Like Tree52Likes
Old 05-14-2013, 08:58 PM   #2266
Suspended
Default xb4 weigh
i just put weight under the battery.
poorboy racing is offline   Reply With Quote
Old 05-14-2013, 11:15 PM   #2267
aloksatoor's Avatar
Trader Rating: 42 (100%+)
here's mine
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-15-2013, 02:15 AM   #2268
.AJ.'s Avatar
I made my own, giving 3 weight options
Losi 5ive T - Bartolone G340 - Hitec 1000 & 845 - MIP Shocks & Brakes + loads more.
TLR 8ight E 4.0 - HW Xerun XR8 Plus - Xerun 2250kv G2 - Protek 170t - IP powered
Spektrum DX4R Pro
.AJ. is offline   Reply With Quote
Old 05-15-2013, 07:04 AM   #2269
asc6000's Avatar
Trader Rating: 15 (100%+)
boggles my mind how much weight you guys add on
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 05-15-2013, 08:33 AM   #2270
Odin544's Avatar
Trader Rating: 93 (100%+)
+10000000000
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 05-15-2013, 12:30 PM   #2271
I've been adding zero weight. Also running on Astroturf mainly. My rear end is planted. It's all about the setup.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 05-15-2013, 01:08 PM   #2272
aloksatoor's Avatar
You guys should have seen my mid motor cougar on dirt . Its not all about the setup. Try it you won't hate it (on dirt). Takes away none of the TC handling but still can drive it like an ebuggy if you need to (super aggressive on brakes in turns and jumps). Without rear weights thing was nose heavy.
Old 05-16-2013, 12:50 AM   #2273
.AJ.'s Avatar
It's just another tuneing option and at my local astro track the weights are a god send in the wet and help lock in the rear end
Spektrum DX4R Pro
Old 05-16-2013, 01:16 AM   #2274
aloksatoor's Avatar
Yeah I just cannot afford super soft holeshots every heat or two at my track. So make do with the soft compounds, grip sauce and weight at big races I can understand 1 heat tires for max grip but its too much for club race nights.
Old 05-16-2013, 12:01 PM   #2275
kenny lutz's Avatar
Trader Rating: 36 (100%+)
Attachment 1068430
Where did u get the brass at and how thick it is
Kyosho Rb6.6- Maclan mmax - Fantom 17.5
Kyosho Zx6.6- Maclan mmax - Fantom 13.5
Airtronics M12 - Auer Ace Hardware - Schelle
kenny lutz is offline   Reply With Quote
Old 05-16-2013, 06:27 PM   #2276
aloksatoor's Avatar
I get my brass from the local ace hardware. They sell 0.091 sheets and thinner there around 4 inches accross and 6 to 10 long for about 10 bucks.
Old 05-16-2013, 06:57 PM   #2277
kenny lutz's Avatar
I just put about 45 grams under my batteries so we will see what happens. I'm also switching to the avid pistons and 3 2 in the diffs
Old 05-16-2013, 07:00 PM   #2278
aloksatoor's Avatar
Let me know how that works. Thats almost like running a ball diff the weights. What kind of track is it?
Old 05-16-2013, 07:40 PM   #2279
kenny lutz's Avatar
Medium to low traction and I will let you know how it works
Old 05-18-2013, 11:55 AM   #2280
.AJ.'s Avatar
I was getting fed up with losing body clips when swapping packs, so I've converted over to thumb nuts
I just used M3 x 33mm button heads locked down with a washer and lock nut, the thumb nuts are from Tresrey and are ment for the DEX210
Spektrum DX4R Pro
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
bprc10T3
