I Hate Shocks!
I Hate Shocks!
I'm fed-up with rebuilding shocks!!! I can never get the seals to seat right or even stay in the shock body. The ones I do are perfect though... I just rebuilt 2 or my 4 shocks & the other 2 are screwed-up so I need to order a new rebuild kit! I hate this so much, I will seriously pay someone like $5 to build my shocks for me.
If you are talking about associated shocks, get the yokomo caps. You cant go wrong with them making them even is a peice of cake!!
Team Fusion
Team Tekin
BKPaintwerks
Team Fusion
Team Tekin
BKPaintwerks
Heres a neat trick to building associated shocks, it's fail proof. Slide the first white plastic washer on your building tool and one of the rubber o-rings and seat them all the way into the shock. Then put the rest of the white washers and rubber o-rings on the tool and seat them. With the first two seated in the shock there is nothing to catch or rip. Take your time, get the yokomo caps and make some good shocks, be sure to use the green slime also.
Team Fusion. fusion batteries ROCK
Team Tekin
BKPaintwerks
Team Tekin
BKPaintwerks
Easy fix is to seat the first plastic washer and first o-ring by themselves before putting in the other parts together.
As far as rebound goes, just get them close and call it good. Even if you get them all exactly perfect, one lap around the track, if you took them off they'd all be different again anyhow...
Even though I am a Big AE fan... I must admit that Losi shocks are superior. They last longer, are much easier to build, and have less problems. Their "cartridge" system is something Associated should truly consider moving towards.
The owner of my LHS put some Yok caps on his B4 shocks and they were awesome. No air at all, and super easy to get right.
Too bad, he is out of them but when he gets some in stock I certainly will get them.
After building 2 of the 4 shocks on my BJ4 i hated Associated shocks as much as i hated my Xpress touring car.
Originally posted by Nrctc3
Well, that's kind of the problem I have now... The first half seats fine, but the last part of it doesnt.
No, actullay the first half is whats hanging up. Put the first two in, get them seated all the way to the bottom of the shock. Then put the remaing parts on the tool and seat them. It is fail proof. The best way to set rebound is with the Yokomo caps. Bleed them with the screw, loosen the screw just enough to let oil out as you push the shaft in, when the piston bottoms out tighten the screw with the shaft still pushed all the way in. You will then have somw awsome shocks.
Team Fusion, batteries that rock
Team Tekin
BKPaintwerks.
