #2608
If that helps
Gorden
Cheers Gorden. That gives me some comfort while I wait for the new ESC. And slightly faster motor
Old 08-20-2013, 08:42 AM   #2609
mjk1210's Avatar
Cheers
both. basically, any screw going into any aluminum pieces should get a little bit of blue loctite. Not too much, and NOT RED (permanent). Just a bit so it holds together with all the bumping around that it might get But still check screws after each run and if you notice anything coming loose just add a little bit more loctite.
Last weekend I noticed a couple screws loosening on the front spindles at the top and bottom of the caster blocks. So take the tires off and check those every once in a while too. no loctite there though. It will "melt" and ruin plastic parts.
Better to take a minute going over the car then finish a race early parked on the side of the track.
Old 08-20-2013, 09:38 AM   #2610
joeymdz's Avatar
Send a message via MSN to joeymdz
Here is a little wing goof I tried this past weekend and it worked out very well!!!
Before cutting the front of the wing I left on a little bit of extra lexan so it can "rest" over the rear shock tower thus keeping the wing straight after accidental flips. My joking around worked! I figured once the lexan starts to rip at the 90 degree cuts I would just cut it right off.
On my next wing I'll cut it more rounded than a 90 degree cut.
joeymdz is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
MTYL
