Like Tree45Likes
Old 02-11-2013, 12:42 PM   #1561
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by kenny lutz View Post
where is everyone getting there parts from the only place i can find parts is amain and they dont have everything i want.
I get mine from my local hobby shop, the kit and the parts cheaper than online too. I haven't needed any parts however.
edit : keep in mind these come from Europe and they get here on a BOAT that travels about 2 miles a day.
I do believe the boat just landed and parts should be available soon
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 02-11-2013, 01:07 PM   #1562
BentKa's Avatar
could you post a picture of this upgrade and was it hard to do
Here's a crappy cell phone pic of the carbon brace for the front of the tower connecting the 6 screws:
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 02-11-2013, 02:55 PM   #1563
kenny lutz's Avatar
Trader Rating: 36 (100%+)
Originally Posted by BentKa View Post
Here's a crude cell phone pic of the rear brace made out of a piece of 90 degree aluminum angle:
The upper holes are drilled through to use a nut on the back side while the lowers are drilled and tapped for the 3mm hardware.
I'll see if I have a pic of the front brace as well............
Bent
That looks like the front but I might be wrong
Kyosho Rb6.6- Maclan mmax - Fantom 17.5
Kyosho Zx6.6- Maclan mmax - Fantom 13.5
Airtronics M12 - Auer Ace Hardware - Schelle
kenny lutz is offline   Reply With Quote
Old 02-11-2013, 02:59 PM   #1564
kenny lutz's Avatar
Bent
Go you only do it to the front tower and can you buy the piece on the front or you make it to?
Old 02-11-2013, 03:27 PM   #1565
BentKa's Avatar
Yes that's the front tower
Running the 4mm TeamSR carbon towers eliminates the need for a brace on the rear bulkhead or tower.
The brace for the front of the tower is made out of 2mm carbon fiber but can easily be made out of aluminum for the same effect.
Just use the shock tower as a guide and add material to the bottom part and drill out a couple of extra holes.
The use of 4mm towers lets the tower sit flush with the lower front part of the bulkhead as well......makes it really easy to make a brace for it
Doesn't take long and all you need is a Dremel and a drill bit + cutting wheel
Bent
Old 02-11-2013, 06:04 PM   #1566
KalEl63's Avatar
Just wondering when would you consider running +.75 or -.75 hexes front or rear to standard and why?
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 02-11-2013, 06:06 PM   #1567
aloksatoor's Avatar
Trader Rating: 42 (100%+)
running plus 0.75 rears since day one. The offset with my rango rear wheels seemed off by that much. I run a similar setup in my xb9 as well, helps lock in rear same as more toe in but more efficient.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 02-11-2013, 10:46 PM   #1568
Originally Posted by seth556 View Post
Get a spare set of outdrives, I broke one before I realized I need to limit uptravel on the shocks.
Once you have the upgrade kit you don't need anything. Of course different shock and diff oils are good to have for tuning. Get some spare wings too.
According to the shop the upgrade kit is included in the kit I've ordered.
Is this possible and are we talking about the same upgrade kit?
Mugen MBX7T OS Speed | Mugen MBX7 Os Speed | HB D413 | Sanwa M12
Huske is offline   Reply With Quote
Old 02-11-2013, 11:43 PM   #1569
asc6000's Avatar
trashed some gears, bummer as the car is on rails
so .... how, do you decide how much to shim ?
Ayrton Senna
Old 02-12-2013, 12:22 AM   #1570
BentKa's Avatar
Yes......all European shops should have gotten the upgrade kits several weeks ago so they will be included when purchasing a new kit
Bent
Old 02-12-2013, 12:42 AM   #1571
Bent
Oh OK, First we recieve as first the new Mugen Fuel tanks and now the upgrade kit from Xray .
Will fetch mine tomorrow afternoon .
As pinion I think I will put a 20T, is this good?
The motor is a hacker Skalar 10 5.5T, ESC is a hacker Tensoric 10 (160A).
I always try to have no play (sideways) and to shim it as thight as possible without feeling the teeth of the gears (minimal play between gears).
I hope this is good .
Old 02-12-2013, 12:51 AM   #1572
BentKa's Avatar
Depends on track size really.
We run a 20T pinion with Tekin Gen2 6.5T on this track:
+ YouTube Video
Plenty of speed with just a touch of boost for the straight
If you have a similar track size I would start with a 19T and go from there
Bent
Old 02-12-2013, 01:19 AM   #1573
KalEl63's Avatar
If it is any help I am running an 18T with a 6.5T Nosram and temps on Saturday didnít go past 60 degrees C (plus warm day in my part of Australia)
1.21 GIGAWATTS!!!
Old 02-12-2013, 03:29 AM   #1574
thinking about getting one of these. i'm used to ae cars and the ball diffs. how often do you have to change the oil on the gear diffs? when you check to see if it needs changing, how do you check? based on feel of rotation of the rear tires, just like a ball diff? thanks
xb2, xb4, RC10 re-release WC, sc5m, vintage rc10's
Eaglesrx is offline   Reply With Quote
Old 02-12-2013, 03:46 AM   #1575
BentKa's Avatar
I've ran AE cars for a "lifetime" and have always been very pleased with the ball diffs. Really low maintenance if you set them up correctly.
And the gear diffs on the Xray are no different.
Do it right and you will have a trouble free setup.
Sand the diff halves where they meet the gasket.
This will ensure a level and smooth surface to mate with the gasket.
I start off with 400 grit and finish off with 800 grit on a level surface (usually my setup board).
Soak the gaskets and o-rings in green slime prior to installing.
Take care when installing and torquing down the screws for the diff halves.
Do them a little at a time and every other screw to get it to seat properly.
After the first run-in change your oils to fresh to get rid of particles from the break in.
Enjoy a leak free diff for months
Bent
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
