LST diffs shimming set
I have searched in the web and also in the Manual of the LST but there was not such a part for shimming the LST diffs. Does anyone know how i can shim them, and if they do need to be shimmed? At some point they will definitely need to, i know that but they are new now and they are not smooth at all when you try to turn them with your hand.
I run an E-Muggy, which uses the same diffs as the LST (just a different ratio).
The diffs in mine have the stock shims installed (1 behind each spider) and the diffs have put up to over a year of heavy 5S use. These things are bombproof, I don't see you really needing more then the stock shims.
i dont think there are any shims in lst diffs from stock
Yeap you are right, they are there, just checked the manual. Didint check good enough in the first place.
LST Shims
LOSB3951 = 13mm shim for the Diff Ring & Pinion
