Indoor tires (plz help)
Hi everyone i have new losi 22 buggy 2wd and i dont know what tires should i get for indoor racing.
Can anyone send me link for good deal and optimal tires for the indoor ?
Thank you alot
Thank you alot
What kind of surface is it? For indoor clay you want something like barcodes, suburbs, Rebars or beams. Ask around at your local track and see what everybody else is running, that is your best bet.
Its loam between 50-75F indoor temp tons of humidity in the air track is almost wet
Well that changes it then lol. Again I would check with what others are running. The only tires I can think of that might work are, Calibers Bow-ties and goose bumps. Thinking the bow-ties might be the best bet from your description, as I know calibers can get clogged up when it gets wet. Never used goose bumps so cannot comment much on them.
Are Ifmar Stud tires still available from Losi? They'd proabaly work good.
Just ask the top guys at the track what they're running! Also sneak in a few questions about shock setup, if you want a good baseline to experiment with.
