    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 09-22-2017, 07:15 PM   #14401
Default Doesn't seem right??
Using the 0.3 mm washer as manual states, my rear wheels and cva have huge ( 2mm ) horizontal movement from my hub carriers? Is this right, thinking I need to add 1.5 mm washer?
powerpig is offline   Reply With Quote
Old 09-22-2017, 07:26 PM   #14402
Michael#81's Avatar
Trader Rating: 254 (100%+)
[QUOTE=powerpig;15036411]Using the 0.3 mm washer as manual states, my rear wheels and cva have huge ( 2mm ) horizontal movement from my hub carriers? Is this right, thinking I need to add 1.5 mm washer?[\QUOTE]
Are you using the 2 line or 3 line rear axles? If using the stock 2 line axles the .3 shim and a 1.5 spacer is used. If you are using the 3 line axles you will have to use a 3mm brass axle spacer.
Michael Malott
Michael#81 is offline   Reply With Quote
Old 09-22-2017, 07:44 PM   #14403
[QUOTE=Michael#81;15036424]
Yes stock. Brass collar in between bearings in hub. Will add 1" spacer. Thanks for quick reply!
Old 09-23-2017, 12:28 AM   #14404
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Been running kyosho many years, always have used the aluminum shock caps. Any of you run the plastic caps with the bleeder screws? Just curious, because I noticed some of the factory AE guys using plastic caps on their b6's. Im going to see how week they hold up. I've just never given those caps a try..
hairymuffin is offline   Reply With Quote
Old 09-24-2017, 05:23 PM   #14405
TheRcworld101's Avatar
Would anyone happen to know the part# to the low mount ballstud to use on the rear bulkhead of the RB6.6 to get more roll out of the car instead of using the stock ones? Thanks guys
TheRcworld101 is offline   Reply With Quote
Old 09-24-2017, 05:45 PM   #14406
Michael#81's Avatar
The only low mount ball stud I know of is the LA246. Never used it on the rear bulkhead but mainly on the steering.
Michael Malott
Old 09-24-2017, 05:47 PM   #14407
I have never ran them in steering..gives you a little more steering correct? Besides that I don't think there is one for the rear bulkhead
Old 09-24-2017, 06:02 PM   #14408
Michael#81's Avatar
Not really more steering but a consistent feel. If you run it on the steering rack it will change the ackerman and give you a little more stable and calmer steering. Just like turning the steering plate around to calm the car down and not make it so twitchy. If the track is really slick and you are getting a lot of oversteer it would be good to try to not change the whole setup.
Michael Malott
Old 09-24-2017, 06:07 PM   #14409
Ahhh ok. I never tried that on mine. Will get me a few and see though. Thanks man
Old 09-28-2017, 08:14 PM   #14410
Besides the Kyosho brand pistons that come with the kit and the options that they sell..What other pistons have you guys ran on them that work well to? I was looking at schelle pistons. Was wondering if Ae pistons work on the K shocks. To be able to get 2x1.7 and other options. Thanks
Old 09-29-2017, 05:56 AM   #14411
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I have used VRP Shock Pistons.
If you use the Associated ones, make sure you don't get the V2's. Those attach to the shock shaft with a small screw.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-29-2017, 07:09 AM   #14412
alex4r's Avatar
Send a message via AIM to alex4r
To use the Schelle (and likely Associated) pistons, you will have to use a shim on the shock shaft between the piston and e-clip. Otherwise there is a lot of play due to them being thinner. I ran them a long time ago since I had them on hand, but ended up getting another set of Kyosho 1.6's and drilling them to 1.7 since they fit better.
Alex Kennedy
Bellgate Distributors | Highest RC
Sanwa M12S | Kyosho RB6.6 | Kyosho ZX6.6 | Kyosho MP9 TKi4
alex4r is offline   Reply With Quote
Old 09-29-2017, 10:11 PM   #14413
I'll probably end up drilling the 1.6's out to 1.7. K pistons are probably going to fit the best and work the best with the K shocks.
Old 09-30-2017, 02:07 AM   #14414
http://www.kyoshoamerica.com/Shock-P...cs_p_8038.html
Jason.Dias is offline   Reply With Quote
Old 09-30-2017, 02:10 AM   #14415
JAE
Trader Rating: 28 (100%+)
Jason Dias - What's the latest and greatest setup for med/high bite nowadays? Your buggy looks good. You running the 1.6/1.7 setup or the old school 1.4x3 front and 1.6 rear? Any new setups out there you're hiding? Lol
Originally Posted by Jason.Dias View Post
http://www.kyoshoamerica.com/Shock-Piston17mmx1-Hole2Pcs_p_8038.html
Jeff Werner likes this.
JAE is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Yesterday 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
