Like Tree45Likes
Old 03-27-2013, 03:18 PM   #1951
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by RShockley View Post
Running the +0.75 hex in the rear will cause the rear to be looser. If you run the standard or even the -0.75 hex it will gain a little bit of rear traction and not feel so loose in the rear.
I did not notice much difference though. I run rear +.75 as well. I think it will be more pronounced if you move the rear hinge pins outside which changes roll center. I do this on my nitro cars as well. My xb9e I run +0 hubs (I can control the throttle much better on electric thats why) but the nitro xb9 has +2 and its a lot more stable cornering than the electric without the extra width.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 03-27-2013, 03:31 PM   #1952
Odin544's Avatar
Trader Rating: 93 (100%+)
Curious how many people are running chassis protectors? This is the first time I've had a car with an aluminum chassis. I ran a protector on it the first time out but its already become a hassle. I run on an outdoor clay track. Is it just not worth worrying about? Do the aluminum chassis hold up pretty well?
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 03-27-2013, 04:23 PM   #1953
aloksatoor's Avatar
Don't run a protector. With 4wd running such low ride heights already, its just gonna muck up your setup if you copied a pro setup. Wear is not very high the xray aluminums the same grade as their 1/8 buggy so its really tough. Mine only shows minimal scuffing at the kickup area and no scratches. Track was indoor clean clay though.
Old 03-27-2013, 04:30 PM   #1954
+1. I've gone to +.75 front and -.75 rear. It really took the edginess out of the car.
losi b is offline   Reply With Quote
Old 03-27-2013, 05:23 PM   #1955
Originally Posted by silvalis View Post
Went to 7/7 diffs last night and the buggy felt fantastic. Much more controlled and the rear was a bit more locked in on a loose wet track. Now I just need to figure out my rear shock setup. 30wt losi/6x1.2/1 dot springs bounces around a bit too much.
Tried a 17.5 blinky setup too. kimborough spur, AE pads at 69/30 was pretty good and drops right in with no issues, although temps are high.
I'm running 17.5 blinky as well. 75/32 and it seems to run fine!
Interesting about the diff oils - I'll give it a shot as I have rear traction issues
I use stuff.
Hars is offline   Reply With Quote
Old 03-27-2013, 05:29 PM   #1956
Odin544's Avatar
stormerhobbies has the aluminum shock caps in stock if anyone is interested.
TriCitiesRC.com
Old 03-27-2013, 06:26 PM   #1957
Boz
Trader Rating: 23 (100%+)
Originally Posted by mlinder View Post
Tim,
My setup is pretty much stock. It is very quick, but "nervous" compared to the Associated B44.2 that I own as well. We run on a hard packed clay surface that has medium to high traction and is watered lightly a couple times throughout the day. It feels that the car is stiff, as it does bounce a bit, and the rear end is always kind of loose. My diff oils are 7 front, 5 rear. I have tried lighter shock oils, but still the 3 hole pistons. My latest oils were 32/27.5 F/R. I widened the rear end .75 per side.
I admit my setup skills are lacking. Got spoiled with the B44.2 which is easy to setup. I simply always wanted an xray kit, since they seem like super quality. It was an excellent build, but just trying to get that suspension dialed in. My next idea is to move the rear lower shock mount to the inner hole location.
I ran both cars last night. The xray was a handful for me. Both car run 6.5T motors, but the xray seemed much quicker, probably due to the low drag drivetrain. Just lacking keeping the tires firmly planted to the clay.
It's a keeper for sure. So any setup tips are welcome and would be gratefully received.
Mark
lift your rear diff oil to 7.
A few question
what 3 hole pistons are you using and brand of shock oil and air temperature.
I run on a similar surface, you can find my setup on the xray site. Just do not view them in the pdf format. Some of the values change (ackermann, offset and caster block setting).
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 03-27-2013, 06:26 PM   #1958
Trader Rating: 55 (100%+)
Shows them as vented. Is there a bladder in kit?
Jamison R is offline   Reply With Quote
Old 03-27-2013, 06:43 PM   #1959
Boz
Just keep dropping your oils each run until you feel it's right. You may only be 2.5-5wt out. With each drop in oils put the 2 dot spring back on again.
Are you do the Australian Nats next week?
Do you have to drill out the kimborough spur to get them to fit?
Chris Bozich
Xray XB8 XB4 XB2
Old 03-27-2013, 07:23 PM   #1960
Odin544's Avatar
From my understanding, no. They are similar to the AE bleeder caps. Just a screw in the cap for bleeding out excess oil and getting the rebound you want. I dont have them and cant justify the cost right now. The stock ones don't leak on mine so no reason for me to change.
TriCitiesRC.com
Old 03-27-2013, 07:24 PM   #1961
A few question
Chris,
I am using the 1.3 kit pistons, associated oil. Air temp probably low/mid 60's
I will try 7k diff oil
Thanks!
Mark
mlinder is offline   Reply With Quote
Old 03-27-2013, 08:15 PM   #1962
Chris,
Moving the shocks to the inside arm location requires adding another shim limiter under the pistons, correct?
Old 03-27-2013, 08:58 PM   #1963
Tim Garland's Avatar
Tim,
I have seen you racing your XB4 on You Tube. You seem to have a good setup for your car.
I am still working on the setup of mine for hard pack clay.
Would you be willing to share your current setup?
Thanks!
Mark
I'll try and get that posted for you Mark, I've been so busy painting I keep forgetting lol.
RacePro Hobbies
RadioActive RC Raceway
Tim Garland is offline   Reply With Quote
Old 03-28-2013, 12:41 AM   #1964
Hello,
could you guys suggest engine for xb4, indoor carpet track with
class : modified
im going for ESC+eng : viper, novak, Team orion or SP depends on avaiablility.
farm is offline   Reply With Quote
Old 03-28-2013, 01:12 AM   #1965
Odin544's Avatar
Originally Posted by farm View Post
Hello,
class : modified
Attachment 1049349
That's a pretty big track. I'd probably go with a 6.5 or so. Just depends on your skill though. If you are newer you may even go with an 8.5.
TriCitiesRC.com
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
