Like Tree39Likes
Old 02-05-2013, 03:06 PM   #1486
rraden's Avatar
Trader Rating: 231 (100%+)
Originally Posted by Catzilla View Post
Has any one in the states seen or have info on upgrade kits
My LHS just called RC America today and was told the upgrade kits should be at RC America on 2/8 or 2/9. Then shipped out the next day from there to the hobby shops.
rraden is offline   Reply With Quote
Old 02-05-2013, 04:15 PM   #1487
BentKa's Avatar
Originally Posted by Jamison R View Post
You must be a proud father. She is a great driver and even shows great sportsmanship waiting for the other xray that flipped early in the run.
I couldn't be more proud
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 02-05-2013, 04:16 PM   #1488
BentKa's Avatar
Here she is in round #3 of qualifying.
+ YouTube Video
Bent
Old 02-05-2013, 05:15 PM   #1489
goehm's Avatar
Trader Rating: 44 (100%+)
Bent
That's pretty darn amazing. Very consistent, good throttle control, able to show restraint and run her own qualifier vs. worrying about others.
Most adult racers don't have all those qualities. Well done!
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Old 02-05-2013, 05:22 PM   #1490
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Yep gonna be sponsored soon. I would if I owned an RC company
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 02-05-2013, 05:57 PM   #1491
Falcon#5's Avatar
Has anyone had any issues of leaky diffs?
If so, what was the cause/remedy?
Cheers.
*Adelaide RC Team Driver* - adelaiderc.com.au
ARCR Member - arcr.org.au
XRAY - TLR - Kyosho - Tamiya
Spektrum - Savox - Hobbywing - Proline
Falcon#5 is offline   Reply With Quote
Old 02-05-2013, 07:43 PM   #1492
asc6000's Avatar
Trader Rating: 15 (100%+)
Cheers.
common issue, some used sealents some presoaked the gasket some like me just redid them a couple times while testing and as they broke in the leaks stopped. Same for the shocks.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 02-05-2013, 07:52 PM   #1493
asc6000's Avatar
Man did I mess this up. Early on I measured some wheels in hopes to using some of the 10-15 sets of FRONT mostly new mounted tires from my zx5 and was dissapointed that it didn't look like I could use them.
SO
I had the hexes off the ZX5 and the XB4 was sitting there so after finding the proper pin the Kyosho hexes were on the XB4 and the kyosho wheels fit right on the FRONT. DAGNAGBIT ! They are the tiniest bit more negative offset but good enough to look at it again tomorrow and probably run it.
The rears are even more offset and would need to be drilled so those are a no.
Ayrton Senna
Old 02-05-2013, 08:16 PM   #1494
Z00M's Avatar
SO
The fronts fit on fine with changing the pin. Use the .5 hinge pin inserts to widen the track back out to the standard width. The rears are different and won't fit without drilling as they have to fit over the 5mm part of the Xray axle. The wheels also need to be drilled.
The problem with the rear is that once you have drilled and messed around, you find that the wheel nut goes all the way on and the wheel isn't tight. You then need to put a spacer on the outside of the wheel or you can drill the Avid truck rear hexes like I did and narrow the inside of them a bit.
It takes some messing around but it worked so I could use up my old stock. Might be worth it if you have lots. I have run through all my old stock and now have shiny white Xray wheels and I have to tell you it is a lot less mucking around and the car seems to handle a little better as I can use more of the standard settings.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 02-05-2013, 10:58 PM   #1495
KalEl63's Avatar
My shocks leak really bad so I am going to try the caps in hot water and see if that fixes it.
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 02-06-2013, 02:50 AM   #1496
RShockley's Avatar
The caps seem to work themselves loose. I started unbolting the top and tighten the cap after every run. It's a little bit of a hassle but not bad.
Richard Shockley
Kyosho RB6 / Kyosho RT5
Mike's Hobby Shop......Carrollton, TX
Kalgard / Epic Cameras / SMX Optics / Heavenly Hobbies
RShockley is offline   Reply With Quote
Old 02-06-2013, 04:10 AM   #1497
ps71's Avatar
+ YouTube Video
Bent
Nice driving
Do you have a good setup for the track, plan to drive there this weekend..
Losi 22 2.0 xerun 120a v3.1 6.5t
Xray xb9e w/tekin rx8 gen2 1900kv t8
Spectrum dx3s
ps71 is offline   Reply With Quote
Old 02-06-2013, 05:13 AM   #1498
BentKa's Avatar
Originally Posted by ps71 View Post
Nice driving
Her setup for practice at the moment is:
Front:
35W AE / 2 Hole 1.6 / Progressive springs / Stock Swaybar
10K Diff / Holeshot M3 / Proline Closed Cell
Rear:
35W AE / 2 Hole 1.7 / Progressive springs / Stock Swaybar
5K Diff / Holeshot M3 / Proline Closed Cell
Everything else stock.
Good for 22.7 which is her personal best with this setup
Bent
Old 02-06-2013, 05:17 AM   #1499
BentKa's Avatar
Qualifying round #4 from a different angle on the track.
She went on to win all of her qualifying heats except for the first one in which her battery decided to let go
This earned her start #6 in the A-finals
+ YouTube Video
Need to get a better camera for filming indoors
Bent
Old 02-06-2013, 05:22 AM   #1500
RShockley's Avatar
She has better sportsmanship then most of the adults I race with.
Richard Shockley
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
MrLean
