Ofna Hyper 10C.
You will need a Mod 1 pinion. What motor are you running? Some motors have a 3mm shaft, while others have a 5mm.
Yes I found that out that it takes a Mod 1 pinion with a 3mm shaft cause I have a Novak 540 ballistic 10.5T motor. I think I will have to get a 550 sized motor for the truck cause I heard that a 540 will get a little too hot, so it needs a bigger motor. Thanks
I have not had heat issues with my motor, esc, or batteries with this truck. I have run a Castle 3800kv motor - 540 motor and now use a Tekin SCX 4.5. I think the Tekin is a 550 motor..not one hundred percent sure... Are you geared correctly? You may have excessive motor heat because your pinion is too large.... Do you race or bash? One other thing to check out is binding...Does everything move freely?
Your best bet is to go to the track that you are going to run on and ask knowledgeable racers. The Hyper 10SC is lighter than most other ten scale 4x4 Short Course Trucks. Personally, I run on an outdoor track and my next purchase would either be a Tekin 4 pole 4600 or 4000 motor or equivalent. Try running what you have and ask at your track.
Even though the 10sc is one of the lightest 4x4 trucks you will have a hard time getting the 540 10.5 to work well in it. Best cheaper choices (depending on you esc) will be ballistics 550 (used to run 4.5 in mine for large out door track) or castle 1410 4 pole motor. The castle ran a little cooler and was lighter. Either can be had in the fs forum for around $50-$80.
I use to run the hyper great truck. I would recommend 550 can, less stress on motor and electrics. Since its one of the lighter 4x4s you can ran 6.5 or down to 4.5. My buddy still runs one and is quick he has a pro4 4600kv and it flies I ran a 4000 kv and it was quick as well
