Like Tree52Likes
Old 07-22-2013, 11:20 PM   #2506
We race on astroturf, so lots of grip. I will recheck the slipper though. A lighter motor did also came into our minds. I do have a 6.5t motor, so I will try that.
It's true that stripped gears will let you finish, but it is sounding like a coffee grinder. That not XRAY worthy in my opinion.
I'll have to wait to try things, I am busy with maintenance on th car and don't want to mess with this setup (accept slipper) before the next race.
gdw1963 is offline   Reply With Quote
Old 07-23-2013, 02:05 PM   #2507
KOULLIT's Avatar
Default Shock body - external thread for collars ?
Hi,
I'm searching for the diameter of the external thread, on the XB4 shocks bodies, if you have a digital caliper, because I need a precise dimension :
And can you tell me too, the thickness (millimeters) of the XRA368040 Aluminium shock collars ?
Thanks,
Bye !
SYLVERIS RC - Option Racing Parts
LOSI 8IGHT-E 3.0 - Tekin RX8 GEN2 - Tekin T8 - Futaba 3GR 2.4Ghz
1/8 Off-Road Electric - Belt drive conversion : http://www.rctech.net/forum/electric-off-road/665377-1-8-offroad-electric-belt-drive-conversion-6.html
The French forum : RCMAG.COM
KOULLIT is offline   Reply With Quote
Old 07-24-2013, 03:44 PM   #2508
Default first run
Yesterday was the first run with the XB4. Nothing broke and I was immediately in a comfort zone with the car. I could place the car wherever I wanted and it is very stable. It has a little bit more initial steering than my K1 out of the box and i love my K1. Overall, I am very happy with the XB4. I ran the car at California's norcal hobbies.
Mowilly is offline   Reply With Quote
Old 07-24-2013, 04:20 PM   #2509
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Nice to know. I might come and run at norcal one of these days I run only on road there
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 07-24-2013, 04:26 PM   #2510
pekow91's Avatar
Trader Rating: 45 (100%+)
You should check out their new 1/10th scale outdoor track. Its comparable to the one at Delta. Tons of grip and tire wear.
Just ran my new XB4 out there last Saturday. So much fun. Thanks again for the help.
Kyosho RB6 | Kyosho MP9 TKI3E | Xray XB4
pekow91 is offline   Reply With Quote
Old 07-26-2013, 09:13 PM   #2511
JOJOHAMBONE's Avatar
Trader Rating: 31 (100%+)
Hi Im getting my xb4 tomorrow and was wondering what everyone is running for batteries?
Blake Morris
-521 Designs-Tony's Hobby+Video-R&L R/C Products-Richards and Lees Cabinets-
**2014 XB4**Tekin RSX, REDLINE 5.5t, Protek Servo, Revtech Formula X Batteries
JOJOHAMBONE is offline   Reply With Quote
Old 07-26-2013, 10:54 PM   #2512
pekow91's Avatar
SMC and just got a new thunder power saddle that I will be testing next week.
Old 07-26-2013, 11:58 PM   #2513
pekow91's Avatar
Hey guys, I noticed my xb4 has this clicking sound when I am on the track. However the sounds goes away when I run it on my stand.
I checked the front/rear diffs and they are super smooth. However I didn't open up the actual check the internal gears. The ring and bevel gears look good. I noticed the slipper gear moves front and back about 1/8-1/6 inch between the drive lines. The slipper clutch is set at 6.2mm and I just put in fresh center bearings.
I am completely stumped and would appreciate any help. Thanks
Old 07-27-2013, 12:50 AM   #2514
.AJ.'s Avatar
The only time my XB4 has clicked is when the cvd pin in the front centre drive shaft popped throught the plastic retaining collar, it's worth checking all the cvd joints on the buggy
Losi 5ive T - Bartolone G340 - Hitec 1000 & 845 - MIP Shocks & Brakes + loads more.
TLR 8ight E 4.0 - HW Xerun XR8 Plus - Xerun 2250kv G2 - Protek 170t - IP powered
Spektrum DX4R Pro
.AJ. is offline   Reply With Quote
Old 07-27-2013, 01:02 AM   #2515
And although the differential- and bevel gear looks alright at first sight, check the thoroughly. I suspect the bevel gear, otherwise as mentioned by .AJ check the pins from the centre driveshaft. If not lubricated properly the tend to push through the plastic retainer. That's why we use homemade aluminum sleeves but you can get commercial ones.
Old 07-27-2013, 01:48 PM   #2516
.AJ.'s Avatar
Wired up my mates new XB4 the other day, she looks sweet in blue
Spektrum DX4R Pro
Old 07-27-2013, 04:13 PM   #2517
I just posted on the RB ADS thread but thought I'd try here also. Anyone tried RB's ADS yet? What are some good starting oil weights? Springs?
nickmig is offline   Reply With Quote
Old 07-27-2013, 04:17 PM   #2518
pekow91's Avatar
I like that blue.
Old 07-27-2013, 04:22 PM   #2519
pekow91's Avatar
Thanks guys. The pins havent pushed through but on closer inspection a few teeth of the bevel gear seem to be sheered off. Just ordered a new set so hopefully thats what was making that sound.
Old 07-27-2013, 05:00 PM   #2520
About the clicking...after about ten runs with the car I noticed some clicking and assumed the worst. I like to use my trigger finger as my slipper. After inspecting both diffs they looked like new. I then checked the CVD pins and everything looked good. I run at California's Norcal hobbies and the track is not a horsepower track and it's a medium traction indoor track. I then ran the car on carpet in my house and did not hear the clicking anymore. I can't explain the clicking sound that I heard from the car at the track.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
