Kyosho Scorpion Ve XXL Thread
#616
Still on the stockers here
Good to see that the talkon ones fit.... I have to say I am a fan of the ARRMA stuff.
Have not even got these buggies out yet for the season.....maybe this weekend
#617
#618
the stock shocks are good for the most part.
kinda feel like they smooth out after a while of use
#619
Mine were leaking as crazy. Tried to seal them, but they still leaked.
#620
i would like them but these buggies sit a bit cause of life and other RC's that get more use.
However they are very very fun to drive...y buddy bought some 8000mah 2s and I am going to try them the next time I get mine out.
I hope for at least 40 mins of run time
#622
What kind of motor temps do you guys see on these stock out of the box? I got one yesterday and after a quick test run the motor was pretty warm. I didn't have my temp gauge with me, so I couldn't check for an actual temp reading, but it felt warmer than it should be after only a few minutes. This was on 4S, 85F outside, on the street, not pushing it by any means.
#623
It was 85 out and the motor is enclosed in the chassis.
They do seem to run a bit hot but you need to temp it and see what it is.
I don't worry till its over 180 then shut it down.
Mine both have been puched to the limits in the summer time with paddles and have never over heated.
#624
Ran mine last night for over 1/2 hr.
8000mah 4s seems to work very well.
temps after the run were 130 at the motor and the speedo was warm.
Running it mostly on the grass and some on the street and its stock including the diff.
#625
Thanks for the information. Hopefully I'll have a chance to run it this weekend. This time I will make sure to bring my temperature gauge. Just wanted to see if a pinion change or some other simple fix might be needed. I have a bunch of mod 1 pinions laying around.
Is the ESC's bec voltage adjustable? I have a HV savox servo I want to put in, but cant figure out if/how I can increase the voltage.
#626
I would say no.
But you may want to google the Orion ESC
#627
#628
I don't think it's worth hassle. Plus I doubt I would save any money if I bought a rival to the 1270tg or 2274sg. BECs are cheap and easy to add, plus now that I run HV on almost all my cars, I prefer it to the standard stuff.
#629
Finally got mine out for a run. Did a RC demo at race track. Been awhile since I've tried jumping it. Did far better then I remember
https://youtu.be/MtUjrJYKAcY
