Savage flux problems, I've tried everything!
#16
I figured it out!
with some quick research i discovered i have parallel wires, while the previous owner had series, i read that parallel increases capacity( 5300maha*2= 16000mah) while series increases voltage(7.4v*2= 14.8v), so id imagine the ESC was set for 14.8v while im only giving it 7.4v and thats why it says Low Voltage Cutoff! i think i figured it out, so now should i resolder everything to make it series or is there a way to change that?
#17
lukily i do have traxxas connectors! is there a way to give you good feedback or like a thumbs up because you guys really helped me a lot! thank you soooooo much!
#18
I JUST LEFT SOME FEEDBACK AS IF I HAD BOUGHT SOMETHING TO GIVE YOU A +1 ON AWESOMENESS!
#19
It works!
Thankyou all I just switched around the connectors and had to solder one plug and know it works better than ever! Thanks guys you really don't know how happy I am right now it seemed as If everything was going down the drain until you guys helped me here, ThankYou!
