Like Tree247Likes
Xray XB4 thread
Old 07-08-2013, 05:33 AM
  #2461
onekiwi's Avatar
With the deals on SP stuff you can get a esc and spare motor for a good price.
Otherwise hobbywing orion.. Toro looks really good as well.. Someone is surely going to chime in with tekin but you need a pc if you want play with settings. The other escs you have a program box
onekiwi is offline
Old 07-08-2013, 06:22 AM
  #2462
seth556's Avatar
Trader Rating: 43 (100%+)
Originally Posted by pekow91
Hey guys, I was thinking of picking up an XB4 and had a few quick noob questions. I will be running on a indoor clay track with some tight turns and good traction and wanted to know if the kit set up was a good place to start or if you guys found a better setup.
I was planning on running the the avid 2+2 pistons based on Aloksatoor recommendation. But I wasn't sure if there were any other hop up/tuning options I should consider.
Also, does anyone have a lead on a used one? I checked the classifieds and only saw one.
My setup is pretty close to stock. Those pistons are really good, helps the car quite a bit. Other than that I'm running 5/3 diff oil and a lot of guys are running 5/5 or 7/7. I've tried a lot of things on setup and like some of them but then I'll go to another track and it's terrible or inconsistent. The stock setup is very fast, there's just little tweaks to adjust it into your driving style and track conditions.
seth556 is offline
Old 07-09-2013, 04:13 PM
  #2463
Default Shorty battery conversion.
How do you think about shorty battery conversion kit for XB4 like DMX410??
I made a conversion kit.
blurabbit is offline
Old 07-10-2013, 04:26 AM
  #2464
Trader Rating: 16 (100%+)
where can I get metal diff gears for the XB4? thanks
Mullet1 is offline
Old 07-10-2013, 04:50 AM
  #2465
BentKa's Avatar
Just use these part # in Google and find the one with the best price/delivery time
NT1 Metal diff gears: part #335030
Metal pins: part #335080
LW alu. hard coated pins: part #335081
Bent
BentKa is offline
Old 07-10-2013, 07:27 AM
  #2466
Bent
got a question
I bought this and it doesn't seem to work....too tight of a mesh. I only used the gears and pins. Do I use the shims behind the small gears like the plastic ones use?
https://www.amainhobbies.com/advance...335050&x=7&y=8
thanks a BUNCH for your help.
Mullet1 is offline
Old 07-10-2013, 07:35 AM
  #2467
pekow91's Avatar
Trader Rating: 45 (100%+)
Thank you.
pekow91 is offline
Old 07-10-2013, 08:01 AM
  #2468
BentKa's Avatar
got a question
Yes.....you replace plastic with metal and assemble as usual.
The metal gears and pins are a direct replacement for the plastic parts so there's no need to change the shimming.
We've run this for 6+ months now with both the old crown gear and the new upgraded 35T gear.
No issues at all
(I'm assuming the set you bought contains the #335030 gears).
Bent
BentKa is offline
Old 07-10-2013, 09:09 PM
  #2469
pekow91's Avatar
I was thinking about running a Speed Passion 6.5 motor in my XB4. Anyone run these motors a 4wd buggy
pekow91 is offline
Old 07-10-2013, 11:07 PM
  #2470
Z00M's Avatar
Trader Rating: 15 (100%+)
Xray have introduced an updated set of carbon composite diff gears for those needing more peace of mind but not wanting to update to the steel ones.
New part number is 304931 (old number was 304930). Seems it was introduced back in June.
Z00M is offline
Old 07-11-2013, 05:25 AM
  #2471
rraden's Avatar
Trader Rating: 259 (100%+)
I'm currently running a SP 6.5 in my car. Motor is OK but seems to lack torque coming out of the corners. I had to turn up the boost to get it to pull harder. I'm going to put a 6.5 Ballistic in it to see what the difference is.
rraden is offline
Old 07-12-2013, 12:46 AM
  #2472
mental_raycer's Avatar
Default stock 17.5 gearing
I'm planning on experimenting with a solution to the spur gear problem tonight, I tried using the AE spurs and removed one shoulder and reamed out the hole by hand but I found the body reamer can leave a large amount of slop on the hole if you miss your mark, causing the gear to spin off centre.
I'm making up a holder to go on a lathe that will allow quick and easy machining of the hole diameter to 5.9mm and then use the lathe to remove the shoulder, making the spur as nice and neat as possible. its great if you have access to a lathe
mental_raycer is offline
Old 07-12-2013, 02:43 AM
  #2473
Bcholka's Avatar
That is super helpful--Thanks for posting this!!!!
Bcholka is offline
Old 07-12-2013, 03:36 AM
  #2474
savagesam's Avatar
Here is the first few laps of my Xray Xb4 buggy running Nosram 6.5t, Nosram esc, Nosram 5600 55c/110c on Proline at Knox Offroad today.
http://youtu.be/RaSFet6-BVY
savagesam is offline
Old 07-12-2013, 09:05 PM
  #2475
Bcholka's Avatar
What's the problem with the spur gear?? We've had zero issues on indoor high bite clay for months. Am I spose to be worried about something??
Bcholka is offline
