Like Tree52Likes
Old 03-15-2013, 04:08 PM   #1861
KalEl63's Avatar
Just build the diffs the same as the manual says for the plastic gears if you are going to run metal ones
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 03-15-2013, 05:30 PM   #1862
B00t13g's Avatar
Thank you.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-15-2013, 05:50 PM   #1863
fullsyzz's Avatar
Trader Rating: 106 (100%+)
Originally Posted by MX943 View Post
Where to buy the NT1 gears?
GS Hobby!
fullsyzz is offline   Reply With Quote
Old 03-16-2013, 12:11 AM   #1864
MX943's Avatar
Trader Rating: 41 (98%+)
Originally Posted by fullsyzz View Post
Thanks Man,nice.
B5M
2013 BMW S1000RR Motosport 200hp
2015 Yamaha YZ450F,2002 CR250R
Aprilia Tuono ,2006 CRF450X st legal
BMW M3 E46
MX943 is offline   Reply With Quote
Old 03-16-2013, 09:02 AM   #1865
asc6000's Avatar
Trader Rating: 15 (100%+)
A diff that requires me to weigh oil to accuracy of 100th of a gram.
Yet tenths of mm's difference in the parts tolerance is OK ?
I think not but to each his own.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 03-16-2013, 04:20 PM   #1866
Phil Trotta's Avatar
Thumbs up
Ran this car the second time with m4 scrub fronts and m4 suburb rears.
Shortened rear wheelbase no rear sway bar car was very easy to drive and rotated amazing
Ride height was bones above level .... I think the finishing touch will be 6 degree caster blocks ...
The diffs holding up fine ... Great great buggy!!!!
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 03-16-2013, 04:22 PM   #1867
Looking forward to ordering once sorted things out.
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 03-17-2013, 08:19 AM   #1868
Sorry if this has been asked before but I was wondering if there has been a fix for the leaking shocks that I read about?? If there is a fix can someone point me in the right direction.
Thanks in advance
Bryan D is offline   Reply With Quote
Old 03-17-2013, 08:45 AM   #1869
asc6000's Avatar
Thanks in advance
After a few oil changes mine quit leaking. The tops of the shock bodies needed to "seat in". Some people are using Dex o-rings.
Similar to the diffs, mine leaked at first but a couple oil changes and proper wrenching on my part ended that.
Ayrton Senna
Old 03-17-2013, 09:41 AM   #1870
jhautz's Avatar
Trader Rating: 85 (100%+)
Thanks in advance
When I built mine the first time I put just a little grease on the threads of the shock body where the cap screws on. Never had a single drop leak. My friend had a little seeping the first time he built them but the light coat of grease solved it.
jhautz is offline   Reply With Quote
Old 03-17-2013, 10:14 AM   #1871
Green slime grease from AE/Losi etc
Old 03-17-2013, 10:38 AM   #1872
07Forester's Avatar
Trader Rating: 10 (92%+)
Thanks in advance
After initial build, I only had ONE shock leak. When I changed oils I realized I didn't tighten the top caps as tight as they could go. I put an allen in the hole in the top and tightened them more after a rebuild. no leak since and i've got 3 race days on them.
Speed Passion USA - speedpassion.net
Team Associated Factory Team Cars
B4.2| SC10 | SC10 4X4 | T4.2 | TC 6.1 WC | RC8.2E
Xray [XB4]
Leisure Hours Raceway/RC-Raceway/Trackside/HobbyTown LITH
07Forester is offline   Reply With Quote
Old 03-17-2013, 11:00 AM   #1873
Great thanks for the responses
Old 03-17-2013, 01:07 PM   #1874
Odin544's Avatar
Trader Rating: 93 (100%+)
This is what I used on the threads before putting the caps on. Hasn't leaked a drop since I first built them.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 03-19-2013, 02:33 AM   #1875
B00t13g's Avatar
Originally Posted by losi b View Post
Yeah baby!
Hey that's me in the grey hat in the middle! Lol
Mackenzie Meyercord
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
miranmotorports
