Like Tree38Likes
Old 03-21-2013, 03:59 PM   #1906
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by BentKa View Post
Metal bushings with plastic sleeves.......so metal to plastic
Bent
Same as big brother XB8-9 series...
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 03-21-2013, 04:36 PM   #1907
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by aloksatoor View Post
Did you try the progressives with the stock pistons/oils(+25 on stock wts)? I loved them on our indoor track. I stopped tweaking the car too much its too good with the right tires but our winter series is over now so will see how she does outdoors in looser conditions.
yes I did run progressives with stock pistons and regular oils and it was better than stock on the faster rougher sections, it seemed to keep the dynamic ride height "up" without raising the static ride height. The 6/thin is simply to handle the impact of big air landings. I am not actively racing right now just running for fun so the big airs really shouldn't be happening in a race. With the track rebuild I'll be running 2 or 3 holes monday night. I agree on the tweaking too much thing. I'm far more concerned with my driving than my setup. Finding a split second here and there is worth nothing if you just throw it away with mistakes.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 03-21-2013, 04:54 PM   #1908
BentKa's Avatar
Almost........same principle though.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 03-21-2013, 05:03 PM   #1909
Rubber o-rings in size 12x1mm suggested to use for XRAY XB4 shock absorbers in the upper cap to prevent the shocks from leaking.
I'm hereby suggesting they include these with any kits sold in the future.
"Option part".
I use stuff.
Hars is offline   Reply With Quote
Old 03-21-2013, 05:24 PM   #1910
aloksatoor's Avatar
Hmm, I am gonna try flipping the rear tapers on my xray and run a bit more drag brake. It worked wonders to cure the nose down jumping of the sct410 and also helps on looser conditions. The car squats on power a lot more and numbs the fwd wt transfer as well on braking (since rebound is slowed down by flat side), need a bit heavier rear oil though. Biggest advantage though is flatter jumping.
Old 03-22-2013, 08:01 AM   #1911
kenny lutz's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Arigato View Post
I have a set in my basket on amainhobbies. Please report back after you run them.
ok so lastnight the car had a little bit of a push after putting the new springs on but with some change to ride height it gain the steering and it landed alot better when over jumping and even jumping over all it felt good with the new springs.
Kyosho Rb6.6- Maclan mmax - Fantom 17.5
Kyosho Zx6.6- Maclan mmax - Fantom 13.5
Airtronics M12 - Auer Ace Hardware - Schelle
kenny lutz is offline   Reply With Quote
Old 03-22-2013, 08:10 AM   #1912
kenny lutz's Avatar
what should the 6 degree hub do compared to the 9?
Old 03-22-2013, 08:29 AM   #1913
asc6000's Avatar
just put together a set of Kyosho bigbores with ghea 4x1.3's and those will be run monday night as well. And the "big" race is this weekend so the track will be all nice and broken in with a new smoother layout, super jacked to run this week.
Ayrton Senna
Old 03-22-2013, 09:50 AM   #1914
07Forester's Avatar
Trader Rating: 10 (92%+)
Less Caster, gives you more steering.
ALL of the questions you could ever want are answered here
http://www.hudy.net/xhudy/showfile.p...2bef0706315e0c
Speed Passion USA - speedpassion.net
Team Associated Factory Team Cars
B4.2| SC10 | SC10 4X4 | T4.2 | TC 6.1 WC | RC8.2E
Xray [XB4]
Leisure Hours Raceway/RC-Raceway/Trackside/HobbyTown LITH
07Forester is offline   Reply With Quote
Old 03-22-2013, 09:52 AM   #1915
07Forester's Avatar
Originally Posted by MX943 View Post
There is no way that I will spend $70 on caps! The orings is better solution for Me.
Aluminum shock caps add ZERO performance gain to the car.
The o-rings on the other hand do. I was quite suprised when I built my kit that they didn't come in the kit.
Xray [XB4]
Old 03-22-2013, 10:14 AM   #1916
aloksatoor's Avatar
I used that exact setup and I did not like it much. It was wallowing around a bit and not as precise. The progs with xray shocks felt like a tc. The shock lengths are too much I believe and the kyosho shocks are much heavier. The towers need to be taller to use those beauties . Let me know if you find a good setup I still have the kyoshos lying around somewhere.
Old 03-22-2013, 10:18 AM   #1917
aloksatoor's Avatar
Yep its just a habit of mine, I spend anything possible to get the shocks bulletproof. That moment of revelation was when I drove a kyosho rb5 wc for the first time after owning a dex210 and a crappy cougar sv2.
Orings or at least bladders (to cut if need be) should have been part of the kit though.
Old 03-22-2013, 10:48 AM   #1918
kenny lutz's Avatar
thanks alot
Old 03-22-2013, 03:54 PM   #1919
Odin544's Avatar
Trader Rating: 93 (100%+)
So I'm finally setting my XB4 up and getting ready to run it a bit this weekend. Got everything in it and threw it on the scales just to see how it was side to side and its 110 grams heavy on the motor side. There really is no room to move components around to help even it out. Has anyone else ran into this? Have I been running too much TC lately? I would prefer to get it a little closer but 110 grams? Thats a lot of lead.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 03-22-2013, 05:37 PM   #1920
asc6000's Avatar
Really that much ? mines only 5 or so left to right but i have a big esc and servo. You do have a big motor on the right and a small esc and a lopro servo on the left but 110 grams is a ton. Cool job on the antennae tube and the wiring, thats some nice work.
Ayrton Senna
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
