Like Tree36Likes
Old 05-04-2013, 08:53 AM   #2221
Yeah, That makes sense re: noise... I did use all the correct weight oils and Hudy graphite diff grease on the diffs... When I lift it off the ground and pull the throttle it's incredibly fast... The tires actually started to come unglued... but as soon as I set it on the ground and pull the throttle, its a dog...
Tekno EB48.2// Viper VTX8// Viper 1900kv//
Thereallion is offline   Reply With Quote
Old 05-04-2013, 10:28 AM   #2222
Odin544's Avatar
Trader Rating: 93 (100%+)
You mentioned you had an Orion RS pro. I assume you meant Tekin RS Pro? If you move the motor so the pinion is not in contact with the spur gear does the car roll freely? If you are running the RS Pro what are your esc settings?
I run a Tekin RS Pro and Gen2 6.5. I'm running a 21 tooth pinion. So your gearing shouldn't be that far off. But that is dictated by track size. I run on a large outdoor 1/8 scale track. That would be way too much motor on a smaller indoor track like asc6000 runs on.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 05-04-2013, 10:59 AM   #2223
Sorry, It's a Team Orion Vortex R10 Pro Brushless ESC (160A, 2-3S). I will try to to roll it when I get home...
Old 05-04-2013, 11:39 AM   #2224
Trader Rating: 31 (97%+)
Hey All,
Just a couple quick questions as I start my build:
- do most use a low profile servo? or does the standard fit ok?
- does the V2 upgrade come along with the new kits now?
- any solutions to what I read about leaking shocks?
also any set up tips would be very helpful:
I will be running on a mid size indoor clay track with med. bite
i'm using a LRP Flow with a tekin Gen 2 7.5
Thanks in advance
Jay
Jason Collins
Losi 22 3.0 & 22-4
Friday night @ Island Raceway & Hobby
Jay rb5 is offline   Reply With Quote
Old 05-04-2013, 01:56 PM   #2225
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Jay rb5 View Post
Hey All,
Thanks in advance
Jay
standard servos fit fine, depends on the size of your esc/bec/rx etc (I used a full sized servo and moved it backward and still have plenty of room). The kits by now I think would have the upgrades, I'm still running 2 month old stock pieces. The shocks need to seat in, or add o-rings. Box setup is a good start. or the link to petit setups I posted earlier. Get it, run it, love it.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 05-04-2013, 02:05 PM   #2226
asc6000's Avatar
Our track is 65x75, I like a little less motor, always have. When racing of course, when running for fun (on a track) I love to power up and air it out. This car especially seems to like it.
Ayrton Senna
Old 05-04-2013, 05:29 PM   #2227
nerdling's Avatar
Where do you add the o-rings? I'm getting a lot of discharge between the cap and the body. This rebuild I've done the shocks up extra tight, if this does not work I'm thinking of trying the diagrams from the T4 Shocks.
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 05-04-2013, 05:52 PM   #2228
Odin544's Avatar
http://www.teamxray.com/xb4/download..._press_v02.pdf
see the second page.
TriCitiesRC.com
Old 05-04-2013, 08:34 PM   #2229
When I move the pinion away from the spur the car rolls freely... I backed off considerably on the slipper clutch. I did it the way thats directed in the manual but i doesn't appear to be doing anything, in other words the spring seems to be the same distance as when I built it 5.5 mm.
Old 05-05-2013, 09:08 PM   #2230
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Will the kyosho/TLR/AE big bore pistons directly fit? I want to try out the 1.6 and 1.7 mm 2 hole pistons on many setup sheets. I really don't want to drill out my own ones would prefer factory. I think avid was about to release a set for the xb4 any ETA on that?
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-05-2013, 09:56 PM   #2231
silvalis's Avatar
Trader Rating: 29 (100%+)
The K pistons are too thick. Not sure about the others.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 05-05-2013, 10:07 PM   #2232
aloksatoor's Avatar
Thanks. What about the tapered gheas
Old 05-05-2013, 10:16 PM   #2233
silvalis's Avatar
Not sure, never tried em. The Avid and K 5H BB pistons need to be about half a mm thinner so you can get the c-clip on. If the Gheas are the same thickness...
Old 05-06-2013, 07:14 AM   #2234
aloksatoor's Avatar
cool thanks guess I have to get the drill bits out on my piston tree from xray
Old 05-06-2013, 08:42 AM   #2235
locked's Avatar
Hey All,
Thanks in advance
Jay
I'm using a Savox 1251MG low profile servo in my car. Works fine so far.
To Thereallion. I'm also running an Orion R10 ESC and a 6.5 motor (mine is a ReVtech) I believe I have a 21 tooth pinion on it as well. No issues with speed. If anything, it might be a tad too fast Anyway, maybe there's an issue with your sensor wire? Try a different one. If it's still an issue, try plugging into the other sensor port on the ESC. If it's still an issue, try another motor. Maybe you got a lemon. One of my 5.5 motors has the weakest rotor I've ever felt. I have an 8.5 that is much faster than that 5.5. I'd also try re-calibrating the ESC.
locked is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
