Nikko Turbo Panther - disassembly help
guys;
i'm in no way an RC guy; i just rediscovered this car in a box of stuff i've had for years. so i put some batteries in it, drive it six feet, smack into something, and now it won't move.
i can hear/feel the motor turning, so i guess something happened in the gearbox. i started to disassemble it and found out that the rear wheels appear to be pressed on. does anyone know the correct way to get the rear end apart? do i drive the axle out from a particular side (axle exits out the right side, or axle exits out the left side), or should i try and pull the wheels off instead?
i want to get it going again, but i don't want to tear it up in the process.
thanks,
-ungarata
thanks,
-ungarata
I've got the same problem. I have Nikko off road DINGO (bought some 15 yrs ago) and I just want to clean the rear mechanism after kids played the car at seashore. Is there any way to turn the wheels apart after taking the engine out?
best,
Chris.
best,
Chris.
I have a Sears Lobo 1. The rear wheels had a press on sleeve on one side, and what lookes to be a nut on the other side, though I think it was a ress on also. I grabbed both wheels and pulled. The press on sleve came off. Now I may have just got lucky. The gear box is supposed to not be serviceable. Can you post some pics?
