The AE FActory Team B44.2 Thread
#8177
Ahh yes the screw that came with the kit that I put in that spot not to forget it. Thanks
#8178
I just picked up a b44.2 to run at my local carpet track..... I built it identical to cavalieri's carpet setup, minus the 3* rear toe. I cannot get this thing to NOT spin out when Im off throttle in a turn. ive tried different tires, stiffening the front end, softening the rear, reducing d/r and nothing fixes it......any ideas what to look for ? Also, if I stay on the gas through a turn, it pushes like a dump truck. My 2wd buggy has the opposite problem, but its way easier to drive.
#8179
When I ran the car on carpet I almost always kept the same setup from clay/dirt, and just put on the smallest spring cups to really drop the car down. I also ran clay compound Proline Ions with no traction compound on them because our track outlawed hard mini pin tires. It was on rails and no one could catch it.
#8180
Hello ,needs some info ,will the b44.3 gear diffs work on the b44.2 ,what other parts do I need to make it work .
#8181
#8182
In need of a new motor my brand new speed passion 6.5 fried on me!!! Any of you run the lrp vector x20 6.5??? If so is it a good reliable motor??? And what tooth pinion with stock spur??? Thanks for any information!!
#8183
#8184
For the 6.5 I would suggest 16-18 tooth with stock spur. Start 16 and check temps, gear up or down as needed with motor temps.
My 7.5 is 21/81 and comes off about 115 after 8 minutes with light boost and stock timing. My track is indoor and has some tight sections.
#8185
What's the diffrence between carbide and ceramic diff balls ,is one more durable or last longer ?
#8186
#8188
Do B44.3 gear diffs, front & rear fit on the B44.1?
Just buy the gear diffs and put then on the b44.1? Any mods involved or is not possible?
What parts are needed if a YES! Model number!
Thanks!
Thanks!
