Like Tree36Likes
Old 04-11-2013, 07:16 AM   #2086
H0LESH0T's Avatar
Hudy have released this aluminum shim for the XB4 which fits on the rear wheel axle, and the set-up system leans against the shim. For use with XRAY XB4 or any off-road car on which the set-up system cannot be inserted on the non-threaded part. The set-up system will then sit properly on the threaded area of rear wheel axles only.
H0LESH0T is offline   Reply With Quote
Old 04-11-2013, 03:20 PM   #2087
Trader Rating: 24 (100%+)
Originally Posted by jlfx car audio View Post
For me this is why I buy cray they r very reliable /HD in kit form .
May want to grab a few sway bars and shock oils but the kit springs will give u 95% of what anyone needs to be in the Amain with a good driver behind the wheel.
I have 2 in stock form and I've played with oils and shock location and pretty much just drive it.
Now if u race indoor on nice smooth clay springs from avid might get u set up a little better .
But for a outdoor track the stock springs will/does do great
thanks, that's great to hear.
So no one has even bothered getting the optional springs ? is caster adjustable out of the box or do u need the optional caster blocks?
what about rims....how can I get B44 rims to fit lol. 10mm front hex and 12mm rear.
" It takes a lot of things to go right, but only one thing to go wrong to lose a race "
HEI | NBHC.com | Model Engines | World Hobbies
Jarred King is offline   Reply With Quote
Old 04-11-2013, 04:06 PM   #2088
Z00M's Avatar
Trader Rating: 15 (100%+)
Jarred, yes we have bought the optional springs and they do get used depending on the track conditions. I've run 2 dots all around, 3 dots all around and also the progressive springs all to good effect.
Fitting the B44 hexes is going to be a challenge as there is no direct fit part for the front. The rear you can use if you drill out the 12mm hexes and space them correctly.
The 6 degree caster blocks are an option if adjusting caster at the hub side, however the front kickup is adjustable to give similar results.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 04-11-2013, 04:10 PM   #2089
Thanks mate, much appreciated.
A lot of people saying the car is dialled from the box springs, wouldn't mind getting some different types tho.
Old 04-11-2013, 04:12 PM   #2090
aloksatoor's Avatar
Trader Rating: 42 (100%+)
From my understanding, the kickup at the chassis does not affect off power steering much but at the blocks it does. Anyhow the progressives are working better for me 2 stripes I think. Stock pistons and a little heavier oils in shocks.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 04-11-2013, 04:12 PM   #2091
also, is the more dots the harder for springs?
Old 04-11-2013, 04:14 PM   #2092
Odin544's Avatar
Trader Rating: 93 (100%+)
I have the progressive springs as well. I tried them with a few different oils and have went back to the stock springs. I plan to try the progressives again though with some different pistons this weekend. BTW I run on an outdoor 1/8 sized clay track.
The rear is the easy one to convert to 12mm. You just use the aluminum clamping hexes from the Losi Ten-SCTE (losb3493). It's posted a few pages back. As far as I know no one has a solution to the front hexes though.
Any shim or spacer will work. I have an assortment of shims specifically for this purpose for use with my hudy setup station.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 04-11-2013, 04:16 PM   #2093
ill see if I can get a AE 10mm front hex to fit, cant see it being to much of a problem
Old 04-11-2013, 04:44 PM   #2094
Odin544's Avatar
I'm sure you could have something made to make it work. Most people are looking for something thats just bolt on though.
TriCitiesRC.com
Old 04-11-2013, 08:37 PM   #2095
caguilar4's Avatar
Sooo has anyone snapped a rear cvd? I just snapped one of them, right behind the hex, where the pin is actually.
Must've been pretty worn, as i slid my car and the wheel came off, with the cvd end and wheelnut still attached!
RB6 | XB4 | SC10.2 | MBX6 | RC8.2e
caguilar4 is offline   Reply With Quote
Old 04-11-2013, 09:06 PM   #2096
Odin544's Avatar
Haven't heard of anyone doing that. Are you keeping them properly cleaned and lubed?
TriCitiesRC.com
Old 04-11-2013, 09:36 PM   #2097
B00t13g's Avatar
Does anyone have any tips to get the xb4 to square up better on power? I'm thinking diffs I'm at 7-5 now.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 04-12-2013, 02:20 AM   #2098
Peakki's Avatar
"New" ideas to suspension.
Well, indoor carpet racing is something else than racing on clay...
Destiny&V-Dezign 1:12- Sanwa M12s - Xray XB4 2016 - Xray XB2 DE - HW XR10Pro & Team Orion R10.1 Pro & Sanwa Super Vortex Zero Gen2- Team Orion Vortex & Muchmore & Reedy BL motors - Sanwa & Highest & Sav÷x servos
Peakki is offline   Reply With Quote
Old 04-12-2013, 03:49 AM   #2099
BentKa's Avatar
That's the 2WD prototype they have been testing since the last EOS round.
From the Xray Facebook page:
Juraj Hudy, the XRAY chief designer:
"At the last EOS race, less than 1 month ago, I got an idea to modify the XB4 into a 2WD version so I could use the track time and drive in 2WD class as well. The quick modifications I have made at the race amazed me and this crazy idea stayed in my mind. After coming back to the factory the R&D team has worked extremely hard for several weeks and the production was even more busy with all the prototypes to be made, we have even designed and produced few moulds in a new record time - just incredible what our team is able to achieve when is motivated and excited.
We have quickly designed a very first 2WD prototype based on the XB4 platform and in just last few weeks got the first prototypes ready to test. To be able to test the prototypes we have built within few days own indoor track and had Reno, Martin and Jirka to come over. For the last few days the racing team has worked very hard from early morning till very late night to build the prototypes and to get some first hand-on experiences and to have some basics to start building on for the next development. I am really excited about this new project and I have been very proud of what we have achieved in just few weeks. We are ready to hit the tracks with the very first XRAY XB2 prototype."
http://www.facebook.com/TeamXray/posts/4809245275287
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 04-12-2013, 04:06 AM   #2100
H0LESH0T's Avatar
Originally Posted by BentKa View Post
That's the 2WD prototype the have been testing since the last EOS round.
Bent
Isn't that a diff in the front? Although there doesn't seem to be any driveshafts.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
