Like Tree39Likes
Old 04-14-2013, 12:05 AM   #2116
Trader Rating: 24 (100%+)
that PN was the alloy shock caps. is there an o-ring on its own?
" It takes a lot of things to go right, but only one thing to go wrong to lose a race "
HEI | NBHC.com | Model Engines | World Hobbies
Jarred King is offline   Reply With Quote
Old 04-14-2013, 12:43 AM   #2117
silvalis's Avatar
Trader Rating: 29 (100%+)
970120 are the orings
http://www.teamxray.com/teamxray/pro...p?prod_id=4546
The caps are 368051
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 04-14-2013, 02:13 AM   #2118
do you mean? 970121 (12x1x1.6)
970120 doesn't come up anywhere as an o-ring
Old 04-14-2013, 02:33 AM   #2119
silvalis's Avatar
nope. 970120.
http://www.teamxray.com/teamxray/new...0Gear%2084T/48
Old 04-14-2013, 02:46 AM   #2120
neallewis's Avatar
Originally Posted by Jarred King View Post
where do u get the alloy caps?
MB Models have them, delivery world-wide:
http://www.rccarshop.co.uk/index.php...nt-hole-2.html
YZ-2 | B-MAX4III | 2x B-MAX2 MR | Cougar KF | RC10 | RC10WC | Supastox GT
neallewis is offline   Reply With Quote
Old 04-14-2013, 08:44 AM   #2121
Default My Stock 17.5 XB4
My Stock 17.5 XB4
XRAY XB4 - Hobbywing Xerun 120a V2.1/Team Power 17.5t
KYOSHO RB6 - VTX10R Black Series/Team Power 17.5t
WeekendRCDevil is offline   Reply With Quote
Old 04-14-2013, 11:57 AM   #2122
Default Receiver too large to fit in provided space.
I was wondering if anyone else has ran into this problem and what they did as an alternative. I have an XB4 with a Futaba R2104GF receiver. The receiver is too large to fit into the space provided due to the battery wire retainer posts. Anyone else run into this problem? If so, where did you end up mounting the receiver? Thanks!
Tekno EB48.2// Viper VTX8// Viper 1900kv//
Thereallion is offline   Reply With Quote
Old 04-14-2013, 01:17 PM   #2123
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
I got a solder iron with a wide flat chisel tip and melted the molded wire retainer out of the bottom so u could arrange my electronics better it worked great
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 04-14-2013, 01:49 PM   #2124
Odin544's Avatar
Trader Rating: 93 (100%+)
cut the wire retainer post off. problem solved.
Or get this rx. http://www.amainhobbies.com/product_...Micro-Receiver
I know for a fact it fits.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 04-14-2013, 02:28 PM   #2125
Crawlin's Avatar
Trader Rating: 22 (100%+)
thats what I did, ordered the micro receiver
then i had the regular for a different vehicle
Crawlin is offline   Reply With Quote
Old 04-14-2013, 02:58 PM   #2126
Thanks! Any chance you guys have pics of your wiring configuration. trying to make it as tidy/clean as possible... I have an Team Orion RX10Pro, but it looks as though I'm going to have to bypass the wire retainer because they seem to be in the way of driveline components due to the configuration of the Orion ESC. Any pics or tips would be greatly appreciated
Old 04-15-2013, 01:05 AM   #2127
Peakki's Avatar
http://www.petitrc.com/setup/xray/se...ctronicsSetup/
There are many Orion escs in those pictures.
You can also have more space by removing the plastic cover around the capacitors and shrink wrapping them after that.
You can re-solder your wires so that the wires go down from the esc. That way you can use the wire retainer more easily.
Destiny&V-Dezign 1:12- Sanwa M12s - Xray XB4 2016 - Xray XB2 DE - HW XR10Pro & Team Orion R10.1 Pro & Sanwa Super Vortex Zero Gen2- Team Orion Vortex & Muchmore & Reedy BL motors - Sanwa & Highest & Savöx servos
Peakki is offline   Reply With Quote
Old 04-15-2013, 10:00 AM   #2128
Default setup
Hey ,
i will buy xb4 this week i hope.
Tell me one thing.
Is a 1:10 http://www.yeahracing.com/catalog/ye...ad-p-3152.html setup system adoptable to 1:10 offroad, by modification?
Adoptable to use with xb4 ofc.
Maybe HUDY setup is from off to onroad or vice versa
http://www.sklep.rcracing.pl/product...16&language=en
farm is offline   Reply With Quote
Old 04-15-2013, 10:33 AM   #2129
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by farm View Post
Hey ,
Tell me one thing.
Both of those are for 1/10th using 5mm axles, the hole in the side plate determines the maximum axle size.
Smaller axles can be used with spacers/etc.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 04-15-2013, 05:38 PM   #2130
neallewis's Avatar
My XB4 in action at my local indoor club:
https://www.youtube.com/watch?v=5fxKROVNXM4
+ YouTube Video
I'm the blue/green car, all the others are B44.1/B44.2.
Also this earlier final running with 2wd cars, as I was running my Bmax2 in qualifying that night, but ran my XB4 in the final and got a bump up to the A.
https://www.youtube.com/watch?v=d-z16zzU5Ds
+ YouTube Video
This super slippy rubber floor has been causing me some issues with the rear rotation, but think I have it dialled now. Using the new Ralls Racing rear tower, with extra wide camber link holes, which really helps with the camber change as the car rolls. Rear grip is far more than with the stock tower.
I've also added 40g weight under each lipo.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
