How is the Losi ten scte rtr??? >
Old 12-05-2014, 08:12 PM
  #16
Originally Posted by truggy1973
Is this truck suitable for a novice, just for bashing? Is it durable and easy to work on?
Thanks!
Yes, yes, and its a four wheel drive so there are some things (diff set up) to be learned. The shock towers need to be upgraded to the carbon fiber ones. The aluminum ones do bend pretty easily. That being said, i've been bashing a stock one for a year (i bought the roller so the electrics are different) and have only had to bend the shock towers back a few times. I've never messed with the diffs yet. Great truck!
JCascia is offline
Old 12-05-2014, 09:20 PM
  #17
OK, thanks! Does the ESC come with low voltage cut-off?
truggy1973 is offline
Old 12-06-2014, 05:35 AM
  #18
cttech455's Avatar
Yes. I believe its just a rebadged castle mamba max pro
cttech455 is offline
Old 12-06-2014, 05:47 AM
  #19
Losi SCTE rocks! I had an rtr and it was good. Now I have a scte with the TLR kit and tekin electronics. Love it, very durable and fast and it can take a beating.
Here's a video of mine running a tekin rx8 wth pro4 motor so you get an idea of the speed and durability.
https://www.youtube.com/watch?v=NV02CKY8O0U
CT4L is offline
Old 12-06-2014, 05:54 AM
  #20
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Thumbs up
Originally Posted by barbazoo74
What is the runtime bashing for stock losi teen scte rtr?
You should get 10-15 min with a normal 2 cell ($50-$60 )... spend more and get a 7800 ( $80 up) might get you longer run time depending how you drive
Yes it is a good novice /basher truck. You can also slowly upgrade it to make it more competitive.
> http://www.horizonhobby.com/LOSB0128...JQvhoCTsLw_wcB
Thanks!
XXXDad is offline
Old 12-06-2014, 06:13 AM
  #21
Default How about 2nd hand sc
Losi scte is a proven platform for sure. But, if you can wait for right time, you can find clean 2nd hand truck with top notch electronics. There are some people sometimes need to sell their scte 2.0s or tekno sct410s with tekin rx8 and pro4 or pro4 hd and with nice servos around 450-600 usd range w/o rx, tx. Even, i saw scte 2.0 with mip buggy conversion and tekin pro4 4600kv combo around 350 usd (w/o rx tx) and it seems to be maintained very well. If u can find one like these, i suggest you to go with those. From buying rtr and upgrading to scte 2.0 and nice electronics will eventually cost you so much more.
murat61 is offline
Old 12-06-2014, 09:13 AM
  #22
Is the SCTE 2.0 the updated version of the Ten SCTE RTR?
Thanks!
Old 12-06-2014, 09:25 AM
  #23
fq06's Avatar
Yes, but almost a redesigned truck... not just a few bling aluminum parts added.
Good suggestion murat61.
fq06 is offline
Old 12-06-2014, 11:13 AM
  #24
As far as I can tell, the 2.0 is a kit, not RTR. Is that right? I don't think I'd feel comfortable building a kit yet.
Old 12-06-2014, 12:18 PM
  #25
fq06's Avatar
If you take murat6's advice, you don't have to build anything. A used 2.0 (or a better choice for drivetrain durability Tekno) will be built.
But building a kit is the best way to go. The instructions will lead you right through the build and you will know the truck inside and out. You can do it, it is intimidating until you start and see that it's not that complicated.
Sooner or later you will need to tear it down for maintenance or repair so you will be working on it one way or another. If you have built it from the ground up you will have a better idea of its workings and be able to diagnose a problem easier than if you got an rtr or used truck.
fq06 is offline
Old 12-06-2014, 02:38 PM
  #26
werner sline's Avatar
cool vid ! what a nice spot, the dirt seems soft without gravel
werner sline is offline
