    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 08-07-2017, 05:20 PM   #14341
JAE
Trader Rating: 28 (100%+)
Are the AE gullwing's a pop in solution, or do you need extra parts? Any special dremeling or work required? thx
Originally Posted by RogerM View Post
I do on high grip surfaces yes.
Gullwing arms basically change the way the shock inclination changes as the car rolls. The result of this is that, changing nothing else, you lose a little initial steering but gain a good chunk of mid-exit steering.
This makes the car feel more neutral through the whole turn with the tire combinations we run on astroturf / carpet.
JAE
JAE is offline   Reply With Quote
Old 08-14-2017, 04:23 AM   #14342
Drop straight on with a few spacers, think it's 1.5mm outboard and 3mm inboard from memory.
Kyosho UK RB6.6 & ZX6.6
RogerM is offline   Reply With Quote
Old 08-14-2017, 02:33 PM   #14343
Woulvesbaine's Avatar
On the AE, a different tower is run; I'm guessing to maintain sufficient droop. Maybe someone can confirm that in which case double the amount of droop you have after switching.
Woulvesbaine is offline   Reply With Quote
Old 08-15-2017, 05:02 AM   #14344
If you were running short eyelets on the front run mediums, if you were running mediums then run long.
If you were already running long your track isn't going to be suited to gullwing arms anyway so no need to worry.
Old 08-20-2017, 05:50 PM   #14345
Tommy R's Avatar
Trader Rating: 20 (100%+)
Hey folks,
I bought my RB6.6 used and raced it for the first time yesterday. Did pretty well with it, but the motor ran hotter than I feel comfortable with. I need a fan on it and have been searching for what is available in the aftermarket world....such as the waterfall mount I had on my Assoc. B5M. So far, I've come up empty. Any suggestions?
Thanks!
Tommy
Tommy R is offline   Reply With Quote
Old 08-20-2017, 08:13 PM   #14346
Originally Posted by Tommy R View Post
Hey folks,
Thanks!
Tommy
The exotek angled fan mount is what I use, however . . . I used to shoe-goo it to the chassis as well, and while not nearly a cool it works.
mupchu is offline   Reply With Quote
Old 08-21-2017, 04:48 PM   #14347
oPAULo's Avatar
Hey folks,
Thanks!
Tommy
nvm...
Stinkin photobucket...
oPAULo is offline   Reply With Quote
Old 08-21-2017, 10:11 PM   #14348
Tommy R's Avatar
Well, I ordered a 30mm fan from Maclan and will try to install it similar to what I saw in an RC Car Action article. Haven't decided on the mounting method yet, however...and I can't quite tell how this one (below) was attached.
Old 08-22-2017, 05:55 AM   #14349
oPAULo's Avatar
I can't figure out this image linking anymore...
Old 08-22-2017, 10:01 AM   #14350
Looks like double-sided tape to be honest . . .
the fan does not have a screw in it for a mount, and it does work . . .
Old 08-22-2017, 10:03 AM   #14351
JAE
Best way is to CA glue the fan to the double sided tape and stick the tape to the chassis. This is better than the fan mount as it doesn't bounce around. Distributor for WTF fans gave me the advice and haven't broken one since
Old 08-23-2017, 11:45 AM   #14352
Tommy R's Avatar
Now that's pretty interesting! I may give it a try when the fan arrives tomorrow. Thanks!
Old 08-23-2017, 11:57 AM   #14353
I shoe goo mine down. No issues at all and with a little heat it releases clean.
Jeremy Clark
RB6 for Mid, ZX6 and an untold number of Axial crawlers for family fun...
Arcain41 is offline   Reply With Quote
Old 08-23-2017, 12:02 PM   #14354
JAE
Best thing about doing it this way, other than it stays secure, is that being it is CA glued to the tape you can still take your motor out. The fan can be bent since it is the tape that flexes a little and fan is CA'd to the tape.
I've taken my motor out a dozen time and never had to re-tape the fan.
JAE
Old 08-23-2017, 12:18 PM   #14355
Tommy R's Avatar
I have a setup question(s) for everyone. I picked up my RB6.6 used. I went through it and set it up with the box stock setup as best I could, but the manual was a bit unclear in some regards. I also noticed that the rear pistons were 4 hole, but I believe they were originally 2 hole?
I'm running on a very smooth turf track that's awfully high bite so I'm running a laydown transmission setup with a shorty pack as far forward as I can get it. I'm also running the hardest front springs and the second hardest rears, based on some info I found online. Given the high grip levels, I thought it seemed pretty reasonable. Anyway, I threw 35 WT in the dampers and raced it last weekend. It did well, but had a few issues...
It had a slight push on corner entry. Not awful, but it was noticeable. It also flat-landed poorly and would seem to slap and get sideways sometimes. The track's landings are easy to overshoot and when I did, the car would typically get pretty upset costing me lots of time. Here's a video a friend took for me while I was practicing:
https://www.youtube.com/watch?v=Uqc9ODkej98
I also checked the petitrc site, but didn't see a setup for high grip, smooth turf that's geared for an RB6.6 (as opposed to an RB6). Any suggestions?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22953 Today 12:29 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
