Like Tree38Likes
Old 04-24-2013, 11:38 AM   #2161
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
What u see in the picture looks to be a tape of some kind or vinyl .
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 04-24-2013, 03:56 PM   #2162
Odin544's Avatar
Trader Rating: 93 (100%+)
Definitely a wrap. You can see the overlapping sections of it. There is a guy who posted earlier in the thread that will do custom wraps. Maybe he can do something similar for you.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 04-25-2013, 02:27 AM   #2163
memyselfandI's Avatar
Just thought I would lee people know that we found in testing that reducing the rear anti squat really locks the rear end in on this car on slippery tracks so if you guys are finding a general lack of rear grip try reducing it from 3 degrees to 2.5
Carisma Racing Australia
Modelflight.com.au
Team AKA
Ryper Hobbies
memyselfandI is offline   Reply With Quote
Old 04-25-2013, 05:22 AM   #2164
Rear grip is my problem. I own a B44.2 as well, but bought the XB4 as my next move up. But so far, for me, I havent had much luck with it. The B44.2 is so hooked up with stock settings, it is a joy to drive. Despite many attempts, the XB4, though a ROCKET, can't keep the rear planted, even on the straight. It does sound like less anti squat may help. Did you take the angle off the FR or add angle to the RR to reduce anti squat? I am not the best at setting up cars - I do rely on online setups, local racer input, etc. so your advice helps! No local racers for the XB4, though. I truly love the quality of this car so hopefully I can work out the rear end grip deal. I am blown away by its almost friction free drivetrain.
I look forward to hearing back.
Mark
mlinder is offline   Reply With Quote
Old 04-25-2013, 06:44 AM   #2165
wraps for almost all bodies
http://rctagz.com/body_wraps.html
Gorden
light is offline   Reply With Quote
Old 04-25-2013, 08:22 AM   #2166
seth556's Avatar
Trader Rating: 42 (100%+)
Mark
If you lower the rf you should have more rear roll (less rotation) than if you raise the rr. You'll get the same amount of anti-squat but the arm will sit farther up (more distance from it and the bottom of the chassis) causing less roll on that end of the car, when you lower the RF bushing.
I think I got that right, but I know on my touring car if I raise up where my rear arms mount it'll roll less on the rear and I'll get more rotation and vice versa. Although it might be a pretty small change on an off road car.
Also try adding just a little bit of rear toe, last time I was at the track I tried 3.5* and it seemed to calm the car down some and make it easier to drive.
seth556 is offline   Reply With Quote
Old 04-25-2013, 08:32 AM   #2167
kenny lutz's Avatar
here is my new body and also took the tekin rs out it was getting a little hotter then i would like it to and put a reventon pro in it to try tonight.
Kyosho Rb6.6- Maclan mmax - Fantom 17.5
Kyosho Zx6.6- Maclan mmax - Fantom 13.5
Airtronics M12 - Auer Ace Hardware - Schelle
kenny lutz is offline   Reply With Quote
Old 04-25-2013, 08:56 AM   #2168
Frank L's Avatar
Trader Rating: 148 (100%+)
Mark
There are a couple ways to increase rear traction. Here's what I would try in order. Try them 1 at a time and see which you like best.
Lighter rear swaybar
More rear toe
Softer rear spring
Lutz nice looking ride
Old 04-25-2013, 10:16 AM   #2169
kenny lutz's Avatar
More rear toe
Softer rear spring
Thank you
Old 04-25-2013, 01:56 PM   #2170
Mark
Mark , what track surface we talking about?
farm is offline   Reply With Quote
Old 04-25-2013, 02:48 PM   #2171
Farm,
Indoor clay, medium to high traction. I have tried the stock clay setup, followed by stiffer front sway bar, progressive springs, the 1 dot rear springs with lighter oil, front 1.6 piston with 1.7 rear pistons (like my B44.2) with thicker oil. I even took the rear sway bar off once. The rear end skates down the straights, will swing the rear end out on the sweeper, etc. barcode gold fronts, HB Beams and barcode gold rears.
It's as if the rear end is spinning so quickly it can't grip. My B44.2 handles great. Same track, same more 6.5t), geared 18/81. But boy it is fast. For sure! I even tried a 8.5t, thinking 8 needed to take it down, but same results. I'm a bit perplexed, but I know once I figure it out, it will be a keeper.
Mark
Old 04-26-2013, 02:38 AM   #2172
silvalis's Avatar
Trader Rating: 29 (100%+)
I had something like that at first, but I'm on an outdoor loose hard pack surface. Went to 7/7 diffs and no rollbars
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 04-26-2013, 04:12 AM   #2173
nerdling's Avatar
Hi all, I raced my XB4 for the first time last weekend. Really impressed with the car, kit settings aside from the chassis flex (max flex). The track was very low grip and bumpy with an assortment of jumps. Motor was an Nosram 6.5 with a v2 in blinky mode. The car was really balanced and easy to drive.
My question is, how often are people finding they need to refill the shocks?
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 04-26-2013, 06:45 AM   #2174
mjk1210's Avatar
not very often, but it depends on how badly you land jumps. If you downside the jumps properly they seem to hold up pretty well. flat landing the jumps will probably push some oil out.
Speed Passion USA - speedpassion.net
Leisure Hours Hobbies & Raceway - leisurehoursraceway.com
"Watch the quad. Watch the quad! ...SHA-BAM!"
mjk1210 is offline   Reply With Quote
Old 04-26-2013, 10:32 AM   #2175
Peakki's Avatar
Farm,
Mark
How much do your saddles weigh? If they are much below 290-300g you maybe should add weight to the rear. Also maybe try to move the electrics towards the rear.
And have you tried shorter rear wheelbase, so that the 2mm shim is behind the hub?
Destiny&V-Dezign 1:12- Sanwa M12s - Xray XB4 2016 - Xray XB2 DE - HW XR10Pro & Team Orion R10.1 Pro & Sanwa Super Vortex Zero Gen2- Team Orion Vortex & Muchmore & Reedy BL motors - Sanwa & Highest & Sav÷x servos
Peakki is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
