Like Tree36Likes
Old 03-10-2013, 06:14 AM   #1786
rraden's Avatar
Trader Rating: 231 (100%+)
Anybody measure the rear toe on their car with the kit setup, meaning the eccentric bushings in the center position? The instructions indicate it should be 3 deg. I stood my car on end and used a camber gage to measure it and it came out 1.5 deg on each side. I had to change the RR to .5 out just to get 2 deg. Can someone check their's and give some feedback?
rraden is offline   Reply With Quote
Old 03-10-2013, 06:53 AM   #1787
silvalis's Avatar
Trader Rating: 29 (100%+)
Mine was 3 deg with centre/centre bushings.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 03-10-2013, 08:12 AM   #1788
reg
1.5 on each side is 3deg in total,unless I'm not understanding what your saying,putting 2deg on each side will be 4deg in total
reg is offline   Reply With Quote
Old 03-10-2013, 08:28 AM   #1789
tc1
Trader Rating: 15 (100%+)
3 deg per side would be a TON of rear toe!
tc1 is offline   Reply With Quote
Old 03-10-2013, 08:45 AM   #1790
RShockley's Avatar
It is 3deg total not on each side.
Richard Shockley
Kyosho RB6 / Kyosho RT5
Mike's Hobby Shop......Carrollton, TX
Kalgard / Epic Cameras / SMX Optics / Heavenly Hobbies
RShockley is offline   Reply With Quote
Old 03-10-2013, 09:17 AM   #1791
A side note regarding the setup sheet in PDF format produced by the Xray data base: Ackermann position is switched between the html page and the pdf file, same for caster, and wishbones position (FF, FR, RF & RR blocks) are all over the place except when at center but not even sure.
Xray is aware of these errors produced by the system.
Arn0 is offline   Reply With Quote
Old 03-10-2013, 11:15 AM   #1792
B00t13g's Avatar
Has anyone tried using the 1/10th sedan hudy setup station for their xb4? I think with some spacers it would work quiet well.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-10-2013, 06:04 PM   #1793
Arigato's Avatar
What a nice kit! The build was excellent as was today's first race. The car is very easy to drive fast consistently.
Dog House Racing
XRay XB8E
XRay XB4
XRay XB2
XRay T4'17
Arigato is offline   Reply With Quote
Old 03-10-2013, 06:17 PM   #1794
asc6000's Avatar
Seems accurate on a Hudy setup. Your system of measurement may have been lacking some accuracy. Good you thought about it though, a used car with issues can definitely be off and it shows clearly on a setup system.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 03-10-2013, 09:02 PM   #1795
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Ran mine in our tracks outdoor season opener . Their was only 4 entry (²kyosho/¹ 44.2 /& my X-ray) after 3 6 min heats and 8min main all cars broke at some point EXCEPT the XRAY!! And this was my first ever off road 4wd buggy race .( Been running tc for 10+yrs tho) love the car . But now I also want a 1/8 scale whens the new one coming out ?
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 03-10-2013, 09:06 PM   #1796
Clint161's Avatar
Three degree's of rear toe is correct, measured on each side.
Yes that's 6*
Clint161 is offline   Reply With Quote
Old 03-11-2013, 02:41 PM   #1797
rraden's Avatar
Yes that's 6*
Thanks, that's what the clay setup shows, 3 deg per side! See attached picture. Maybe my measurement system is flawed. But standing the car on end and measuring the angle of the rear wheels should be close. I'll find a setup system and check it there.
Old 03-11-2013, 02:46 PM   #1798
07Forester's Avatar
Trader Rating: 10 (92%+)
Anyone using other wings besides the stock? If so, which ones?
Speed Passion USA - speedpassion.net
Team Associated Factory Team Cars
B4.2| SC10 | SC10 4X4 | T4.2 | TC 6.1 WC | RC8.2E
Xray [XB4]
Leisure Hours Raceway/RC-Raceway/Trackside/HobbyTown LITH
07Forester is offline   Reply With Quote
Old 03-11-2013, 02:50 PM   #1799
LMR & RUDEBITS R1
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 03-11-2013, 03:28 PM   #1800
asc6000's Avatar
So it seems the eccentric bushings are accurate. I hadn't checked rear toe since I built it maybe 15 runs ago. One side was off by more than one degree. I do a lot of triple checking and there it is, hmm, the left side was off but the right side was "right on". So I loosened all the suspension holder screws of both sides, tweaked the arms back and forth a bit to loosen everything up the same-ish, and brushed a little loose dirts from around the screw holes. Then holding both arms with a slight forward pressure so both would be in the same relative position I tightened the suspension holder screws.
Rechecked and both sides were right on at 3.0. So I changed the RR bushings to .5 out and both sides were again right on at 3.5
Clear example of even the rear toe being off due to wild tumbles tweaking things.
My chassis has been bent in the back for a long time.
Ayrton Senna
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
