540 4-Pole Question
540 4-Pole Question
I'm purchasing a 540 4-pole motor for my SC10 4x4. I was wondering what the difference between KV ratings between a 540 4-pole and a 540 2-pole motor is. I'm not putting a 540 2-pole motor in my 4x4, but i was just curious.
Also, what is a better choice for a small indoor track? A 4000kv 4-pole or a 4700kv 4-pole? I don't want too much power, but i don't want too little either.
Thank you.
Video of track this motor wil be on.
Thank you.
+ YouTube Video | |
Thank you.
Thank you.
I'm limited to what size 550 motor I can fit into my sc10. And the cost is significantly mor as well.
If its indoor 4-pole isent needed a 2-pole 550 can will do just as well you also wont need to buy the more expensive esc to support 4-pole. A reedy 4.0 550 and a hobby wing esc will be just as fast if not faster then a 4-pole.
the 4 pole will have more bottom end kick and depending on your Kv will have around the same top end. the lower the Kv the higher the torque. but also less top end. so I would say the 4000 would be better. but idk the size of the tack either. You could also go with the 1415 size 540 4 pole and get more torque than regular can motors with the same speed.
Those are fairly general statements. It really depends on the 4pole motor. Some have a lot of cog torque and are not smooth off throttle or on power. Some roll very freely like our Pro4 series. Some 540 motors also have a lot of cog torque.
We sell a 550 2pole motor that is good stuff for some applications. However we also sell a ton of 4 pole motors so someone seems to like them
I would have to go with the tekin pro4 4000kv setup. I loved it when I had my durango 4x4 SC. I had it paired with the rx8 speedo. I also had the castle creations 3800kv with mamba max pro setup. Both are fast and respectable, but when it comes to smoothness and response I think the pro4 takes it.
Was looking at the xerun sct pro esc with the 3656 sensored 540 4-pole. It is a small indoor track and the truck will only be used on tracks indoors, very similar in size. I will post a video of the track.
Video:
Video:
+ YouTube Video | |
Video:
Video:
+ YouTube Video | |
P's I'd take the hw xerun over the pro4 and rx8 any day, in fact I did I started this year with a rx8 pro4 setup and once I tried the xerun setup I sold the Tekin days later.
You think 4000 or 4700?
4000 should be plenty but if can always turn down a 4700
That's what I was thinking.
