What is the different between Orion Vortex R10 Pro with 160A and 90A?
Can anyone explain to me the different between Orion Vortex R10 Pro with 160A and 90A?
If I'm running this battery: http://www.amainhobbies.com/product_...es-74V-5500mAh
Can I use the 90A or I must use the 160A? What is the benefit of using the 160A against the 90A?
Thanks guys.
Thanks guys.
power handling. the main difference is probably FET's. Which is basically power handling.
I would guess it is similar to the Viper VTX10 and VTX10-R. both have similar ratings except the vtx10 has 24 FET's and down to like 6.5 turn 540 motors and the vxt10-R has 48 FET's and can handle down to 2.5 turn 540's and 4.5 turn 550's.
i would say you'd be fine with the 90 amp would be fine for 2wd and the 160 amp would probably better suite the 4wd.
the 90A doesn't have the option to change boost or other things from the esc..
primarily just for stock blinky
