losi truggy with losi e kit
#16
comes with a 45 and 15 and 16 tooth gears
#17
Yeah, those pinions are for 1900/2000kv motors or about there. You're going to need 12T and 13T.
Brand of the motor doesn't really matter, you don't want it getting above 180*F.
#18
#19
got a link to some good gears that will fit this kit
#20
look at a main they hav a 50 45 and 47 do they fit
#21
#22
is there a metal one to use?
#23
it will be here in the mail . do i need a metal one gear?
#24
You can use a metal one. Sometimes the slight flex in the chassis and just the sheer torque these motors put out strip spur gears. If you go with a metal spur just remember, you need to get the mesh just right or you will have heat/noise issues, and if anything were to jam the gears, goodbye ESC. However, I have been running the metal spur for a couple months now and I haven't had an issue.
#25
#26
help me pick a motor i like the cc mm 2200 kn is there a better set up
#28
If you like it stick with it. A faster motor doesn't always mean a faster truck, most likely will mean more crashes/flips. If you can run consistent laps without flipping over with your current setup, no need to change. And the castle 1500 series motors are VERY nice.
#30
Losi metal spur gear to fit with Losi E-kit
http://www.amainhobbies.com/product_...-Spur-Gear-45T
