Like Tree36Likes
Old 06-06-2013, 06:57 AM   #2356
.AJ.'s Avatar
Another vote for the LRP X20, I went for the 7.5t and run timing, loads of torque and butter smooth
Losi 5ive T - Bartolone G340 - Hitec 1000 & 845 - MIP Shocks & Brakes + loads more.
TLR 8ight E 4.0 - HW Xerun XR8 Plus - Xerun 2250kv G2 - Protek 170t - IP powered
Spektrum DX4R Pro
.AJ. is offline   Reply With Quote
Old 06-06-2013, 03:28 PM   #2357
silvalis's Avatar
Trader Rating: 29 (100%+)
That's the first time I've heard someone describe the X20 as smooth
I'll +1 it as well. I'm going back to it when I stop running stock.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 06-06-2013, 11:09 PM   #2358
.AJ.'s Avatar
Compared to the 6.5 the 7.5 is a completely different beast, I was surprised myself
Spektrum DX4R Pro
Old 06-08-2013, 05:50 AM   #2359
silvalis's Avatar
Stock titles TQ & Win
http://forum.teamxray.com/xform/inde...D=96&setup=xb4
Old 06-08-2013, 05:51 AM   #2360
silvalis's Avatar
Double
Old 06-08-2013, 08:17 AM   #2361
Gearing 30/69?
farm is offline   Reply With Quote
Old 06-08-2013, 02:05 PM   #2362
silvalis's Avatar
17.5 blinky
Old 06-09-2013, 06:13 AM   #2363
favo's Avatar
Default SHIM FOR 1/10 OFF-ROAD ALU SET-UP - XRAY XB4
SHIM FOR 1/10 OFF-ROAD ALU SET-UP - XRAY XB4 Part # 108927
Could some one please post a photo or a link to where these are used please ?
The #108928 go on the rear axles as spacer for when you use the set up station.
Thank you so much for your help.........
favo is offline   Reply With Quote
Old 06-11-2013, 02:28 PM   #2364
Trader Rating: 31 (97%+)
Quick question about the spur gear>>>
mine seems to have a little wiggle room back n fourth, is this supposed to be or should it be locked with zero wiggle room?
thx
Jay
Jason Collins
Losi 22 3.0 & 22-4
Friday night @ Island Raceway & Hobby
Jay rb5 is offline   Reply With Quote
Old 06-11-2013, 02:35 PM   #2365
silvalis's Avatar
thx
Jay
a little wiggle room is good.
Old 06-11-2013, 04:29 PM   #2366
Z00M's Avatar
Trader Rating: 15 (100%+)
You need some wiggle room because of the chassis flex system.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 06-12-2013, 06:09 PM   #2367
ok, thanks. i thought something was wrong.
Jason Collins
Losi 22 3.0 & 22-4
Old 06-12-2013, 07:59 PM   #2368
asc6000's Avatar
the motor mount and spur gear are held by four bolts in the top and 4 on the bottom along with two more through the chassis all in one spot in between the flex holes... seems to me there shouldn't be any flex directly in that area. I run mine like all the rest and haven't seen any indication that more than normal is needed.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 06-12-2013, 11:48 PM   #2369
I've broken two rear right A-arms. One was a very hard full throttle tumble, the other was a pipe connector down the straight. Overall the car has been very durable.
nickmig is offline   Reply With Quote
Old 06-13-2013, 12:42 AM   #2370
.AJ.'s Avatar
Between me and a mate we have broken
1 Front shock tower
1 FF hinge pin brace
1 C hub
1 Knuckle
1 Spur
1 Wing Mount
And few stock bearings have fallen to bits
Not bad for 3 months hard running, but all output cups and drive pins are starting to show serious wear which isnt great tho
Spektrum DX4R Pro
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
