Old 11-12-2012, 11:56 AM   #601
Just finnished my b44.2 build. I've built two Durango cars/trucks and it was sure nice to finally build a kit that had all the parts included. AE quality control is an A+. The build was easy and all parts meshed perfectly. I'm running a Tekin RS Pro with a Reedy 7.5. I'm using a basic box set up with a few minor tweaks that i feel are appropriate for my track.
Can't wait to run this thing, everything looks solid. As for the ball cups...i'll most likely go to RPM as well...eventually.
Borik is offline   Reply With Quote
Old 11-12-2012, 11:58 AM   #602
dMITIj's Avatar
Originally Posted by cantrell8 View Post
Thanks! and thats the right size and so on?
Best Regards.
TLR 22-4.
ORION VORTEX R10.1 Pro ESC.
ORION VORTEX VST2 PRO 7.5T.
ORION CARBON PRO 4500 100C 7.4V SHORTY PACK x3.
Sanwa MT4S Radio/RX-481 receiver & Xpert RC PI-3402 Brushless Servo.
dMITIj is offline   Reply With Quote
Old 11-12-2012, 12:01 PM   #603
rigor's Avatar
Trader Rating: 35 (100%+)
No the long RPM ones will not work on all links; they are too long for the steering links. You want the regular sized ones below.
http://www.amainhobbies.com/product_...-Ends-Black-12
rigor is offline   Reply With Quote
Old 11-12-2012, 12:04 PM   #604
aeRayls's Avatar
FYI that setup on petit... IS the kit setup, look in your manual lol
The kit does call for 1.7 rear pistons and 1 limiter in all shocks.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 11-12-2012, 12:05 PM   #605
cantrell8's Avatar
i put em on yesterday, outfitted both my 2wd an 2wd with the long ones, i assure you they fit, you can still adjust your turnbuckles without them popping a ball cup also.
Jonathan Cantrell
Viper rc
Rockcroller88@Gmail.com
cantrell8 is offline   Reply With Quote
Old 11-12-2012, 12:17 PM   #606
dMITIj's Avatar
so the short ones for the steering and the long ones the other places?
Best Regards.
TLR 22-4.
Old 11-12-2012, 12:22 PM   #607
rigor's Avatar
Originally Posted by tommy911t View Post
Got out on Sat for the first 4wd race since getting rid of my 44.1 last month.
Kit setup. 6.5 sonic, SXX TC2 with updated mod/stock board, no fan, no boost, no auto brakes.
Stock diffs broke in great.
No issues with stock ball cups while tumbling a few times during a full day of break in, practice, quals and racing.
Instructions did not recommend limiters in the rear shocks. Thought I could hear the dogbone ends in the rear during the air. Then, During a crash while practicing a cva came out. Quick fix: just set the rear shock lowers to the outside.
No ballast needed(for me.) But going from 1.6 to 1.7 rear pistons next.
Never liked chassis protectors other than the lexan type, but AE's version is super tough(like lexan) and scratch free on our smooooth new layout.
Batteries forward with padding(servo tape, one side not exposed) on sides and top straps.
Put a drilled v2 slipper plate in the front of my slipper during build. Slipper never over-slipped(heated up) in the 6 min main and I had it pretty loose to protect my new diffs on a loose indoor track.
Petitrc has this:
http://www.petitrc.com/setup/associa...mSetup2012.pdf
That setup addresses the rear shock limiter AND 1.7 rear piston(kit is 1.6) but no mention of ballast.
Over all first impression:
Over the past 3 years I've fallen in love the 44 layout. It's taught me the importance of a meticulous build and routine maintenance.Pitch control during flight is simple. Never heard chassis slap the entire night with the big bores.
Turns sooo steady but way more fun to catch an over steer and dart straight out.
Will go with the full PetitRC setup from here out until the pros have spoken.
For me, it's so good that the 44.2 is worth savoring for races. Because of dis-assembly required for diffs, maintenance, and breakages; my 2wd will continue to be my training vehicle for practice days.
Dude, what manual did you follow (not follow actually) ? The AE manual calls for 1 limiter on all shocks, and 1.7 pistons for the rear. You really want to get that limiter in the rears so you can mount on the inside bottom of the rear arm.
Old 11-12-2012, 12:23 PM   #608
tommy911t's Avatar
Trader Rating: 50 (100%+)
My mistake. Thanks
Edited my review to try not to confuse folks. Thanks for the heads up!
tommy911t is offline   Reply With Quote
Old 11-12-2012, 12:24 PM   #609
rigor's Avatar
Best Regards.
You can use short ones all over, and probably should. I actually did end up using long ones for both fr/rr camber links, but it required some extra winds of the cups to get them short enough to use. The benefit is those links should now never ever bend.
Old 11-12-2012, 12:28 PM   #610
dMITIj's Avatar
what is the limiter?
TLR 22-4.
Old 11-12-2012, 12:29 PM   #611
rigor's Avatar
If you got the long ones to fit and work on the short steering links, more power to ya. Seemed like I would have had to really wrench the cup too far for the link to be correct length.
Old 11-12-2012, 12:30 PM   #612
dMITIj's Avatar
Thanks for the info
TLR 22-4.
Old 11-12-2012, 12:47 PM   #613
rigor's Avatar
hmm is there no anti roll bar for the front? can't find any in the manual?
and is there an undertray for this kit?
Best Regards.
You should just be able to use the softer black roll bar that comes with the kit. You'll just need to buy the additional anti-roll bar pivots and ball cups (and set screw) so you can mount it up front. I've never heard or seen anyone using a front roll bar on a 44 however.
Old 11-12-2012, 12:51 PM   #614
rigor's Avatar
Look at step 1 on page 18 of the manual, and it shows a nylon washer that goes over the shock shaft (internally).
If you use the recommended shock mounting positions (inside lower hole on rear, outer lower hole on front) then you want 1 limiter on all 4 shocks. Page 23 & 24 tells you to add/remove limiters if you change these lower mounting positions.
http://www.teamassociated.com/pdf/ca...021%202012.pdf
Old 11-12-2012, 12:59 PM   #615
dMITIj's Avatar
I didten think so, i just saw that one guy use it on the front also so i got curious.
Thanks for the info on page 18, i didten see it before when i looked at the manual and didtent know it was the limiter
Thanks for all the info guys.
TLR 22-4.
B44.1 Thread RCHR Electric Off-Road 3011 04-09-2016 09:26 AM
RC10B4.1 FT/WC Wildcat1971 Electric Off-Road 28709 01-18-2015 07:27 AM
FS/FT Factory Team Associated Rollers SC10 and T4.1 ketthoover05 R/C Items: For Sale/Trade 8 04-11-2012 11:53 AM
Associated Factory Team B4 + parts, tires, custom body Cpt.America R/C Items: For Sale/Trade 13 04-09-2010 01:10 PM
SEO by vBSEO 3.5.0
