B4.1 recommended setup.
I have the extended chassis for the buggy, ive tried most of the team drivers set up, but i can never get it to turn very well. i have had other people drive it too and they say the same thing, so i know its not me driving it wrong...is there a certin setup that you have found to work really good? my lhs is Trackside in Milwaukee WI (Scotty Ernst place). medium to high bite i would say. any advice or tips are much appreciated!
Where in the corner does the car need more steering? What are the track conditions? What tires and inserts are you using?
First u should check to see if u are getting full throw both ways and check your steering dual rate on ur tx. if that is good then start looking at setup issues. What setup are u running anyway my friend?
Chad setup is very smooth and allows you to push the car
