Like Tree39Likes
Old 06-19-2013, 09:50 AM   #2416
Trader Rating: 24 (100%+)
Default wheel Hexes....
I run 2wd associated cars and recently bought and XB4 and love it. I realized however that I cant use my associted wheels on my XB4 because the hexes are not the same. Does anyone know if a company offers a hex that would work on the B4.2 or the XB4 so i can use the same wheels on each car?
Thanks so much.
Justin
gocoogs is offline   Reply With Quote
Old 06-19-2013, 09:54 AM   #2417
joeymdz's Avatar
Send a message via MSN to joeymdz
Thanks so much.
Justin
http://www.petitrc.com/setup/xray/se...exAlternative/
joeymdz is offline   Reply With Quote
Old 06-19-2013, 11:29 AM   #2418
Odin544's Avatar
Trader Rating: 93 (100%+)
Originally Posted by joeymdz View Post
I believe this only works for the rear though?
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 06-19-2013, 12:12 PM   #2419
asc6000's Avatar
Trader Rating: 15 (100%+)
Looks like a rear to me
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 06-19-2013, 01:03 PM   #2420
.AJ.'s Avatar
If SCTE hex's fit then HPI Blitz ones should as well, I had them on my SCTE because they were less than half the price of losi ones
Losi 5ive T - Bartolone G340 - Hitec 1000 & 845 - MIP Shocks & Brakes + loads more.
TLR 8ight E 4.0 - HW Xerun XR8 Plus - Xerun 2250kv G2 - Protek 170t - IP powered
Spektrum DX4R Pro
.AJ. is offline   Reply With Quote
Old 06-19-2013, 01:41 PM   #2421
joeymdz's Avatar
I bought mine used and it came with custom hexes... that's the only thing I found online for the xb4
Old 06-19-2013, 02:41 PM   #2422
Odin544's Avatar
Doh! I meant doesnt work on the front.
TriCitiesRC.com
Old 06-19-2013, 05:12 PM   #2423
Z00M's Avatar
You'd think he wouldn't want to put the B4.2 (2wd) front wheels on his XB4. Unless he is secretly testing the XB2 prototype! ha ha.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 06-19-2013, 05:19 PM   #2424
Z00M's Avatar
Have you tried 3/3 ? pretty interesting.
I tried the 3/3 diffs last night and I agree it was interesting. It introduced a slight on power push at the first application of throttle. It was quite strange and I went back to the stock ackerman position and put harder oil in the rear shocks from what I was running and the car was good. In comparing to the 7/7 diffs I think they offered a little better performance overall on the very low grip track we were running last night. Temps were below 10*C and still some damp patches on the track from recent rain.
Overall, glad I tried it. Something else to have in the kit for when conditions change.
XRAY XB4
Old 06-19-2013, 10:56 PM   #2425
asc6000's Avatar
Like I said I am new to gear diffs so I appreciate your input as I am still learning how to tune them to work with my style of driving. Our track is low grip (indoor clay so it is consistent) and I do indeed run slightly overdamped shocks because the standard oils made the car a bit sensitive. Iv'e since gone back up some in diff oil weight. Unfortunately due to my current life I don't race and can only get to the track for an hour at a time so when I do go I tend spend my time concentrating on my driving rather than tuning. Makes it difficult to get a firm opinion on things sometimes.
Ayrton Senna
Old 06-22-2013, 05:46 PM   #2426
joeymdz's Avatar
I'm new to 4wd but good lord this car rocks. Bought the car used and this thing is so easy to drive!
Just wondering if there's a set up for a low/loamy track set up? I just want to compare set ups. I saw rschockly's but that's for clay
I haven't taken my car apart yet but the only think I know the front different is 9k and the rear is 1k. Other drivers like my set up so cudos to the previous owner
Old 06-25-2013, 09:39 AM   #2427
Trader Rating: 29 (100%+)
what is the best way to clean the oil from the gear diffs?
thanks
ronzo is offline   Reply With Quote
Old 06-25-2013, 10:05 AM   #2428
jhautz's Avatar
Trader Rating: 85 (100%+)
thanks
Don't clean the oil. Just put in new oil.
Kidding aside. Just dump it. Pull the small gears and cross pin out and let the diff sit draining on a paper towel or something for a few minutes. The little bit of residue sticking to the inside isn't a big deal. Just reassemble after the old oil drains off and refill with fresh oil.
jhautz is offline   Reply With Quote
Old 06-25-2013, 10:19 AM   #2429
aloksatoor's Avatar
Trader Rating: 42 (100%+)
blast the cup and the ring gear with compressed air hold a towel under the part so the oil does not makea mess.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 06-25-2013, 12:18 PM   #2430
Trader Rating: 1069 (100%+)
Couple quick questions:
Do the 12mm hexes have the right offset if used on the front?
Are most using the metal gears from the NT1 in the gear diffs or the V2s?
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
