Like Tree45Likes
Old 07-14-2013, 09:01 PM   #2491
Bcholka's Avatar
Originally Posted by Rampokker View Post
Here you go:
We run 21.5 motors in 4wd stock. The fan is just extra protection.
Your wiring is so clean I almost thought your car was wireless!!!!
2-Tekno EB48.2's, 1-Tekno ET48, 1-Tekno NB48, 1-Tekno NT48, 1-Tekno SCT-410, 1-AE B5, 1-AE B5M, 1-Kyosho RT6, 1-Kyosho MP9e TKi, 1-TLR Losi Mini 8ight
Our Awesome Sponsors: Tekno RC, AKA Tires, Dialed Designs Airbrushing
Special Thanks to: Trackside Raceway, Clark R/C Park & RC Scoring Pro
Bcholka is offline   Reply With Quote
Old 07-15-2013, 12:32 AM   #2492
Rampokker's Avatar
Thanks!
It did take me some time to get it right. It's not quite perfect, but I'm happy with it.
XRAY XB8 - Keep Off 21-4
XRAY XT9 - Elite 8 Off
XRAY XB4 - Tekin RS Pro / Fantom 6.5
Rampokker is offline   Reply With Quote
Old 07-16-2013, 02:13 AM   #2493
.AJ.'s Avatar
Here's my wiring
Losi 5ive T - Bartolone G340 - Hitec 1000 & 845 - MIP Shocks & Brakes + loads more.
TLR 8ight E 4.0 - HW Xerun XR8 Plus - Xerun 2250kv G2 - Protek 170t - IP powered
Spektrum DX4R Pro
.AJ. is offline   Reply With Quote
Old 07-16-2013, 05:06 PM   #2494
Bcholka's Avatar
Originally Posted by .AJ. View Post
Here's my wiring
Another sweet job!!
Old 07-16-2013, 06:02 PM   #2495
Joel Lagace's Avatar
what are carpet/astro turf guys running for diff oil?
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 07-16-2013, 08:06 PM   #2496
Suspended
Default steering
Here's my wiring
what aluminum steering rack is that ...
poorboy racing is offline   Reply With Quote
Old 07-16-2013, 11:00 PM   #2497
MikeR's Avatar
Trader Rating: 15 (100%+)
Hi Fast Guys,
A few new XB4 upgrades are in stock. Choice of black or Xray orange.
If these do well I'll be sure to launch many more
http://www.exotekracing.com/
Thanks!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 07-16-2013, 11:23 PM   #2498
.AJ.'s Avatar
Yaiba Racing
Spektrum DX4R Pro
Old 07-17-2013, 12:38 AM   #2499
.AJ.'s Avatar
Originally Posted by MikeR View Post
Hi Fast Guys,
Thanks!
Nice, I'm glad they do black so it won't clash with the red theme on my XB4
Spektrum DX4R Pro
Old 07-20-2013, 11:19 AM   #2500
turboken's Avatar
Hello is this buggy worth taking a look at?
team www.trick-parts.com team shark bite tire treatments
turboken is offline   Reply With Quote
Old 07-20-2013, 11:36 AM   #2501
AP3XMONK3Y's Avatar
Congrats to Martin on the winning the euros This morning he drove awesome and kept the all the big dogs behind him and the xb4 looked pretty planted to the ground.
DEX210,Hobbywing,futaba,revtech,jconcepts
DEX410V3,Hobbywing,futaba,revtech,jconcepts
s350 bk1 evo
AP3XMONK3Y is offline   Reply With Quote
Old 07-22-2013, 10:41 AM   #2502
We keep stripping the bevel gear and if not noticed (heard) in time the differential gear. The front seems to have the most problems. I set the slipper accordingly the supplemental sheets and it slips as it should (I have it's set at around 6.2mm). Motor wise i use a 5.5t motor with a 17t pinion. Mesh is setup properly and minimal.
Don't know exactly when is happens, but I think after hitting the brakes very hard, after a verry long straight.
I'm certainly not the only one, I know at least 4 or 5 people with the same problem. I also know that shimming is not the way, but as support from XRay don't answer my thread on their own forum I have no other option.
The car drives like crazy, but this keeps the fun away! I'll start with a shim behind the bevel gear (0.1mm) en on the outgoing bearings (0.1mm). This makes the mesh smaller but stil there is some play.
What are your opinions about this?
gdw1963 is offline   Reply With Quote
Old 07-22-2013, 01:33 PM   #2503
Too much brake power ?
Indeed I've seen several braking bevel gears but they still be able to finish their run and this is a very tough car overall.
mojo tom is offline   Reply With Quote
Old 07-22-2013, 04:02 PM   #2504
Z00M's Avatar
I think you'll find that with the 5.5 motor you are doing speeds higher than a lot of us will ever see and braking hard from such high speed is going to cause issues. What sort of surface are you racing on?
You have a couple of options I think. The slipper is going to give the gears the best chance of surviving. Have you tried loosening it half or one turn? This might give the slip needed under brakes. The supplement was 6.2 to 6.7 from memory.
A shim will prolong the life of the gears a little as long as there is some freeplay as you mentioned.
Probably the next best thing would be to go with a 6.5T motor and a 19 or 20 tooth pinion and see if the softer drive is easier on the gears.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 07-22-2013, 04:45 PM   #2505
seth556's Avatar
Trader Rating: 42 (100%+)
I've had the same thing happen once or twice. I think it's the internal diff gears and not the ring and pinion but I'm not sure. It's only happened a few times and my gears all seem fine. I'm using a 6.5t motor, and it's only on one track we have here in Florida where it's a super long straight with a ton of traction where it dumps into a tight turn so you go from the fastest it's ever been on a track to full breaking with a lot of traction.
seth556 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
