Old 09-03-2012, 11:39 AM   #1
Default ::: Tamiya XV-01 PRO Rally 1/10 Review!!! :::
Hi guys i'm Benz from Thailand, this is my first post in RCTECH.com and i feel abit nerves hahaha.. a few days ago i got myself a XV-01 PRO kit and the performance was too good to be true!! the stabilities of the car is perfect for both tarmac and off road track. The normal setting out of the box works perfectly! The car itself is like TA-03 mix with DF-03 (stable like a touring car but have an ability of a off-road rally too in a sametime). If anyone really interest in buying a 1/10 rally car or a rally fans i will recommend u get the XV-01 or XV-01 PRO! worth every cents!
check out some of the pic i taken a few days ago... Enjoy
::: Tamiya XV-01 PRO Rally 1/10 Review!!! :::-20120903_031748_resize.jpg   ::: Tamiya XV-01 PRO Rally 1/10 Review!!! :::-20120902_054502_resize.jpg
Losi TLR 22
Tamiya XV-01 PRO
Team Associated SC10 4x4
KO Propo EX-1 K.I.Y
iluvm4 is offline   Reply With Quote
Old 09-05-2012, 07:34 AM   #2
Losi TLR 22
Tamiya XV-01 PRO
KO Propo EX-1 K.I.Y
Old 09-05-2012, 09:37 AM   #3
kevin107's Avatar
Trader Rating: 85 (100%+)
Send a message via AIM to kevin107 Send a message via MSN to kevin107
What motor/ESC are you running in it?
www.rcsoup.com - R/C Reviews, News, and Tips <<- PM Me if you'd like us to feature your product
kevin107 is offline   Reply With Quote
Old 09-07-2012, 12:54 PM   #4
Just ordered one today' can't wait!
Djtrippusa is offline   Reply With Quote
Old 09-07-2012, 03:53 PM   #5
Awesome car... thanks for sharing
ljh501 is offline   Reply With Quote
Old 09-12-2012, 12:31 AM   #6
color0's Avatar
I found that mine had some issues with the suspension and steering, the steering knuckles bind at full lock and the lower arms have just under 0.5mm of play when built according to the manual. Weird, but fixable.
Mine is primarily running on-road (tarmac rally, drift, "touge") so I left out the dust/dirt protection gear and it's starting to look a bit more like the old TA03. Because I'm using lightweight servo, ESC and receiver though the weight balance L/R is completely off, and I'm contemplating having a new base chassis made to move the battery farther towards the centerline. Please LMK if anyone's interested!
::: Tamiya XV-01 PRO Rally 1/10 Review!!! :::-img_20120911_232801_hdr.jpg
Brian Ma
Greyscale Racing
color0 is offline   Reply With Quote
Old 09-12-2012, 04:05 AM   #7
Sith Lord's Avatar
Trader Rating: 17 (100%+)
Scale Stage R/C Rally
Beware of the Dark Side
Tamiya TRF417v5 :: Tamiya F104 Pro :: Tamiya M05 Pro :: Tamiya XV-01 Rally :: Tamiya FAV 2011
Sith Lord is offline   Reply With Quote
Old 09-12-2012, 07:54 AM   #8
OSRC's Avatar
Highly recommend this chassis as well. Super planted on or off road...Tamiya nailed the set-up imo. I just changed the tires and ride height from factory settings and so far it drives like a dream!
OSRC is offline   Reply With Quote
Old 09-12-2012, 08:15 AM   #9
mkiiina's Avatar
Trader Rating: 35 (100%+)
What kind of jumps can this take, how much suspension travel is there? I have always been a fan of the Rally concept and have just been waiting for a proper execution, this one looks promising!
mkiiina is offline   Reply With Quote
Old 11-05-2012, 01:41 PM   #10
Justin-san's Avatar
I'm trying to find out what parts are included in the Pro vs the kit?
Justin-san
Justin-san is offline   Reply With Quote
Old 11-21-2012, 10:17 AM   #11
Default My personal overview and experience
Probably one of the most important differences between the pro and the regular kit is the upgrade to TRF shocks. You also get an aluminum motor mount, aluminum turnbuckle shafts, and steel universal driveshafts all around.
The TRF dampers are wonderful but the springs are something to be desired...it's too soft. In my first rally race on tarmac (medium grip) with patches of sand, there was too much body roll and the chassis was too mushy. Trust me, it looks realistic and cool as hell but man it was painful to drive. On hard turns the back wheel would actually lift. Stiffer springs and/or anti-roll bars could have helped here.
So before my second rally race, I purchased Tamiya's On road tuned hard white spring set part# 49382. For low grip offroad I installed the soft (reds) in the rear and medium (yellows) in the front. Used the stock damper oil that came in the kit all around...I think it's Tamiya #900 wt. Wow what a world of difference over the stock springs. This upgrade is a must! It was responsive but not jittery and soft enough for traction on snow/dirt/asphalt (surface type I raced this past weekend). It was easy to drive. An easy driving car is a fast car. To me it felt balanced.
This is my first belt driven car and it's smooth and quiet compared to shaft driven vehicles which means something to the quality of this product. The mud fenders are an excellent touch, the semi-sealed esc and rx compartment is excellent, and the sealed silicone filled diff is wonderful. Building the pro kit was fun as was my other Tamiya kits.
Now for some of the negative bits of this build. Tamiya couldn't completely pimp out the pro kit loaded to high heaven...they won't make money that way. So what broke on my XV01 this weekend during one of my races? My drivers side front suspension mount broke (made of plastic!). Tamiya conveniently released aluminum versions 54379, 54376, and 54377 (for the rears). So I'll be upgrading to those as the plastic ones will be too brittle for racing in the cold (-5 C).
Bulky aluminum parts are quite durable. However, in non bulky form we found that aluminum turnbuckles are not suitable for jumping in cold weather. One other racers XV01 turnbuckle broke after some light jumping. He was very upset. So if you are doing some serious jumping or running in cold weather, I suggest using steel turnbuckles.
Other than that everything is great on this car. Use the right tires for the road conditions and fine tune the suspension and you got a great rally car and could make for an intermediate on road car too.
Also, if you're doing hard running and jumping with this car, get the Tamiya slipper clutch set 54378. Note that the slipper is 77t and the stock it 68t so you'll be losing some top end speed if you don't change to a larger pinion.
Out of the box using a 17.5T on 2s lipo with the stock gearing (22t pinion/68t spur) was a bit slow. So I ordered Tamiya 26t and 27t pinion set 54228. The 26t was perfect for rally on snow/dirt.
Comparing to the DF03ra which I also have, they both are comparable in performance. I know because I raced a couple DF03ra's this past weekend and they are still a great car. But the XV-01 is something new and I had to have it. The front motor position is something unique to me and I must say that I like the front weight bias. It's a different driving experience for sure....meaning a positive one.
Overall, I'm more than happy with the XV-01.
Evandiego is offline   Reply With Quote
Sponsored Links
SEO by vBSEO 3.5.0
