Best Motor for Short Course Truck
I am going to be running a 60c 5600mah 2s lipo on a new Team C TS4 short course truck.
Does anyone have any recommendations on which motor to choose? I am torn between getting a 540 or 550 size motor. I feel the truck to be pretty light and suitable for a 540 can.
thanks for any advice guys!
As just a general rule for 4x4 SC you want a 550 or a 4-pole 540 to move it around the track, the 2-pole 540 motors tend to get too hot.
You will get a 100 opinions, but here a few ways to look at it.
For a budget, you can do well with the castle 3800KV or the tenshock motors.
I also like the Ballistic 550 motors since you can rebuild them one part at a time, or even change out the stator for different KV setups.
The Pro4 motors have a huge following, and are worth it if you can spend to set it up, and the new Revtech quads look to be strong motors as well.
Beyond that there a ton of good 550 motors to pick... but I have only dealt with Trinity and Ballistics in mine, and the trinity 550 is discontinued in favor of the 4-pole Revtech setups.
There are a lot of "right" choices, first thing to figure out is do you want ROAR spec (tenshock is not ROAR legal, or the castles if I recall right). Then decide if you want a 540 can or 550 can, then pick the right KV or turn for the track you plan to run.
Tekin motors r good
My Castle 1410 is pretty much overkill in my xxx. So It should be awesome in a 4x4!
