Like Tree36Likes
Old 08-10-2013, 04:59 PM   #2566
seth556's Avatar
Trader Rating: 42 (100%+)
You can go the 1dot rear springs and that will give it a good bit more rear bite. Although the stock setup is very good on higher bite flowing tracks. On tight indoor tracks that Bayer setup is great.
seth556 is offline   Reply With Quote
Old 08-10-2013, 05:00 PM   #2567
joeymdz's Avatar
Send a message via MSN to joeymdz
I tried the Martin Bayer set up and it was really good on a NW dirt track. Only thing I changed was the diff oils... 7/3 to start out with but ended up with 5k in the front and 3k in the rear. It made it very stable and predictable but I'm going back to 7/3. It pulled through the corners on power and was on point
joeymdz is offline   Reply With Quote
Old 08-10-2013, 11:54 PM   #2568
Trader Rating: 55 (100%+)
Where can I find this Bayer set up? I'm racing on a tight indoor medium to high bite clay track. Car just doesn't settle in after a jump like it should. Anybody using 2 hole pistons? If so what weight oil? Also anybody using the RB ads shock inserts?
Jamison R is offline   Reply With Quote
Old 08-11-2013, 02:25 AM   #2569
Z00M's Avatar
Trader Rating: 15 (100%+)
All the Xray setups are on the teamxray.com web site. Search by model. If you want a great setup for 2hole pistons then also have a look at Chris Bozich's setup.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 08-11-2013, 10:52 AM   #2570
joeymdz's Avatar
http://www.petitrc.com/setup/xray/Se...tsXrayXB4.html
Old 08-11-2013, 12:34 PM   #2571
pekow91's Avatar
Trader Rating: 45 (100%+)
Anyone try using Velcro on the body instead of using body clips. It works on my RB6 and would love to get rid of the clips.
Kyosho RB6 | Kyosho MP9 TKI3E | Xray XB4
pekow91 is offline   Reply With Quote
Old 08-11-2013, 01:00 PM   #2572
Default Bayer Setup
There is an info on the M.Bayer setup , that he use new xray topdeck.
Anyone saw it? Maybe its full lenght like yaiba.
farm is offline   Reply With Quote
Old 08-11-2013, 01:36 PM   #2573
joeymdz's Avatar
Are you looking for pics?
http://www.petitrc.com/setup/xray/se...lid2013071820/
Old 08-12-2013, 03:19 AM   #2574
Default xb4 new top deck
Yep, thanks
Im f...n blind.
Old 08-12-2013, 09:45 AM   #2575
mental_raycer's Avatar
Originally Posted by Bcholka View Post
What's the problem with the spur gear?? We've had zero issues on indoor high bite clay for months. Am I spose to be worried about something??
I apologise...the problem being that we can't run stock motors in the XB4 without modifying another spur gear. the holder idea works great, if you have a lathe
just machine up an aluminium bar with about a 3mm deep pocket thats a push fit on your AE spur, then fit 3 bolts around the outside to clamp it down. then use a 5.95mm drill bit to take out the centre hole and while youre there remove the internal shoulder. assemble onto xray slipper clutch assembly and youre good to go
Chris Mitchell
West Coast Model RC Club President
Ryper Hobbies | AKA Racing | Hobbywing | Wild Turbo Fan
mental_raycer is offline   Reply With Quote
Old 08-12-2013, 08:11 PM   #2576
joeymdz's Avatar
Question: when filling the diffs do you guys go by weight or by filling just above the satellite gears? When filling by weight it sure does look like its too much in there! Anyone else noticed this?
Old 08-12-2013, 08:16 PM   #2577
asc6000's Avatar
This was my first gear diff race car so.... and my scale doesn't weigh 1/100th of a gram so.... I eyeballed it. After a short learning curve it seems to be working out.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 08-12-2013, 08:32 PM   #2578
silvalis's Avatar
Trader Rating: 29 (100%+)
I've been using velcro and no clips since i got my launch release xb4. I still leave the posts in though...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 08-12-2013, 08:33 PM   #2579
joeymdz's Avatar
I hear ya but that's why I bought a scale. It just looks like too much fluid when weighing it. Anyone else uses a scale or by the magic eyeball?
Old 08-13-2013, 08:20 AM   #2580
glock man's Avatar
Default New to Xray B4
Hello Gents! I recently purchased an Xray b4. I should have it here by Friday. I am new to 4x4 buggies. I read good things and bad things about the xb4. I just couldn't wait for Losi to elevate their game. I am reading this thread and see people are having problems with landings on xb4. Any advice would be great. Also what motor shold i run? I have a brand new orion pro 160 amop speedo i plan to use. Also what parts should I stock up on? Last thing i want is to break down and not be able to continue racing.
Thanks guys
glock man is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
