    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 10-13-2012, 03:22 AM   #1471
steam's Avatar
Originally Posted by Posvar View Post
Hey guys. I am on step 10 and have a quick question....the Japanese set up calls for a caster block setting of 4 degrees. Is that achieved by using the hub bushings (a4 and b4)?
Thanks.
yes
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 10-13-2012, 05:27 AM   #1472
silvalis's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Energyzer View Post
I'll use an arm reamer or some other hardware to get some plastic off... This does not happen in an Xray kit for example... It's my first Kyosho though.
Funny thing, I've never had to ream the inner suspension holes out on my K cars but I have had to on my T3'11 and T3'12.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 10-13-2012, 05:29 AM   #1473
Ray Kindstrom's Avatar
Trader Rating: 147 (100%+)
Originally Posted by Yeti AS3 View Post
Some more Yoshi love.
Finally sprayed the body after 2 weeks of running a stickered up body Red seems to be the thing now, so i went another route.
Looking fantastic, as always Curt!
Ray Kindstrom is offline   Reply With Quote
Old 10-13-2012, 05:32 AM   #1474
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
The tranny is done but there is a little side to side play with my diff. Is this normal? It's not much.......
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-13-2012, 06:19 AM   #1475
silvalis's Avatar
mine moves <0.5mm. Probably around 0.3.
If you're worried, you could shim it.
Old 10-13-2012, 06:23 AM   #1476
Trader Rating: 1069 (100%+)
Japanese setup, except .5 rear carriers and running in saddle config. Totally hard to gauge the traction as the track was slicker than snot(everyone had trouble). Car jumps/lands like a dream. Had lots of steering once I found the right fronts in the 2nd heat. I could take The triple that is normally a double single much more consistently(as long as I felt like I had the traction) and was lined up and clear the table top/single more consistently.
I think I'm going to try full stick pack as the japanese setup next time and maybe play with shorty and use foams for placement.
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 10-13-2012, 06:38 AM   #1477
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Originally Posted by jordy-15 View Post
Can i ask where did you get that CF battery strap and brace
from?
cheers
I made the strap and brace at work last night. I would make them if I knew the CNC would be open, but I never know how much work I will walk into each day.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 10-13-2012, 06:57 AM   #1478
gas1313's Avatar
Trader Rating: 18 (100%+)
Question guys my buggy is coming does the rb5 big bores fit the same on the rb6 just want to know for a extra pair of shocks. Thanks
gas1313 is offline   Reply With Quote
Old 10-13-2012, 07:19 AM   #1479
Trader Rating: 27 (100%+)
Yes but your other pair won't have the new caps
Kyosho, Lunsford Racing, Express Motorsports, Dibrino Designs.
C_Money is offline   Reply With Quote
Old 10-13-2012, 07:33 AM   #1480
Yes they are the same size length and use the same springs. The RB6 has new single piece aluminum caps which you can buy if you want them to be exactly the same...
Old 10-13-2012, 09:44 AM   #1481
Moderator
Posvar's Avatar
Thanks for the tips guys! Made it to step 20. Lol
Old 10-13-2012, 10:23 AM   #1482
BranVita's Avatar
Trader Rating: 39 (100%+)
Branden V.
Kyosho Rb6 | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1257
Kyosho SC-R SP | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1258
BranVita is offline   Reply With Quote
Old 10-13-2012, 01:58 PM   #1483
Here is a pic of my thumb screw down. I scribed a line on the under side of my battery strap and cut there with a strong razor knife. about 1~2mm of drilling the hole for the screw to go in it got really easy as it gets hollow from the bottom for the M3 screw. I cut the heads off of 2 15 or 16mm M4 screws, so about 7mm is on each side.
Old 10-13-2012, 02:14 PM   #1484
Trader Rating: 137 (100%+)
New RB6 pron.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-13-2012, 04:59 PM   #1485
Moderator
Posvar's Avatar
Any Saturday race reports?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22955 Today 12:08 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
