    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 01-27-2017, 12:32 PM   #14161
Originally Posted by JAE View Post
Dope new strap eliminates waterfall and uses a turnbuckle
http://rawspeedrc.com/kyosho-rb6-6-c...-strap-set-up/
Agree, it looks awesome - love CF. However, if you have to undo 4 screws plus a turnbuckle screw just to change batteries...sheesh.
(I know...first world problems...)
...I'll probably still get one.
BK24 is offline   Reply With Quote
Old 01-27-2017, 01:13 PM   #14162
JAE
Trader Rating: 26 (100%+)
Needs shock posts. Anyone know if the zx6 and rb6 aluminum shock posts are the same size? Links below
https://www.amainhobbies.com/kyosho-aluminum-battery-post-set-gunmetal-fs2-sp-kyolaw41gm/p219092
https://www.amainhobbies.com/kyosho-aluminum-battery-post-set-gunmetal-kyoumw520gm/p222069
JAE is offline   Reply With Quote
Old 01-27-2017, 02:14 PM   #14163
Trader Rating: 137 (100%+)
You take your battery out to charge? hehehe... I like that it will allow better battery placement. My electronics are very cramped up front. Should have gone with a KO radio instead of the 4PX. Indeed first world problems.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 01-27-2017, 02:15 PM   #14164
https://www.amainhobbies.com/kyosho-...aw41gm/p219092
https://www.amainhobbies.com/kyosho-...w520gm/p222069
You have to use the FS2 battery posts. Or you'll be doing some odd shimming, and who wants that annoyance?
Old 01-27-2017, 02:22 PM   #14165
I own a 6.6 laydown and standup running stock. Prefer it to all buggies I've had thus far. Have not driven it mod yet. Does this buggy have the forward grip of the b6 and other competitors in MOD using the 3 gear laydown? I've noticed a recent trend that a lot of people runnning mod with a laydown are running 4 gear. Wondering why that is. Considering trading my b6 for another 6.6 to run solely in Mod
I'm going to try the 4 gear laydown with the shocks mounted in front today. Its dry in Socal so LRH wont be as high bite as it usually is. Hoping to get more forward bite out of the car without it washing out so easily. I did stuff 15 grams of weight under the transmission as it says on Tebos setup. Will report back in. Track should be dry with a bit of dust build up after the 2nd hour they are open.
Old 01-28-2017, 09:20 AM   #14166
JAE
How was the 4 gear? Thx
Old 01-28-2017, 09:44 AM   #14167
As I figured, when the track was drying up, when the winds kicked up, moving to tread and 4 gear with really good, felt way more planted, and I didn't necessarily notice much loss in corner speed. I need to correctly prep some tread for when those types of conditions happen, but it was definitely miles better then 3 gear, car would wash out the rear end very easily. I've got the parts to build both transmissions for a quick change, so i'll be ready for next race day.
Old 01-29-2017, 03:37 AM   #14168
Motorman007's Avatar
Trader Rating: 76 (100%+)
What is the weight bias of the rb6.6.
I just did my rb6 and I got 38/62
My b5m lite is 36/64.
Just wondering what the 6.6 is in Stock form.
Thank you
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 01-29-2017, 08:11 PM   #14169
Originally Posted by FallenAllDay View Post
Currently have an rb6, absolutely love the way it drives however the rear grip is really lacking and struggle to get forward bite outta the turns for the tracks I run on, medium grip at best to low/loose outdoor tracks. Is the new chassis and side guards make a significant difference compared to the original chassis?? I run mod so I'm already running 4 gear stand up, rf brass weight etc just chasing some grip, thanks guys.
I have been tinkering with an RB6 also, agree feels quite nice. However i was told to cut the side guards and trim the edges of the chassis to run the shorty sideways. I also trimmed the tabs from the front of the waterfall to get a few more mm.
I was quite astounded by the improvement. Ran on a really low grip blown out track yesterday and had quite good results.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 02-02-2017, 03:02 AM   #14170
eper's Avatar
Trader Rating: 14 (100%+)
Does anyone know where I can find a db2 chassis. I need a new one. Or used doesn't matter as long as the rear holes aren't worn out past being good. Mine let go and I just got the car where I really am liking it
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 02-05-2017, 12:40 AM   #14171
JAE
Default 2hole or 3hole pistons
Anyone running 1.4 3 hole pistons or any 3 hole pistons vs 2 hole? What practical effect have you noticed on the buggy? Thx
Old 02-05-2017, 03:12 AM   #14172
eper's Avatar
More holes make the initial pack more resistant then it becomes a softer feel due to turbulence in the oil basically the 3x1.4 is in between a 2x1.6 and a 2x1.7.
new milford ct,
Old 02-05-2017, 11:37 AM   #14173
JAE
I have a laydown rb6.6....Practically speaking, would moving from 1.6x2 all around to 1.4x3 give me less traction as the pack goes up...1.4x3
Old 02-06-2017, 04:08 AM   #14174
eper's Avatar
No more traction the initial pack is more kinda the first input into the shock it stalls movement more then gets softer. U could try making a 3x1.3 to do what your looking at or try a 2x1.5. Are u looking for less traction for or rear and in what situation?
new milford ct,
Old 02-06-2017, 07:35 AM   #14175
JAE
Looking for more traction, sidebite and coming out of the corner on power. First Time running the laydown 6.6 with a mod Motor. Have no traction issues in stock but haven't put down serious power...I have these vrp eu pistons that do not come in 1.7 2 hole rear so was debating to go 1.4 3hole rear with the 2x1.6 fronts, 2x1.6 all around, .or just 1.4 3 hole all around. Track runs electrons in med bite clay. Thx for the help
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
