    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0į/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 10-20-2017, 04:23 AM   #14446
messn03's Avatar
Default Laydown parts...RB6
Originally Posted by hairymuffin View Post
In my opinion itís nice to get the new chassis/side guards, but if you donít want to, you can drill holes for the tranny. I think you only need to drill 2 holes?
LD trans case
6.6 camber plate/bulk head
Rf hinge pin holder
LD motor plate
LD gear cover optional
The 6.6 idler is optional too depends on if you run 3 gear or 4 gear. If running mod, go 4gear, wich you should already have all those parts
Thanks! Great info!
Mess Sez:
"Yur Gonna have That"
messn03 is online now   Reply With Quote
Old 10-20-2017, 01:32 PM   #14447
Default Need help please
Got an Ultima rb6 ready to run made some upgrades to race. how do you get the mode for forward only with no reverse for racing. Please help. Thanks
bonzo915 is offline   Reply With Quote
Old 10-21-2017, 05:23 AM   #14448
Still on the subject of springs: here are the ones I have. I think the unknown fronts may be white.
Jeff Werner likes this.
heyscottn is offline   Reply With Quote
Old 10-22-2017, 07:46 AM   #14449
I have sc6 but rb6 is good looking also
RedRenegade is offline   Reply With Quote
Old 10-22-2017, 03:18 PM   #14450
Default Adjuster rod??
Need some help here so my adjuster arm snapped at the track today (rear) and was looking to upgrade to this set up by Lunsford.... Lunsford Super Duty Kyosho Ultima RB6.6 Titanium Turnbuckle Kit w/Ball Cups (6) [LNS36106] the stock size says its 40mm but this set up is 55 for the front and 60 for the rear? Am I misunderstanding something or does anyone else have a good suggestion that I can get as a kit with ball ends as well since the arm snapped off inside the ball end. Your help is appreciated on any advice or should I just go back to stock. It is an RB6 Ultima ready set. Thanks in advance
Old 10-23-2017, 04:18 AM   #14451
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
The Lundsford Turnbuckles are probably longer because the ball cups are shorter than the stock Kyosho ones. those are good turnbuckles, I have them on my ZX6.6 with B6 ball cups.
Team Kyosho (RB6, RT6, ZX6 & SC6)
Team Orion R10.1 Pro
Team Orion Touch Duo Charger
Team Orion Pro Carbon 100C Batteries
motorfinger is offline   Reply With Quote
Old 10-23-2017, 11:11 AM   #14452
So I am new to this car and haven't raced a 2wd buggy since 03. I am having a little trouble figuring out the gearing. I am racing on a medium size indoor clay track with:
HW pro Stock ESC
TSR The one 17.5
Track power 80C 4500
4 gear Mid ball diff
Positrons
The smallest spur I have is a48 P 76. Based on what I have seen here and setup sheets. I came up with 32/76 at a 6.175. Problem is it doesn't fit. I have ordered a 69T to run 29-30/69. Am I even close or completely out to lunch?
AndyThomas is offline   Reply With Quote
Old 10-23-2017, 07:43 PM   #14453
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by Jeff Werner View Post
Thanks for the pic. Where are you placing the bottom of the spring (rotation wise)? What if the bottom of the spring (spring that was face down) was placed at 12 o'clock?
Thanks,
Jeff
Jeff, they should all be at 6 o'clock when looking down from the top.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-23-2017, 07:49 PM   #14454
oPAULo's Avatar
HW pro Stock ESC
TSR The one 17.5
Positrons
Right on track with the gearing. We run 28/69 for medium to small tracks in 17.5 class. Try 3 gear transmission too.
oPAULo is offline   Reply With Quote
Old 10-23-2017, 08:30 PM   #14455
Ok good to know I will start with 28/69. Would it be safe to say dropping to a 26/69 would be ok for a 13.5 at 6.9?
Thanks!!!
Old 10-24-2017, 04:54 AM   #14456
^^I'm running 30/76 on my 13.5, which is really close to 27/69.
**edit - do you mean 6.9Amps? That's much hotter than I'm running, so you should start lower than my figures.
Old 10-24-2017, 11:03 AM   #14457
Sorry, 6.9 final drive ratio.
Old 10-26-2017, 01:23 PM   #14458
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Help with my diff, it is rebuilt with all new parts. New diff screw,spring,nut,everything. Problem is, it keeps barking when ran too loosely. I have to have the diff really tight for it not to slip. Do I need to replace old parts on my slipper? The spring is pretty old. But I didnít think it would effect the diff issue
hairymuffin is offline   Reply With Quote
Old 10-26-2017, 01:42 PM   #14459
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
do you use a break in procedure? ive seen diffs not broke in properly just get ruined one run. Xray Ty Tessman has a nice utube video
TEAM ASSOCIATED Rc10, rc10B6D ,FUTABA , TEAM ORION, KYOSHO RB6.
mdwaeracer is offline   Reply With Quote
Old 10-26-2017, 01:43 PM   #14460
I use the tebo method, I will look and see what ty does
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Yesterday 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
