biggest 1/8 buggy tires?
These are 2.8 trenchers mounted on maximizer beadlocks...you do have to trim the tire bead a bit. I've seen guys mount these tires on rpm revolvers, which is a better idea(still have to cut the outer bead off of the rpm wheels to make it work. Very easy to do.
They are only a hair taller than buggy tires but much wider. Much shorter than truggy tires, but wider.
Probably not what you're lookin for but figured I'd put it out there since no one else responded
Its not quite as simple as just adding truggy arms. . You need truggy arms, driveshafts, shock towers, links, shocks. At least that's what I needed to convert a Vorza to a short chassis truggy.
Here's a link to my build..it will give you a general idea of what's involved.
http://www.ultimaterc.com/forums/sho...d.php?t=151962
or you could run 1/2" offset truggy wheels and rc8t extended hubs and have plenty of clearance.
With just the rc8t extenders u got 1inch total width.
So the losi hub extenders(pn-LOSA3533) that add 1/2 inch total wouldn't cut it.
What's the inside diameter of the rc8t hexes so I can be certain they will fit over my axles
I just measured....with a crappy- ass caliper I bought from harbor freight tools(so its not exact). But the inner diameter is just a bit over 8mm. 8.25ish I think?
Maybe someone else can chime in if rc8t hexes are compatible with losi buggies???
I know the associated hexes fit my hpi, hotbodies and thunder tiger RC's....seems to be a standard size
